FUNJET
I am not trying to fight ya on this.
take you video here and ask larry to doppler it http://www.wattflyer.com/forums/showthread.php?t=26852
and send me your link and I'll take my 153 Quick there
I do not believe that you are trying to fight me. I believe that you are just trying to verify (from your perspective) what the video claims. I also believe that if you now go to that link, you will see the real-time timeline that happened after I read your comment from U-TUBE.
NICEwebpage you got there !!!!!!!
holy crap like I dont no how you did it that's one fast styiker you got man I guess I am all wrong on that but I still dont beleave it WOW
carefull with that thing that one nice set up you got and that's some crazy reforcments so my hat is off to ya
so I have posted on all three site in one way or another my apology so you can go brush your teeth
It's cool that you can do the doppler I tryed and cant get it to work for methe only thing I clam to know is how to build from my head with no plansso thanks for you comment on my youtube sight
so what kinds watts is it pulling
First things first: That video bites.
It shows a Stryker launching but then either the Enterprise or Klingon Bird of Prey (not surewhich)zooms by at Warp factor 5.2 (at least).
2nd and more importantly: I know the power systems in that Stryker and I know it has previously been flown faster with different setup and that his next setup (whichMoparmyway already has) will have a significant power increase as compared to the set up in video and will fly faster.
Isuggest no info is given on this setup, and when next video will be ready (hopefully in 2-3 weeks) that it gets posted along with full specs. Since you have 150A Eagle tree data logger along with many sensors on board that you can post a few nice in flight charts of various parameters, a much better video for Doppler/evidence and as much details of your power system as you wish to share.
I expect well above 150 MPH by most people's analysis.
Now back to the Funjet programming.
Gryphon
Anyway, I will get another video that is set-up better within a few weeks. I am a little occupied right now with a few other projects.
__________________________________________________ __________________
Gryphon,
I aint too sure thatI could post any numbers anyway, I dont even remember which setup it was ??????????????
I have good news I got my move done and a new shop set up. I all most got my molds done for my carbon fiber funjet hopefully late summer I'll have the first on done and flying
I'll keep them comeing
plaster then I'll roll 4 to 5 coats of epoxy and then bondo and paint it.That hold up nicely plus I can putheat cureand not lose the shape of the mold butkinda suck to move it around.There not to bad around 60 pounds.
here soon I'll get some pics my computer crashed last night and today
I have some servo covers made but they did not come out the best the mold is to small to work the carbon and Kevlar fabric and then bagging it. So I need to make a new mold for those parts
I think you should turn it into a plug mold they dont make that one any more for what I heard
I do still have a couple mico jet that I will mold after the funjet is done and flying
If you want some good Ideas on mold makeing out of fiber glass have a look at this guys videos I will be doing them that way from now onhttp://www.youtube.com/user/hornitpilotthere are 33 videos of how to plus the plane is bad - it's a 20 footlong B1B with 4 45 pound thrust jets man it is sweet I have a video dose not show as mush as his. It's on my youtube page look for The Birth Of a B1B http://www.youtube.com/user/b1bman
Great Planes ElectriFly LiPo 11.1V 3350mAh 25C Power Sr
theb1bman ,
You do great work. I am very impressed.
Looks like you may be able make a DREAM Funjet airframe.
On the high side of battery packs, the following have been previously used in Funjets by various people:
4S-5000, 5S-3700, 6S-3300
5S-3850 and 5S-5000 are in the works too.
No doubt low speed flying capabilities go out the window and launching them takes some practice.
But that is how 160-175+MPHcan be achieved.
My new Custom MEGA16/35/1.5 was tested to near 2500W on 5S-5000, I am 100% sure it can lay down above 175 MPHpasses even though it is 28mm motor, 56.5mm long, 160 grams, 5mm shaft.<o></o>
<o></o>
<o></o>
500W per cell….yes<o></o>
<o></o>
<o></o>
Below is screen shot of APC Pylon 6.5X6.5 on TP 4S-5000 30C at 25% discharged pack (ground testing).Other pic shows the custom motor next to regular 480 sized 110 gram MEGA16/25/2 2650KV3.2mm shaft.
<o></o>
Note: Given Funjet’s limited cooling airflow to the motor, there would have to be some throttle management.
<o></o>
<o></o>
Gryphon
ya those megas are real nice I lost mine with the trust vectoring one I set up some thing came loss an it shot out the back end in a spin.
never to be found
I'll get some more pic up to night got to get them off the cam
I've read pretty much this entire thread. Good stuff. I used to chat with Gryphon and CP on the Stryker threads. I wore out my Stryker and got into a 50CC electric Extra for a while. 2 6S 5000 packs at a 100 amps is some juice
Anyways, here is what I have left over from my Stryker. What would this do in a Funjet?
Mega 16/25/3
CC 45
4S 2200 packs
HS 82 MG servos
In my Stryker I think I remember getting about 95 mph at 40ish amps on a 7x7 apc. The verticle was great and overall flying was enjoyable. For that speed range I liked the low amps and thrust. I thought about building another but want to try something different.
I also previously ran an HET 2w-25 on a 6x4 but the amps were way higher. The speed was a little better and the verticle was awesome but it was crying out for larger packs.
Are my Mega and servos to heavy for the Funjet? I would like decent flying with a top speed of 110 to 120 mph. I could sell the mega and go to a higher kv if needed but I don't want to waste money if I don't have to. If I wanted to do 170 I would just buy a ducted fan jet.
I am also looking for the mods I would have to do to fly in this speed range.
Thx
Rino
