Mislabelled packs?
Hi guys,
I bought a new set of 5s 5000mah Zippy packs from HK and wonder if they've been mislabelled? Two things stand out...they're heavier than my other 5s packs (1200-1270grams), at 1360grams, and they're also fatter (wider). I'm wondering if maybe they're actually higher capacity than 5000's?
Don't know if this means anything, but after I charged them the first time I tried to break them in with gentle running on the plane (about quarter throttle only for 6:30 minutes). Then when I went to charge a second time to storage charge I couldn't! Kept getting "bad S count" on my Cellpro. I was able to use the 0.1A charge setting and saw it was at 45% capacity but the cell voltages still read 4.0volts (also all cell voltages were almost the same).
Any thoughts?
Cheers,
Ken
Any thoughts?
Cheers,
Ken
The 'bad cell count' could be an indication of a bad connector or connection with the balance leads. It does sound like the packs may be mislabeled. Contact HK services, there have been a few reports of the wrong labels on packs. I bought 3 small packs for a foamy this spring and one of them was the wrong size. Label was wrong. They fixed the problem.
Woodie
Woodie
Quote
Any thoughts?
Cheers,
Ken
Ken, I had the same thing happen to one of my packs (Zippy Compact 25C-5000) I gently broke it in at 1/4 trottle for 7 minutes and I got the same thing( The out of the box capacity was 24% and the other were 50% or above). I am using them as practice packs anyway and for now local contest packs. The other 4 packs are still doing fine and the Ohm's are still low after 30 flights 1.8 low to 3.1 on the high and thats consistent with all the packs. I have worked a few of them very hard testing and setting up ESC lately.
Bill
Any thoughts?
Cheers,
Ken
Bill
