Go Back  RCU Forums > RC Helicopters > Electric RC Helis
 GY 401 problem >
GY 401 problem
Electric RC Helis Discuss electric rc heli's such as the Piccolo, Logo 10, Logo 20, Hornet, Eco.
GY 401 problem
Old 05-07-2006 | 06:29 PM
Default GY 401 problem
Ok,
I'm just stumped here I have a 401 and using a HS-65 with it. When not is HH mode the helicopter hovers has no problem what so ever. If I switch to HH mode the gyro starts putting input into the servo. Here is how it is set up: My servo arm is short as I can get it ( I don't have wag in NoN HH mode or HH mode) I've tried different gains from 10 - 80 percent. If I have any gain on it the servo auto goes full right swing very slowly but If I correct it as soon as I stop putting input it goes full right again. It's as if something is telling it that is giving it input. I never had this problem until the other day after about 3 good flights I decided I would do a one over and tightened a few things up nothing major or even with the flight controls. Now today I go out and do some flying and I can't get the tail to stop drifting. Once again it only drifts in HH mode. I don't use any sub trims on my rudder so switching from NoN HH mode to HH mode shouldn't be any big deal, doing this with rotors stopped and the helicopter not moving. Any input would help, I'm still flying but do like the HH mode for just hovering around and building my skills up.
Old 05-07-2006 | 07:53 PM
Default RE: GY 401 problem
Ok I think I got it fix, for some reason it was only happening when I had the motor plugged in. So from there I did a bunch of different things. In the long run what seemed to have fixed the problem was that I had -5 Throttle in my Throttle off switch I put it to just zero and it seems to have made the problem go away. BTW I am using a DX6 so maybe this only affects this TX/RX do to the way it takes few extra seconds for the two to communicate and the gyro was thinking that there was some sorta REV mixing going on because one second it seen Zero throttle and the next it had -5.
