Source for odd size bolts?
Old 01-04-2010 | 03:49 PM
jtisch's Avatar
Default Source for odd size bolts?
Anyone have leads for a source for unusual size bolts/ screws? I am looking for M5 x 1.25 panhead and am not having much luck.
Old 01-04-2010 | 03:52 PM
MajorTomski's Avatar
Default RE: Source for odd size bolts?
Have you tried an ACE hardware store?
Old 01-04-2010 | 04:15 PM
jtisch's Avatar
I've tried Ace, McClendon's and Tacoma Screw, plus E-bay and a Google search.
Old 01-04-2010 | 04:27 PM
Try True Value hardware stores. They have pull out bins of almost any type and size of metric and standard hardware. If you continue having problems, let me know and I will pick some up and mail them to you.
Sincerely,
Richard
Old 01-04-2010 | 07:55 PM
xx
Old 01-04-2010 | 07:57 PM
M5x1.25 is a very coarse thread. I couldn't find it even in Machinery's. Are you sure it is not a 20 pitch SAE? What is it from?
John
Old 01-04-2010 | 08:20 PM
jtisch's Avatar
It is off of a Stihl 32cc 4-mix for the manifold (goes through the manifold into the block) and yes it is a very coarse thread. On google the only thing I saw was for Subaru where it was for holding part of the instrument panel in place. I think I will just try machining the stock cap head bolts and see how that works.
J
Old 01-04-2010 | 08:32 PM
My Feedback: (13)
why not retap it for something more common?
Old 01-04-2010 | 08:48 PM
It sounds like some of those coarse SMS or self-taping screws for cast aluminum or pot metal one comes across from time to time. That's why I keep several jars of odd stuff. Good luck. John
Old 01-04-2010 | 10:10 PM
jtisch's Avatar
ORIGINAL: rangerfredbob
I thought of that, but there isn't a whole lot of extra material on the intake flange. I was hoping for an easy way out, but it looks like turning the stock bolts will be the easiest way, though not my preferred solution.
Thanks to all!
BTW, I should be getting my Stihl 36cc 4-mix this week. Can't wait to see what that will do compared to the 32.
Old 01-05-2010 | 10:26 AM
How about trying a Stihl repair service?
http://www.google.com/search?hl=en&s...=Stihl&aqi=g10
Old 01-05-2010 | 11:01 AM
Try mcmastercarr.com
Rick
Old 01-23-2010 | 03:54 PM
j_t01's Avatar
They are indeed a self tapping screw. This is the Stihl part number and description direct from the Stihl look up.
9075 478 4167 Pan head self-tapping screw IS-D5x32
Jim
