Ebay Rafale...?
#101
A Free motor and ESC.! thats a pretty good deal Id say. So what were your flight times like. I managed to get 8 and 9 min flights! The battery was really warm but not melting hot. My first light was 6min and it took 1450mah to charge. That was with the 2200 lipo and the A123 had a failure at about 6min when one cell crapped out. Im going to try and gouge more of the back wall out.In fact I had concidered cut it right into the intake steam so as to pull the hot air out of the Battery compartment. Going to need an intake hole though or the suction could colapse the canopy. I cant complain of how it handled but I think I can do better. Mind you I was flying in 30klm+ winds. Hey Joe! I now know what its like to fly backwards in a high Alpha now.lol I have some video now but that could take a while for me to upload it.
This plane is just WAY to fun!!!!
Trev
Trev
#102
IA
I dont really want to push it for flight times right now Just take it up for 4 minutes tops maybe 5 its like 90 degrees here now with opressive humidity. I will test it for longer flight times when the weather cools. I think it will be about what you said after 4 or 5 the Li Po was just starting to warm up. This new motor sounds sweet compared to the ragedy vibration prone motor that came on it. I guess the airspeed is the same. He said this motor was off an FA18 Hornet. I guess Im gonna find out for sure cause this will be the next motor after this one. unless there is something slightly hotter. I dont think I would want a really fast motor on this thing its hard to see at a distance. Our runway sucks so I keep running off the edge cause its so narrow and going into the grass which is ok but the front gear bends back a little most of the time.
HEY is this your plane Canopy picture Vettster ? I Tried to fly my 2100 Li po and couldnt even get off the ground. and mine is further back than this
Heres the video of my crappy landing. http://www.youtube.com/watch?v=Nikz5hUCIIU
#103
My Feedback: (59)
VA
Vet,
The harder it blows the more fun it is to fly! Though I was going to get a chance to fly in some 12 to 15 knot winds today, but go figure, mother nature keep them down around 10..[
Joey
Joey
#105
IA
Ok so much for my earlier post about not having trouble getting off the ground. today I ran off the end of the runway twice trying to get up. Reason NO WIND. I always had wind to take off into before today. Man I had to use almost every inch of the runway and got it off the 3rd time. It lands beautiful with no wind. Floats Down like the Space Shuttle.
#106
Wellp! No more flying for me till my replacment fuesalage gets here[
] I had just received my wings useing my P-51 Mustang at my feild and minutes later everyone wanted to see the jet fly. No problem, I put on a great show using the 2200mah batt and it was windier than ever. All was good for about 8 min till the power started to drop quickly and with the wind so stong I couldnt bring it out of the loop fast enough and drove it straight into the end of the feild. The battery did most of the damage as it ripped its way through the entire front section. I hope to have it back to gether for our "Rafale Rally" Joe. By the way that should be around Aug 23
fossoman! I am now hand launching this thing cause it has so much power, But! with the 2200mah in it I have to use the Bungee. I tried hand laucnhing it and it hit the deck like dead duck. With the extra weight your going to need an extra boost. Why dont you attach a rocket!lol hum...............
Hey Fossoman! I just watched your video and now I know why your under powered. They gave you a JohnDear motor!!.
Nice vid though
] I had just received my wings useing my P-51 Mustang at my feild and minutes later everyone wanted to see the jet fly. No problem, I put on a great show using the 2200mah batt and it was windier than ever. All was good for about 8 min till the power started to drop quickly and with the wind so stong I couldnt bring it out of the loop fast enough and drove it straight into the end of the feild. The battery did most of the damage as it ripped its way through the entire front section. I hope to have it back to gether for our "Rafale Rally" Joe. By the way that should be around Aug 23fossoman! I am now hand launching this thing cause it has so much power, But! with the 2200mah in it I have to use the Bungee. I tried hand laucnhing it and it hit the deck like dead duck. With the extra weight your going to need an extra boost. Why dont you attach a rocket!lol hum...............
Nice vid though
#107
My Feedback: (59)
VA
Fossman,
Make a 1/2 to 3/4 inch longer nose strut. This will make your takeoffs a breeze, probably under 25ft. I have a guy here that bought one from me and he does half throttle takeoffs! His just floats off the runway.
Vet,
Sorry to hear about your crash[
] If you dont have it fixed, you can fly mine.
Joey
Vet,
] If you dont have it fixed, you can fly mine.Joey
#108
ORIGINAL: SoppyJoe
Vet,
Joey
Vet,
Thanks buddy, BUt I sure hope to be flying mine.
So guys. This means a whole new paint job. What would you like to see this time.
