conversion air filter??
Old 08-15-2005 | 01:03 AM
ETRNL's Avatar
Default conversion air filter??
i am hunting for a good solid engine to convert for a MT. all of the trimmer i found had choke plates and a cover but no air filter. i relize that a trimmer stays an average of 3 - 4 feet off the gorund away from the dirt. but i am planing on changing that to about 6 inches. so i am going to need a air fiter of some sort. long story short i am looking on advice of what to get or how to build an air filter for 2 stroke engines
thnx ETRNL
Old 08-15-2005 | 11:21 AM
My Feedback: (29)
Default RE: conversion air filter??
Hello,
What is an MT? The answer is to buy a straight style carb V-stack and slip a rubber hose over it with a hose clamp. connect the other end to the air filter of your choice. If a MT is large, you could us a good size from a motorcycle application or something to get low restriction and good filtration. Engine selection depends on your power needs. If you need a clutch, many trimmer engines will have that.
Dave
Old 08-15-2005 | 07:11 PM
ETRNL's Avatar
MT= Monster truck specifically TMaxx frame. as for the engine i need something that will zip around 18lbs like nothing.
if u have any suggestions please let me know. i am looking for a homelite but have no idea what make or model to get. i am ope to suggestions.
THNX for the advice
Old 08-16-2005 | 12:35 PM
Volfy's Avatar
My Feedback: (23)
You'd be better off going with a chainsaw engine, which will come with a gear already attached to the output shaft. You can use a chain to drive the rear axle. There is a guy here in Houston that builds custom MT using Poulan chainsaw engines. Very nice work but very expensive too.
With weedie engines, there is no convenient way to set up the output drive. I suppose you can cut a V-groove into an aftermarket "prop hub" and use a lawn mower drive belt, but maintaining the correct belt tension would be a problem unless you make the rear axle rigid (no suspension).
Old 08-16-2005 | 12:39 PM
Volfy's Avatar
My Feedback: (23)
Oh, forgot about the air filter. Best way I can think of is to first get a velocity stack ($8-10), then attach a lawnmower engine air filter to it. Many of the replacement air filter has a round inlet that might fit onto the typical VS with a little modification.
Old 08-16-2005 | 01:33 PM
Crusty's Avatar
All the trimmers I have seen already have an air filter...???????
Old 08-16-2005 | 06:45 PM
Isnt a T-max frame a little small for a gas engine? What size tires r you gonna use?
Old 08-16-2005 | 09:48 PM
ETRNL's Avatar
im going to use Moabs on 40 series rims.
and i am going to double the chassis width and use hub extenders to widen the track.
Old 08-17-2005 | 03:29 PM
Volfy's Avatar
My Feedback: (23)
ORIGINAL: tripp3d
The only one I know in that size is:
http://www.mecoa.com/compagnucci/index.htm
Otherwise, none of the conversion engines are small enough for a T-MAXX.
Old 08-17-2005 | 06:10 PM
ETRNL's Avatar
it going to look something like this.....
[img][/img]
ID:	311560   Click image for larger version
ID:	311561   Click image for larger version
ID:	311562   Click image for larger version
Old 08-18-2005 | 07:43 AM
That looks cool[8D] Are they as fast as the nitro cars?
Old 08-18-2005 | 08:05 PM
ETRNL's Avatar
well see for yourself...
thanks to Dr. Honda....
http://www.putfile.com/media.php?n=-Maxx-gasser-small
and this is with a new john deere engine before breakin....
