engine conversion
MI
w8ye
13'' long? ryobi? maybee I'm confused my ryobi from the back of the 2" mount to back of the spinner is 7-1\4"
r we talking about the same thing here?
MI
long shaft or short shaft engine? mines a short shaft with ch ignition hub. and a 2" wacker engines mount.
thats 7-1\4"to the back of the spinner . I got ryobi envy!
MI
kahn41
welcome back ,gasket kit try your local lawn mower repair shop or cut them yourself,thats what I do .takes a little time
but gasket material is cheap! or try http://www.outdoordistributors.com/ for gasket kit but, you shouldnt need one if your carefull
MI
kahn41
I have no way to take measurments like that sorry .
I can tell you I'm getting 7500 rpm's on 18x6 zinger brand new no breakin
on stock 2 needle carb with cdi ignition .SACCAL72 was 7700on mag ignition
with stock single needle carb two tanks through it, if I remember correctly .
the common recomendation is 14lbs plane(max) and 1000 sqr inches of wing min.
Well I am partial to Echo. Tons of power and not heavy. Plus I like the quality of the castings. Poulan would be another if it were me. Not that any others are not as good it's just that I have been partial to Echo and I have a lot of parts collected for them.
MI
kahn41
I am converting two ryobi at the moment and have a homelite 45cc I used to be able to get homelites
localy and cheep BigLots used to sell remanufactured equipment but now they have stopped.
any engine that you can get parts for will make things easier like anything harbor freight sells
ive noticed that BigLots has been selling polan recently so I may have to switch to those
also a good word to watch for is remanufactured=discount ,thats good usually.
another word to look for is "emission,or california compliant" translates for the most part to, save
your money theres no power here.
something else to consider is conversion parts availability hub mounts muffler mount etc.
in the inexpensive 31cc class ryobi stands alone, hard to beat.homelite, makes one, its new
havent seen much on it . suposed to be a homelite\ryobi hybrid, by parent company m.t.d.others are
chainsaws and they get more expensive.
MI
kahn
my ryobi's are ,one is going in a china models yak 54 the other is homeless for now my 45cc is in a scratch built edge 540 84inch wing
the yak is 72inch wing about 12lbs.