Trev
#110
IA
hey what happened to everybody lets keep this thread alive. Oh YEah I crashed My Rafale yesterday Saturday. SMASHED IT UP. Tore the nose off it. Pancaked it sending the battery flying through the bottom of it. I lined up the front again and EXPANDO FOAM to the rescue had to fill in the parts that were egshelled too bad to reconstruct. Totally pilot error no fault of the plane. Just got too far away to see which way was which.
#111
Sorry to hear of your bad luck Fossman
Im missing every second I dont have the RAf. I bought the Kyosho Jet Vision with the swing wings so I would have a jet to fly while my parts for the RAF are on the way. Whell! this thing is SO!!! underpowered, its just the complete opposite of the RAF Ive crashed it twice already and Ive only flown it 4 times. The swing wing is neat but now Ive just had to order a whole new EDF unit with a better motor just to give it a fighting chance. MAN! do I miss the RAF.
#112
My Feedback: (59)
VA
ORIGINAL: fossoman
hey what happened to everybody lets keep this thread alive. Oh YEah I crashed My Rafale yesterday Saturday. SMASHED IT UP. Tore the nose off it. Pancaked it sending the battery flying through the bottom of it. I lined up the front again and EXPANDO FOAM to the rescue had to fill in the parts that were egshelled too bad to reconstruct. Totally pilot error no fault of the plane. Just got to far away to see which way was which.
]Joey
#114
FL
Hay joe. I can't wait to fly the rafale my 70mm f-20 is wright behind it and i have a cermark mb339 with a os 91 with a bvm fan I'm going to have alot of fun when the cool wheather comes here lol
#115
My Feedback: (59)
VA
ORIGINAL: vettster
Hows that phantom comming Joe. have you flown it yet.
GetMore, your gonna love the Rafale, its just blast to fly. Have you flown the cermark yet?
Joey
#116
FL
Joey no I haven't yet but it has flown before. I did some changes to it and now it is ready to fly.
I am waiting on some cooler wheather to go fly it. I have to drive 30 miles to fly that bird and when I go Im going to take all my jet stuff and make a hole day of it. good luck with the phantom I love that jet
I might have to add that to my hanger. lol
#118
well at least your flying again. Im still waiting for parts
on the good side of the news.....my 4800klv outrunner motor just showed up, WoooHoooo
check out this link : http://www.rcgroups.com/forums/showthread.php?t=871698
look at what buddies up to on page 4
#119
IA
Let me know how that works with the motor upgrade. You lookin to rip the wings off it. whats the stock motor 1800 KV tops. would be cool to go unlimited vertical. But my problem is the wings are so short its hard to see which way it is facing at a distance. Hence my first major crash. I stay a little closer now.
Happy flying love this planes looks and even with my lack of good piloting skills Im having a blast with it.
#120
Actually I think the stock motor is 4300kv I know this cause when I replaced it with the Turnigey 4040 it just didnt go like it did before and I think i seen that purple motor somewere before with the specs.
Hey! any landing without braking things off is a good one! and great tunes on your vid.
Id be happy if the fues would get here. its been a while. But other stuff I ordered is starting to show up, so maybe it wont be long now.
#121
IA
Vettster Hey fly a little mellower next time will ya. One thing that didnt hurt mine was I filled up all that hollow space where the front wheel is you know behind it All that is open space and structurally weak just thin foam. I filled it with expando Foam the Hard setting variety. took the wires and put them up high. Heres a pic./
Thinking of filling the nose up too.
#122
Thats another great Idea with the exspando foam. Way to go! Infact since I dont even use the nose gear I could remove the servo and mount it in the back then fill the front fues with Exspando. The servo will add weight to the back wear its need to counter the 2200mah battery. Good thinking Fossman.
#123
IA
hey what motor and esc combo did you end up with. Will it go unlimited vertical now? I like mine ok for now but extra power would be nice after I get more comfortable with it.
#124
ORIGINAL: fossoman
#125
IA
VETTSTER Hobby Lobby is right here in TN Where Im at now. Ive been there I bought mine directly from there its a 35 minute drive from my house. The problem is not that they dont want to sell you one. They Dont have ANY. Theyve been waiting for the parts to be shipped from china. They are way overdue They had a few and sold out but they never got the Fuselages in yet only little stuff extra Li POs Landing gear ETC. They had some of the parts in stock but sold out right away. But they havent got the fuselages yet. This plane is in popular demand and hobby lobby isnt the only one selling them. I think most of the stuff is going to other countries. They had set an arrival date for each of the parts and some were in stock now all parts say Available Soon. I Keep checking every week. Forget about the phone they dont answer the phone worth a crap. Your very lucky if you can get someone to talk to you. But I will say they did me right but I was face to face with them. Which is why I got the esc and motor.
I will let you know the minute I find out anything cause I need a fuselage too.
HERE is the link to Famous Electronic Tech site or whatever they call themselves http://www.fmsmodel.com/Engdy.asp?En...an%20Airplanes
