How to convert from Points
Old 10-21-2005 | 07:50 AM
My Feedback: (131)
Default How to convert from Points
I see alot of older motors out there with points ignition, is there a universal conversion kit out there, or not ??. The motor I'm actually looking at is out of a Poulan 361 chainsaw, 59cc with points.
Thanks, flyrc
Old 10-21-2005 | 08:38 AM
My Feedback: (29)
Default RE: How to convert from Points
Hi RC,
If you can pickup a more modern solidstate coil that will fit, it should work with your flywheel. You may want to go to CDI for a large engine due to kickback. Get one with syncro spark auto advance or use a heavyduty starter. They used to have a points eliminator kit at saw shops for about $15. You probaly have to get that big engine spinning at about 400rpm to start it.
Dave
Old 10-21-2005 | 01:49 PM
I used one of the points eliminator units on my Quadra 40 to cure a glitch problem. If I could fix the glitch another way and go back to the points I would. Without going to electronic ignition, the points type system was easier to start and idled lower. I wouldn't change unless there was a problem. My 3.7 Sachs has points, starts very easy and idles at 1300 rpm.
Old 10-21-2005 | 06:37 PM
My Feedback: (29)
ORIGINAL: bdtsr
Hi,
It sounds like another case of if it ain,t broke don't fix it. Solidstate can be hard to start.
Dave
Old 10-21-2005 | 08:41 PM
My Feedback: (131)
Hmm, so points may be a good thing?? The actual amount of run time on these engines is only a couple hours a year for most of us. If there are no other drawbacks,a new set of points should last for years.
Old 10-22-2005 | 07:45 AM
Antique's Avatar
I'm flying an old Kalt 22 (early G23) on the original points & condenser, runs great. Many many gallons of fuel have been thru this engine. This setup must be 30 years old.
