Go Back  RCU Forums > Electric Aircraft Universe > Electric Pattern Aircraft
Reload this Page >
New Krill Spark Evo I- Build Thread.....
Electric Pattern Aircraft Discuss epowered pattern aircraft in this forum
Old 09-04-2011, 07:32 PM
  #176
flyboy91
Default RE: New Krill Spark Evo I- Build Thread.....
The spinner on the Evo is 80mm
Andrew
Old 09-04-2011, 07:52 PM
  #177
rgreen24
rgreen24's Avatar
Dave, that a great way to rear mount the motor. Did it add much weight doing it that way. I have Himax 210 that needs a home, may have to borrow that way of mounting it to the Evo1. now if I can get Todd Schmidt to finish my Mystic for me I should be all set for next year
Old 09-05-2011, 04:16 AM
  #178
rgreen24
rgreen24's Avatar
Thanks Andrew
Old 09-05-2011, 07:47 AM
  #179
Dsnow
The mounting is slightly more than a firewall only, the carbon plate can be reduced from what's shown to an X shape and the 1/4" lite ply can be reduced also to save some weight.
Old 09-05-2011, 08:02 AM
  #180
mups53
My Feedback: (41)
Robert if you take a look at Ron's Impact that I sold him and Dave built it uses that system. Mike
Old 09-05-2011, 11:04 AM
  #181
Dsnow
I was asked in a pm for the firewall template but cannot find it, but here are several pictures of how I make formers and a PDF of the carbon plate. I used two layers of 1/16" carbon plate epoxied together to make the X plate that mounts to the motor and firewall. The temporary formers are glued together from small pieces of 1/8" or 1/16" balsa, after the general shape is made this can be traced to make a slightly oversized former that should fit with some sanding. I hope this helps.
Dave Snow
File Type: pdf
Old 09-05-2011, 11:11 AM
  #182
wagen017
that is really cool Dave, thanks for sharing!
Volkert
Old 09-05-2011, 11:58 AM
  #183
woodie
woodie's Avatar
Just finished the firewall CAD drawing and CNC cut for the firewall in my Spark Evo. I am using a Himax 6330-210 (same firewall dimensions as Pletty 30-10). The nose ring is large enough for the motor to slide in from the front. Firewall is 1/8" end grain balsa/carbon laminate. See pix below.
My firewall is set to add about a degree of right thrust and half degree of downthrust. My Evo has no right or down in the nose ring relative to the wing/steb setup.
Don
ID:	1658613   Click image for larger version
Old 09-05-2011, 02:51 PM
  #184
rgreen24
rgreen24's Avatar
Woodie any chance you can send me the CAD of that firewall. I will be running a similar set up
Old 09-05-2011, 04:28 PM
  #185
woodie
woodie's Avatar
Here is a file (dxf) for the Evo firewall. You will need to rename it from .txt to .dxf after you down load it. It is drawn slightly oversize on the outside dimensions to allow final fit/taper, etc.
Woodie
File Type: txt
Old 09-05-2011, 05:44 PM
  #186
rgreen24
rgreen24's Avatar
Thanks for the additional info As well Mike
Old 09-06-2011, 07:12 AM
  #187
tschmidt
ORIGINAL: rgreen24
We'll get you taken care of Robert!! Starting to round up materials !!
Todd
Old 09-06-2011, 12:12 PM
  #188
rgreen24
rgreen24's Avatar
Todd, I want you to fly as much as possible right now. You can work on the bird when the weather gets cold. See you in Fort Scott
Old 09-14-2011, 07:47 AM
  #189
underwoodsteve
hi guys,
what size wheels as my new bee , did not come with any ..............................oh but it did have a tail wheel......
rgds
steve
Old 09-14-2011, 07:56 AM
  #190
jon bruml
i found 2 and 1/2 inch works fine you could even go to 2 and 3/4
Old 09-14-2011, 07:59 AM
  #191
underwoodsteve
many thanks,
has any one got any pics of canopy fixing please...
regards
steve
Old 09-19-2011, 05:13 PM
  #192
rgreen24
rgreen24's Avatar
Does the Spark come with the incidence set? if not are you using the canopy area to zero?
thanks,
Old 09-19-2011, 07:48 PM
  #193
Jason Arnold
Jason Arnold's Avatar
On the Spark Dynamic there are dimples on the fuse side to mark the wing zero point. I assume the EVO has the same thing. The stab and motor can be referenced from this point.
Regards,
Jason.
Old 09-19-2011, 07:52 PM
  #194
rgreen24
rgreen24's Avatar
Thanks Jason
Old 09-27-2011, 10:31 AM
  #195
wagen017
ORIGINAL: Aussie_Knife_Edge
There has been limited talk about the new Spark EVO and how it performs compared to the Spark Dynamic.
So, what's the verdict?
Is it better than the Spark Dynamic?
Are there any weaknesses in the design or construction?
Cheers,
Jason.
I still feel this question was not really answered. I am very much looking for this feedback. I found the Dynamic a great airplane with fantastic snaps and great flying. I am thinking about buying another one but the Evo is beautiful as well. However, it is the flying that is most important in the end. No plane is perfect of course so some honest feedback would be great.
Volkert
Old 10-16-2011, 03:46 PM
  #196
woodie
woodie's Avatar
Quick question about the rudder horn location on the Spark Evo. All the pictures I see show the rudder horn about half way up the rudder. There is a half rib in that location but no block. There is a block in the bottom of the rudder which seems a strange place to put the horn, gets a little crowded down there with elevator linkage, tail wheel, etc.
Those of you that have built the Evo, where did you put the rudder horns? If you put them near the center of the rudder vertically, did you add a block somehow?
thanks
Woodie
Old 10-22-2011, 11:26 AM
  #197
underwoodsteve
hi woody,
i mounted my horn on the centre rib as yousaid earlier i added some small carbon inserts when iput the horns in, i will post pics of my build if you
like as there is very little info on installation etc , my modelwas in white ,now painted ! ( 50 hours) so the model is of to be clear coated monday.
regards
steve
Old 10-22-2011, 11:41 AM
  #198
woodie
woodie's Avatar
thanks Steve, would like to see your installation pix
Woodie
Old 10-23-2011, 06:24 AM
  #199
MachLoop
MachLoop's Avatar
ORIGINAL: underwoodsteve
i will post pics of my build if youlike as there is very little info on installation etc ,
steve
Steve,
Yes. Please post pics of your build and the final assembly.
Old 10-23-2011, 09:59 AM
  #200
underwoodsteve
hi guys few pics,
ant questions please ask.
regards
steve
ID:	1677854   Click image for larger version
ID:	1677855   Click image for larger version
ID:	1677856   Click image for larger version
