Shindaiwa four stroke
Old 11-25-2003 | 01:05 AM
Antique's Avatar
Default Shindaiwa four stroke
Just converted a Shindaiwa four stroke trimmer engine with my CD ignition.....It weighs 3 1/2 lbs, has a nice flat back to put a plate on, idles at 1400..I'm running a Mejzlik 18-6 but can't tach it in the shop with fluorescent lights, the 1400 reading was with the lights out and using a flashlight through the prop...It is a very easy conversion, there is no oil tank..Fuel mix is 50-1 just like a 2 stroke...I'll put a Walbro WA125 on it tomorrow so there will be some way to adjust the high end...Looks like a WINNER...Same technology as a YS...
Old 11-25-2003 | 04:12 AM
ZAGNUT's Avatar
Default RE: Shindaiwa four stroke
COOL!! been waiting a long time to see one of these converted, always seemed to me like it would a make much better airplane engine than the others that have oil sumps and such.
bet it would sound awesome with just a short header pipe for the exhaust...
dave
Old 11-25-2003 | 09:15 AM
Antique's Avatar
Or a nice little reverse cone megaphone.
The Stihl four max looks like the same design, maybe someone will try on of those...We have s Stihl dealer here in Flagstaff, maybe I can con him out of a powerhead without having to buy the rest of the parts....These high end weedeaters are pricey.....
Old 11-25-2003 | 09:29 AM
jerry dotson's Avatar
What is the displacement? I am keenly interested...love 4 stroke gasoline. I have a Honda GX31 on a Fleet biplane for 3 years. It is just barely enough. Flies real scale and sounds good. I run a 18-8 Zinger turns 6800. Turns a 18-6 7500 but seems to have better performance with the 18-8. Sounds GOOD!
Old 11-25-2003 | 09:38 AM
Antique's Avatar
Please keep us posted with the results of your testing with this engine. I'd love to get a 4 stroke with no sump. What's the displacement, size compared to a G-26 ? Any chance of getting pics ?
Old 11-25-2003 | 09:51 AM
Antique's Avatar
24.5cc, 8000 rpm, 1.15HP
Old 11-25-2003 | 10:52 AM
Volfy's Avatar
My Feedback: (23)
One advantage of this 4stroke is that it can take a common WA or WT Walbro carb. Some of the other 4strokes (e.g. Ryobi) uses a different carb mount such that you couldn't easily slap on a larger venturi carb, or just one with adjustable H and L needles.
Old 11-25-2003 | 10:59 AM
Antique's Avatar
True, but when you bolt a WA or WT on the stock insulator the pulse hole doesn't line up and the carb shaft is at a funny angle..There's no room in the stock insulator block to re reroute the pulse hole.I cut the stock block down a little and made another adaptor so that the carb shaft is parallel to the cylinder..the throttle will connect to the carb shaft and will be straight back and forth, no bell cranks....
Old 11-25-2003 | 04:53 PM
Volfy's Avatar
My Feedback: (23)
Good idea, Ralph. What did you use for the insulator material? G-10 boards?
Old 11-25-2003 | 05:28 PM
Antique's Avatar
3/8 G10...A new fitting in the back of the carb and another in the G10 takes care of the pulse..The hole in the stock block is really small, maybe opening it up will let the engine breathe better..A 20-5 PK wide blade prop turns about 5500 and idles at 1200..Way too much prop, but sure sounds nice....
Old 11-30-2003 | 11:43 PM
Ralf: I/we sure would like to see a photo of the converted shindaiwa. Right folks??? Thanks Capt,n john
Old 12-04-2003 | 04:34 PM
what is g-10 board????
Old 12-04-2003 | 05:20 PM
Antique's Avatar
Epoxy board material, sold by industrial supply houses, comes in all shapes and thicknesses...3/8 thick costs about $22 a square foot...Can be drilled, milled, tapped, and other wise machined....
Old 12-04-2003 | 07:51 PM
Hellow...anyone got a photo of one of these Shindaiwa engines converted. Please Thanks Capt,n
Old 12-04-2003 | 08:42 PM
Antique's Avatar
Lost my camera....
Old 12-04-2003 | 09:27 PM
Ralf: How is the weather out there now for flying? Do you have snow yet. It is cold here, but not much snow yet. I may take a trip out your way this summer. I think I can find you ...so you better be good!!! Ha. Take care Capt,n .. West lower Mich
Old 12-08-2003 | 12:36 AM
Antique's Avatar
Hey Cap...No snow yet, maybe tonight, we sure could use the moisture...
The Shindaiwa runs great, but a larger carb, WA167, doesn't seem to work right...The original carb is a 9mm WYL with a fixed high speed jet, and the WA167 acts weird on the engine..The reed under the carb is pretty small, but the way its made I was not about to enlarge ithe intake hole without a spare manifold in case something happened (it's not my engine)..The WYK carbs are larger, 10.5mm, and have and adjustable high speed needle...I think I'll try to get a spare manifold and reed and make the hole bigger, with a WYK carb...I can run a 20-5 prop but have to almost close off the intake to get the mixture right..Could be that the intake valve and port are too small to make any more power..The head is not removeable, like a Saito, so any port work would be pretty hard...
Right not the Mejzlik 18-6 looks like the best prop with the fixed jet carb, with the 20-5 next...
The reed is metal and pretty stiff, but maybe with this type engine, since the mixture goes through an intake valve, it isn't a factor like a normal 2 stroke...
Maybe a little dinky Walbro would work,something around the 7mm size, the engine doesn't seem to need much air....
Old 12-08-2003 | 08:57 AM
Antique's Avatar
Interesting stuff Ralph, please keep us posted.
Old 12-08-2003 | 09:17 PM
RCIGN-1 That sure sounds like a fun experiment. I have been helping my cousin on a monster truck. Lot to learn on those critters!!! One of these days I got to get back to my project engines. Ha!! Take Care Capt,n
Old 12-15-2003 | 09:25 PM
What is the latest on the Ryobi project? Cap,n
Old 12-15-2003 | 10:19 PM
Antique's Avatar
Hello Cap,n..The Ryobi was a Shindaiwa...Best rpm was about 7000 with a Mejzlik 18-6..I sent it back to the owner with a carb adapter so he could try some different carbs on it..He has a small engine shop in Hawaii so he has lots of carbs to try...soon as he gets back to me with some results I'll post them here...
Old 12-16-2003 | 11:47 AM
Sorry about that mis-type....I probably should not be using this computer when I got the flue or whatever!!! I will get back when I feel better. Capt,n
Old 04-17-2004 | 09:00 AM
ORIGINAL: RCIGN1
Did you ever hear back from the guy with the Shindaiwa ? I would love to see some pics, to compare with my GX25
Old 04-17-2004 | 10:28 AM
Antique's Avatar
Nope...
Old 04-17-2004 | 04:47 PM
RCIGN1 Ralf...did you ever find that camera (post 15) ??? Whats new out your way? Take Care Capt,n
