12Z Loose Antenna
My Feedback: (20)
12Z Loose Antenna
I have a 12Z with the TM-14 module. The antenna it self is loose on the two protruding pins that hold it on to the TM-14 module, also, when I set the antenna to point straight out it will fall or drop towards the ground. If I put it to horizontal position (normal position) it wants to drop towards the ground at about a 45 degree angle.
I have not had any operational issues however are there any concerns that you see that would or could affect the signal? If so, can this be fixed?
Jeff
Jeff
