Go Back  RCU Forums > RC Helicopters > Electric RC Helis > E-Flite Helicopters
 crashed my CPP pretty good >
E-Flite Helicopters Discuss the line of E-Flite mini and micro helis including the Blade CP, CP Pro, Blade CX, etc
Old 02-07-2008 | 09:47 PM
sportrider_fz6's Avatar
Default crashed my CPP pretty good
I'm actaully innocent in this one, I was hovering it about 6 feet in the air in my backyard, I flew it across the yard and brought it back to me a few times, then it happened... the Heli started glitching pretty bad the first two I was able to correct but the last one sent it backwards into the ground. the damage was limited to a tail motor and boom. so my question is, How do you remove the tail boom from the main frame and tail motor mount? it seems like it's glued in or something is it just pressed in or are there some screws I'm not seeing?
ID:	872760   Click image for larger version
Old 02-07-2008 | 09:49 PM
Default RE: crashed my CPP pretty good
It's glued. Just give it a good twist and it will come out.
Old 02-07-2008 | 09:56 PM
I'll try again the tail boom just keeps splintering instead of breaking loose.
Old 02-07-2008 | 10:09 PM
It must be stuck in there pretty good.
Old 02-07-2008 | 10:14 PM
Big Green Machine's Avatar
I couldn't get mine out either, my boom was fine but the frame was broken. The boom just splintered into bits when i twisted it. I don't think they sell the boom and tail rotor mount seperatley anyways do they? I have seen teh package and just the frame but not the boom/tail rotor set.
Old 02-07-2008 | 10:52 PM
Use heat, a heat gun or hair dryer will work. I have used a pencil torch, but you really have to be careful. Heat it well, then twist it. This has worked every time for me. Spread the word, I have answered this several times.
Old 02-07-2008 | 11:32 PM
thanks for the help. I finally got the boom out of the frame. the boom is now flush with tail motor mount, so I'm just going to buy a new one.
Old 02-07-2008 | 11:35 PM
just a though but has anyone fabbed up a tail boom out of aluminum tubing? the OD looks about the same size as tranny cooler lines. I don't know it's just a thought.
Old 02-07-2008 | 11:51 PM
I'v never tryed an aluminum boom but that would look really cool.
Old 02-08-2008 | 12:00 AM
There are aftermarket aluminum booms avaialble. I remember stumbling across them somewhere for cheap. For me the problem isn;t the boom its the frame where the boom mounts as it is such as small mating surface and is easily broken. I used heavy glue to fasten the boom the whole way up the HH Gyro flat mount for added strength.
Old 02-08-2008 | 12:20 AM
Here is an idea......bring a sample of your boom to an Archery store and ask them to match it up with either a carbon fiber or aluminum shaft.....CF is one hell of a lot stronger then the stuff the factory uses and there are some CF arrow shafts that have an alum inner tubeing also for the ultimate boom. they wont charge much either. But make sure they cut it to the right size as CF is a tricky animal to cut.
Old 02-08-2008 | 12:31 AM
on the e-flight website they have all the parts listed separately, does anyone know the part number for the tail boom with the tail rotor gear housing already attached? geez I must be ham fisted something fierce I broke the vertical stabilizer trying to get it off the gear housing also. oh well there only $1.99
Old 02-08-2008 | 09:35 AM
The boom and tail motor mount are two separate parts. This would be a good excuse to order the cnc twin motor mount and MicroHeli verticle fin. The only time I ever broke tail booms ( six of them) was when using plastic blades. They will cut the boom every time, even aluminum booms. When you install the new boom, just push it on and use a few drops of CA where it joins the body. This will make it easier to remove the next time you break it.
Old 02-08-2008 | 11:24 AM
I am telling ya...if you use a CF arrow shaft as a boom...it will be the last boom you will ever need to buy.
Old 02-08-2008 | 01:02 PM
ORIGINAL: MAMMOTH TOUGH
Are you sure about that? the CPPs boom isn't very thick. i'm not an archer but I have shot a few arrows and the ones I used had a much thicker shaft than the boom which is only 3/16".
Old 02-08-2008 | 01:08 PM
CF arrows come in a large selection of diameters from tiny to fat I am going to the archery store soon (either today or tomorrow and I will give you the shaft number that fits) and if any of you have a hard time finding the right one I will be more then willing to ship them pre cut.
for the cost of the shaft and what ever actual shipping there is.
