OS46SF Diesel
![](/forum/images/badges/premium_member.png)
Nice work, Jef!
What RPM range were you getting? ...on which prop? ...fuel?
I played with a few of these several years back. Brief break-in on glow fuel - to where the initial metal-dirty exhaust ran clean and starting by hand was sure and easy. Then DDD head and Davis ABC fuel. 11" to 13" diameter, 6-ish and deeper pitch props.
Very nice combo.
OS stock P&L are ABN, so medium low oil % worked fine. I don't recall the exhaust being that juicy. (You use a nice extension rig, too!)
Stock OS carb proved to have better economy than another make, even with a case-pressure operated pump.
Engines definitely showed RPM plateau at about 3/4 throttle: wider open, no RPM gain but wetter exhaust and quicker fuel consumption. I didn't fly any of the engines I worked on, but the guy I did them for had good in-air performance.
Very nice combo.
Nice work, Jef!
Very nice combo.
Very nice combo.
I do the same thing if I'm breaking engines in at home. Makes a huge difference in noise. You just don't want the hose dipping into the water. That is if you're using muffler pressure to the fuel tank.
