Honeybee King v2 tuner shop
#4154
MD
RE: Honeybee King v2 tuner shop
If it's a brass pinion, they certainly do wear out- if the teeth look like they're getting sharpened, get a new one.
Faststar- you certainly can use a G90. The 401 isn't hard to set up, though, if it works right- you just plug it in. The gyro switch will work to switch it between avcs and rate. If the default values aren't good for you then you're out of luck, though, since you can't change them with the stock radio. I got lucky and it worked fine on mine, but that's nothing like a guarantee .
#4157
MD
np, Faststar.
Fly To Chill, I assume it's a press on, that there isn't a set screw near the base? If so, there are a lot of ways to get them off. I just cut to the chase and got a GWS pinion puller (example: http://www3.towerhobbies.com/cgi-bin...&I=LXHHN3&P=ML) since it pops them off without a lot of fuss. Putting them back on, I used a bench vise- put the motor in the jaws, the pinion aganst the end of the shaft, then line everything up exactly while you slowly turn the vise down against it. Then it's a matter of just turning the vise in until the pinion is in the right position. Others have used C-clamps, and so on.
Better IMO is to get a decent pinion with a grub screw so you don't have to deal with the press on stuff any more. A little grean loctite on the shaft can lock it in place in addition to the screw, but I never bothered. I used these steel pinions, but they take a while to get to the US: http://www.heli-fever.com/product_in...roducts_id=691. There are also Align and Revco options, but they're a little more difficult to fit.
#4158
My Feedback: (20)
Would these work?
http://www.ka-planes.com/becs__escs_...nions?start=55
#4159
OK
Try the Rhino gear available in the US at several places (no waiting for chinese post), get the 2.3mm I/D for that esky 3900 and either definitely flat spot your output shaft or run locktite, I would not trust just running it dry on a smooth shaft myself but take the chances you are comfortable with. You may have to run it upside down for fit but it is one tough gear. I definitely agree that going with a set screw instead of press on is the way to go though.
On the HH gyro deal, I would also keep in mind that you will need to go to a digital servo at the tail if you want to run a HH. The stock tail servo will most likely burn up running that 401 since its pulse rate is so much faster and the servo will not be able to keep up.
#4160
ORIGINAL: betapilot
-lohchief
#4161
MD
The 401 is analog/digital switchable with a mechanical switch on the gyro, so you aren't depending on the radio for that. The digital servos do use more power.
#4162
ORIGINAL: osterizer
-lohchief
#4163
CA
ORIGINAL: Fly To Chill
Ok guys look this is my problem I have a hbk2 ,had it for 5 months no matter what i do i cant get the main gear and pinion to mesh rite is there any way that my pinion gear could be no good any more it looks a little funny,and if that is the case how do i remove the pinion off my motor and how do i but on a new one? thanks
Peace,
Z
#4164
OK
You can switch the ds mode off and you have to unless you are running a digital servo and it will still be an improvement over the stock gyro even running an anolog servo but it would seem a waste to spend the money and not reap the full benefits.
#4166
KY
so will a b400 main gear fit right onto the hbk2?? is it the same tooth count?? school me on this please.. i will be in need of a new main gear soon.
#4167
CA
ORIGINAL: sheerider1026
Direct drop in/replacement.....I bought the one-way puller to switch the one-way to new main gears for only $2.99 at my LHS. This is highly recommended. It cost $3.49 for new main gear without one-way, $8.49 with....Do some math and it's really worth it. When I was eating gears up with the Align pinions, I changed out the one-way at least 4 times with zero problems..
Z
#4170
My Feedback: (20)
Ok i would like to say thanks to every one for there help ,I went to ka-planes Mike Jr.hooked me up with a set screw pinion ans he even pulled off the old one for me so that was cool put it back together and she flyies better then ever, and to think I was going to scrap her and use the parts for the belt cp, glad I didn't do that now. thanks again.
#4171
ORIGINAL: betapilot
BTW - my comment was in answer to post 4144 where he ask about running the gyro with a stock tx.
-lohchief
#4172
CA
ORIGINAL: crashcrash
E-Flite is press on, Align is set screw.
The E-flight pinions I bought all have the set allen head grub screw......They were the pinions recommended for the Blade from LHS...Hmmmm? Crash?
Z
#4174
MI
ORIGINAL: Zimatosa
Z
Z
