Engine gear set overheating
QC, CANADA
Last week I took one of my Exceed Forza for a spin on the road ; weather was cool in Repentigny Quebec ,
and after 4 or 5 runs at high speed I noticed that the Engine gear set
was very hot and smoking and when I took it in the shop the gear housing O/D turned dark blue from the heat.
what do you think happenned in there??
The car is still running fine but I'm affraid to run it at high speed again .
Engine was removed and with a sand belt I removed the discoloration
did not strip any further.
Thanks Andy
bouledegum
Thanks Andy
bouledegum
QC, CANADA
Yes . in the spare parts part name they call it gear set assy
yes it's the clutch bell housing that became blue on the end face side
opposite to the gears.
bouledegum
bouledegum
The clutchbell will only get hot and turn blue if there is clutch slippage. High speed runs(less slippage) would be better than non-highspeed runs.
The smoking is from the clutch shoes. Check your clutch shoes for wear.
QC, CANADA
OK The buggy is new but will check it anyway
Thanks again for your reply
PS maybe the heating will stop cause this morning
it was -10 C or 14 F you'r in luck to live in Jacksonville lol
bouledegum
bouledegum
ORIGINAL: bouledegum
bouledegum
bouledegum
QC, CANADA
Yes everything seemed normal
perhaps it's because it was new and over did it
for the first run
now it's fine no more discoloration.
bouledegum
for the first run
bouledegum
I hope you broke in your engine before you ran it at high speeds...the slippage could have acured due to the shoes were new and hadnt had a chance to seat against the clutchbell..
with your engine off and roll your car back and forth, is your roll smooth? There should be no binding either direction.
I once tried to break in my truck on the curb and the clutch bell turned blue and the clutch slice was burning against the bell's wall creating lots of heat.
Andy
Andy
QC, CANADA
Yea I burnt 5 tanks of fuel before I took it to the road.
The car is running smooth now
the clutch must have found it's best running path inside the bell
thanks
bouledegum
thanks
bouledegum
