Speeder Power.
Old 03-23-2023, 10:43 AM
  #126
Clugh
Banned
Before i get my selection for my inverter. I have these laying around. 320 YGE style FETS. Ill show you how they limit the pwm or the amount i can run in parallel in the design. Since its a modular stack build. I can build and bridges with different FETS and test the switching and thermal performance .
Old 03-23-2023, 12:56 PM
  #127
Clugh
Banned
Texas Instruments board layout consideration for BLDC drives. This is a very "valuable" read.
File Type: pdf
Old 03-23-2023, 01:31 PM
  #128
Clugh
Banned
Old 03-23-2023, 01:34 PM
  #129
Clugh
Banned
Old 03-23-2023, 01:37 PM
  #130
Clugh
Banned
Old 03-23-2023, 01:55 PM
  #131
Clugh
Banned
Have the double "R" boys been adding anything useful into the electronic forums in my absence?
Motors, ESC's, BEC's, Batteries & Chargers - FlyingGiants
E-Motoren | RC-Network.de
LOL!
Old 03-23-2023, 02:30 PM
  #132
Clugh
Banned
Okay its a d2Pak with 2.54 pitch (e) T0-262 Its 100 volt 180 ampere fet but the gate charge is double that of the newer fet id use so you can only run 6 where I could run 12 before. The newer fets have the same resistance but half the gate charge so you can build a higher current drive with the newer stuff and it can switch faster for the same number of fets.
Old 03-23-2023, 02:33 PM
  #133
Clugh
Banned
See how it goes? I'll work on this and feed boo boo later this evening.
TTYL
Hubert
Old 03-23-2023, 05:43 PM
  #134
Clugh
Banned
Started this route but Im going to dumb it down even futher.
Old 03-23-2023, 05:57 PM
  #135
Clugh
Banned
Since the MitochondrikLV has all the drivers and ill only use 2 fets per phase ill utilize all the copper I have and build three separate power stages in the notch mode configuration like so and use the entire 77.5 x 102 mm clad for each phase. The caps can go irght in between the GND and VM rails. Like the torque cradle It will be trial and error.. It will be a simple routing for the high side logic in a modular stack as well. Ill have to add a kelvin shunt on two of the power stages. Easy peasy...
Regards
Hubert
Old 03-24-2023, 09:56 AM
  #136
Clugh
Banned
All I need now is to add the DC buss headers and shunts with via the i can go backside and route the signals for a 3 phase half bridge. A power stage will hold the mlcc .
I guess the squirrels are busy eating nutz!
Regards,
Clugh
Old 03-24-2023, 11:08 AM
  #137
Clugh
Banned
Starting the backside routing ..
Old 03-24-2023, 12:55 PM
  #138
Clugh
Banned
Old 03-24-2023, 03:43 PM
  #139
Clugh
Banned
The phase current measurement. of the MitochondrikLV
The "plagiarist".
Hubert
Old 03-24-2023, 06:55 PM
  #140
Clugh
Banned
Default Current Sensing
Regards
Hubert
File Type: pdf
Old 03-25-2023, 12:54 PM
  #141
Clugh
Banned
Here is a half bridge topology that will drive and open ended coil set.
Old 03-28-2023, 11:21 AM
  #142
Clugh
Banned
Old 03-28-2023, 11:24 AM
  #143
Clugh
Banned
Old 03-28-2023, 11:26 AM
  #144
Clugh
Banned
For my personal 7050 marine motor Ill do what Volabo did and create my own ISCAD Ill create an I fit pure copper cage. I can get fancy and cast pure sterling!
Old 03-31-2023, 06:23 AM
  #145
Clugh
Banned
This is a MitochondrikLV based 96 volt 8 kw drive the Valenok
Old 03-31-2023, 08:18 AM
  #146
Clugh
Banned
Ralph I dont know why you are in here,
You assured me that the thing's I heard about you were a lie and you even brought up your charities and told me no way you are like that. Apparently youre anger about the motors have shown who you truly are so I prefer It if u'd go home even though I know you will camp here, Just know This is my last acknowledgement of the myth Powercroco good luck with yourself and your fans. I wont build Micheals thread.
Hubert
Old 03-31-2023, 08:50 AM
  #147
Clugh
Banned
Pavel has offered me evaluation of the Valelnok. I will not forget your bad comments. I will not help you with the Talega drives or the propeller learning because you have a bad spirit. I had many things to help you. you dont tell the truth to the forums. Why should I share my projects with you. I wish the blog was private here I would exclude you. I really would as ugly as that is.
what you are doing is not right I will never lie to the boys.
Regards
Hubert
Old 04-01-2023, 03:25 AM
  #148
Clugh
Banned
neumotor 1521 1..5T Delta on 1.5 mill cells
478 grams
1886Kv
Io @ 10 volts is 3.0
Rm .005
Copper loss .1 watt
Iron Loss .33 watts
Esc Loss .7 watt
Battery loss -
Kt 5.06 mNm/amp
Km .0653 Nm/sqrt watts
Power Density 8.92 Km^2/g
Old 04-01-2023, 03:31 AM
  #149
Clugh
Banned
My COTS choice for speed is Neumotors
If I cannot build it myself everything Id ever need is right here in the USA.
I want to get the most out of my battery!!
Old 04-01-2023, 04:01 AM
  #150
Clugh
Banned
Default Everything is less than 600 Euro!
American Options
for the most amperage demanding form of RC!!
Twin Machines wound Castle 1721's .on XLX2 they are 46 x 101 mm 2400 Kv motors Ideal for extreme speed and drag set ups. They turn 90,000 and are proven to win!
$240.00 each usd
