Electric Pattern Aircraft Discuss epowered pattern aircraft in this forum
jeti controller
Old 05-11-2011, 02:23 PM
Jeff-RCU
Default jeti controller
One more question! I am using a 70 Opto plus Jeti controller for my Miss Wind with a Turnigy 50-65 motor (380 KV). A couple of years ago I used this in edf application very successfully. I do have the Jeti Programming card. It only has 5 options (besides battery type):
High and low cut off voltage, Timing (low and high), Brake (on or off), Throttle curve (linear or logarith), Cut Off type (hard or slow down).
I assume the new controllers have more options, what is the best way to set this up?
Old 05-11-2011, 02:59 PM
OhD
Default RE: jeti controller
I would set low cutoff voltage. You don't want to depend on it though, to tell you when to land. You want to land long before it gets anywhere near low voltage.
Set the timing to high for outrunners.
Brake off.
Throttle curve linear. Use the throttle curve in the transmitter to get what you want.
Jim O
