Electric General Discussion General Discussion forum about rc electric related aircraft, accessories, flight, tips, etc.
Setting up Elevons
Old 04-07-2010 | 12:25 AM
Default Setting up Elevons
Hi,
I have a Delta wing type plane (Superfly) and I am confused about one of the settings that I am trying to get right. I am using a Spektrum DX6i, and when I have the settings so that the aileron function works correctly, then the elevator functions are reversed. If I reverse the elevator so that they move in the right direction then the ailerons are reversed and turning the opposite direction. If I change one so that it's correct the other goes the opposite direction. The left servo is in the aileron slot; the right in the elevator slot of the receiver.
How can I correct this?
Thank you!<br type="_moz" />
Old 04-07-2010 | 08:29 AM
My Feedback: (9)
Default RE: Setting up Elevons
I'm not familiar with the Spectrum radios, but I would try switching the aileron ports. Be sure to mark them when you foind the right combo. I've had to do this with both an Airtronics and a Polk tranny.
Walt
PS you may still have to play with the reversing.
Old 04-07-2010 | 09:36 AM
It sounds like you have things exactly backwards...    Here are the steps I went through with my gryphon
Select wing type "elevon"
plug left side into elevator, right side into aileron
adjust the amount of throw...
Done
I'm thinking just do a reverse on both channels and you should be good to go.
KKKKFL
Old 04-07-2010 | 11:56 AM
Set up the elevator function first.
Polarities etc.
The aileron function is then set by swapping channels between the two servos.
Trying ailerons first won't work.
Old 04-07-2010 | 12:08 PM
Hope you followed that last...  it makes so much sense....  Thanks Tall Paul,   by polarities he means the servo reversing function.  Set that up for elevator.
KKKKFL
Old 04-07-2010 | 02:46 PM
Thanks for the assistance!  Reversing which was plugged into the aileron/elevator slots seemed to fix the problem.<div>
</div><div>Now another question what should I do about the other settings on the transmitter?  Should there be a mix?  And anyone know where I can set the throw?  </div><div>
</div><div>Cheers.</div>
