Hard engine to start! Need help
Old 06-06-2007 | 12:21 AM
Default Hard engine to start! Need help
I have a 38 cc poulan converted. It has a mag on it with the points ignition. It is very hard to start. I dont want to by CH ignition. I have a newer engine that doesn't have points. Would this be easier to start? Any sugestions?[&o]
Old 06-06-2007 | 01:51 AM
Default RE: Hard engine to start! Need help
I didn't read far enough back on the ebgine conversion threads. I need to get a high toruqe starter.[sm=spinnyeyes.gif]
Old 06-06-2007 | 03:26 PM
Ralphbf's Avatar
My Feedback: (27)
If you go to your local small engine repair shop the will have a device that eleminates your points.
This will allow more spark at a lower RPM and should cost $25.00 or less.
I would start there.
Old 06-06-2007 | 03:29 PM
Ralphbf's Avatar
My Feedback: (27)
Sullivan makes a 12 or 24 volt Heavy Duty starter, I have one.
You will need 2 Garden Tractor batterys to power it correctly, about $20.00 each
Plus about $50.00 for the started new.
There are used ones out there.
Ralph
