R3008SB HV receiver output voltage
My Feedback: (16)
CA
Hi, Just got a new 12K 14 channel radio and a R3008SB receiver. My question is what is the voltage output on the receiver at the PWM channels? If I use a 7.4 volt battery to power receiver is that the voltage that is supplied to the servo outputs? I use Hitec servos and they are rated at 6 volts max. Trying to figure out if I will need a voltage regulater or get some 6 volt batteries .
Thanks for your help
