Go Back  RCU Forums > Electric Aircraft Universe > Electric Pattern Aircraft
 New composit model CONTRAST >
Electric Pattern Aircraft Discuss epowered pattern aircraft in this forum
Old 08-06-2014 | 10:04 AM
ltc
What is the white object attached to the bottom of the fuselage in the first picture?
Old 08-06-2014 | 11:26 PM
here for additional Dave design
Old 08-07-2014 | 04:55 AM
A trophy from winning a event.
Old 10-22-2014 | 11:38 AM
tom.laird's Avatar
Hi,
I would appreciate some views on the correct carbon prop to use with this model. I will be using a Q80 11S and I am thinking about a carbon prop to go with it. However at carbon prop prices I do not want to make the wrong choice.
thanks
Tom
Old 10-22-2014 | 11:42 AM
I have 1170 flights with a pletty advance using a pt model 20.5#14 versión 1 with the q 80 11 i would say this would work good .
Old 10-22-2014 | 11:59 AM
  #31
tom.laird's Avatar
Hi Matt,
Thanks for this.
br
tom
Old 10-22-2014 | 09:54 PM
  #32
Hallo, from the first day of November CONTRAST LT airplane models can be purchased at the F3A Unlimited
Old 10-22-2014 | 10:36 PM
  #33
Congratulations Algis this is a big move for your company. Mike Muler with f3a unlimited is a wonderful man to do business with. Great Job !
Old 10-22-2014 | 11:58 PM
  #34
I know Matt, thank you very much
Old 10-26-2014 | 04:37 AM
  #35
I notice some of them have a canaliser and some do not? Which version is better?
Old 10-26-2014 | 07:26 AM
  #36
kanalizer designed so that it can be removed and can fly without kanalize, I the fly without kanalizer
Old 11-02-2014 | 01:13 PM
  #37
Interested in hearing more about this plane. How does one set up the inboard ailerons? Are they optional?
Old 11-02-2014 | 06:09 PM
  #38
The split ailarons are optional. I would only recommend them to a FAI pilot.you program like flapailarons .there are used for control In rolling maneuvers.
Old 11-02-2014 | 09:33 PM
  #39
Optional, how.? Are they already cut out and hinged? If you don't want them do they stay in a fixed neutral position or do they attach to the main ailerons and move with them? Thanks. Since I'm flying intermediate, they won't help me.
Thanks.
Old 11-02-2014 | 11:41 PM
  #40
Additional flap-eleron as no standard. They can be ordered separately. Can work as air brake as flap or with ailerons.
Old 11-03-2014 | 04:14 AM
  #41
No they are add in the build process. These planes are built to order they take around 3 to 4 weeks. Unless you are buying from f3a unlimited there planes are built with only a single aliaron. This is a solid plane and the best value in the market. For the lower clases because it is strong and can take the mistakes made at that level.
Old 11-03-2014 | 01:40 PM
  #42
tom.laird's Avatar
Originally Posted by griff7166
I have looked at every thing and how complete it is. And its quality is right there with oxia. Just awesome.
I will be post weights and pics of the build today and tomorrow. Thank so much Algis
I am very happy with the craftsmanship. I have it all together and will be making test flight the weekend.The weight of
my plan is 10.7 lbs. this is the set I am using.
e .
Hi,
According to one of the on-line converters, 10.7 LB equates to 4853 gram so looks nicely under the 5kg. Add 45grams for a Q80 instead of the Pletty and still under 5Kg.
cheers
Tom
Old 11-03-2014 | 04:14 PM
  #43
Hi Matt.. If I get one, I'd most likely order it from F3AUnlimited... so I guess the split ailerons are a non-issue, which is fine. I don't think I want them. I also see you are team JETI... I fly with a DS-16, and would want to use a speed controller with the integrated telemetry from JETI. Which one are you using in this model?
Old 12-08-2014 | 01:22 PM
  #44
Just ordered one :-)
Old 12-08-2014 | 02:13 PM
  #45
I am sorry for the delay back to you . I use a mezon lite and it works great. Use a 450 millamp Lipo with the bcu. And you will not have to worry about if it will drive your servos I used all hv Jr servos with no issues.
Old 12-08-2014 | 04:05 PM
  #46
Matt, no problem with delay.. Thanks for the info. I went with the Pletty advance motor, JETI Mezon 95 Opto, JR hv servos, 900 mAh receiver 2s Lipo battery. Not sure what you mean by bcu here. I'm unfamiliar with that one.
Old 12-08-2014 | 04:21 PM
  #47
The mezon has a battery control unit (bcu) are better yet it will provide power from your flight packs so a small receiver pack like a 400 mil can be used and you will only have to charge it every once and awhile
Old 12-08-2014 | 07:04 PM
  #48
ltc
I'm going to guess he is referring to the ESC's BEC (battery eliminator circuit)..
Old 12-08-2014 | 07:18 PM
  #49
Yes, your right a bec not a bcu got my terms crossed a bcu is the start battery in a stinger missile .always get those crossed... Just kidding thanks for cleaning that up.
Old 12-08-2014 | 09:09 PM
  #50
Matt.. I'd love any tips and pointers to getting this plane set up when I receive it. Thanks. How long have you been flying this plane?
