Homelite starting
I have completed the conversion of a homelite 25cc and it started very easily within a couple of flicks by hand. I stopped it to adjust to the tickover and it would not start again, I seem to have a very weak spark and it only fires now and again when hand starting, can anyone help. Joe
It is the stock coil, what I can't understand is that it started first time without any problem and then refused to restart? very odd. Joe
make sure the air gap is close on the ignition, I use a business card placed between magnets and coil when I tighten down the bolts.
readjust the tickover back to prior setting. I give up, what is a tickover?
If the engine is old enough to have a seperate (steel) flywheel key then starting is best done with an electric starter. Mine will sometimes start by hand but not reliably. I have a later 30cc with the cast in key and it cranks very easily by hand. I think the explanation is that later flywheels have stronger magnets and the ignition module is taylored for easier starting.
Thanks for that planepounder, I bought the weedwacker new only a couple of months back and started the conversion within a week or so, I am using a starter now because it starts every time with one, although from cold it will start by hand?
I was having a problem with the idle speed being to high but in the interests of experimentation I took off the throttle butterfly which had two holes in it and replaced it with a home made one without holes, I can now set the idle at any speed I like. Joe
