Cloud Dancer 120
Old 02-28-2007 | 12:40 PM
sscherin's Avatar
Default Cloud Dancer 120
Anyone put a Ryobi 31cc in a 120 Cloud Dancer?
Old 03-01-2007 | 11:58 AM
Default RE: Cloud Dancer 120
Just finishing up one myself, going to put a 120 Saito in it. Think a Ryobi might be a bit heavy for it, maybe an echo or Weedeater Feather lite? Sure has a lot of wing area if you build it with the long wing. Put flaps on mine so I could land it, my CD 40 would float forever.
If you try it, let me know if it works, I have a Ryobi on the shelf waiting to go in something.
Steve
Old 03-01-2007 | 10:00 PM
What's the wing area on your Cloud Dancer? if its arround or greater than 1000 sq in go for it
Old 03-02-2007 | 08:21 AM
sscherin's Avatar
Yeah my CD 40 will float forever..
The 120 plans say 1230sq. in. with the short wing.
I have 3 gas motors I can convert.
18cc (I think it's a featherlite)
23cc Koritz
31cc Ryobi
Here's the info on the CD120 plans.
http://www.rcmmagazine.com/store/sto...jtSZ94ieI6T2I7
CLOUD DANCER 120
Our Price $18.50
by Fred Reese,
86" or 98" span, 1230 or 1350 sq. in., .90-1.8, 4-5 ch., built-up balsa and plywood, two sheets 34-3/4" x 69-1/4", 34-3/4" x 51-1/4",
Issue: RCM 1-96,
Old 03-02-2007 | 06:39 PM
I just saw the plans and I would put the Ryobi, it has ample wing area!!!!
I bet it will perform super with it.
Old 03-05-2007 | 08:33 PM
Looked at my CD 120 and compared the Ryobi, looked a bit big, seemed like the Echo would be more suited, but the rear mounted carb of the Ryobi would make a cleaner installation. Believe the Kioritz is the same thing as Zenoha. If you use the Ryobi consider moving the servos to the tail.
Steve
Old 03-05-2007 | 09:57 PM
Ralphbf's Avatar
My Feedback: (27)
The Toro 25 is lighter and more powerful than the Ryobi.
At least that is what Scott Ellington says.
Old 03-06-2007 | 09:07 AM
sscherin's Avatar
Thanks for the input..
I'll go ahead and order the plans.
Then we'll see what motor will fit best and what mods need to be made.
