Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
9C Super question
Old 03-14-2006 | 06:25 PM
Default 9C Super question
Hi,
I found the following quote in another forum under the title "BEWARE! Futaba 9C Tx - Mix offsets changing in flight" but I believe it is more appropriate for me to post my question here :
ORIGINAL: flyer59
This post is to inform other Futaba 9C owners of an undocumented quirk in the Tx programming that nearly caused me to crash several times before I learned what was happening.
The problem is that when a mix is ON the trim levers may change the mix OFFSET instead of trimming the plane. This can happen without entering programming mode. If this happens when the plane is in flight the pilot may keep trying to crank in more trim because the plane isn't responding. If and when the affected mix is later used the pilot will be in for a big surprise because the OFFSETs will be way off.
My problem was with the Butterfly mix on a full-house sailplane. I normally fly with the Butterfly switch enabled so I can engage it without flipping a switch first. In my case applying down elevator trim did not change the trim setting, but the plane dived sharply when I engaged Butterfly mode. A later check of the Butterfly elevator OFFSET showed that it had changed from -10% to -90%.
I kept sending the radio in for service because I didn't understand why the trim wasn't working and the offsets were always changing. The guys at the Service Center wrote back the last time I sent it in and told me of the connection between the two issues.
I like the 9C, but personally I'd prefer not to have my program parameters to change unless I am in program mode to change them. Maybe there's some reason why the 9C is designed this way, but I can't imagine why and I don't see anything in the manual about it.
Be sure to adjust trim in flight only when all mixes are turned OFF to avoid changing the program offsets.
My question is : has this problem been fixed in the new 9C Super ? My reason for asking is that I am considering upgrading from a FF8 and this problem would be a show stopper for me.
Many thanks,
Boo
Old 03-15-2006 | 05:38 AM
bigman's Avatar
Default RE: 9C Super question
I did have the bad experience with myMini Blade. As I remembered that I had set the crow for Mini Blade of down elevator for 16%. It is a good value for Mini Blade. I had experienced to land MB at this value with smooth landing. After several flights, I had put aside of MB for nearly two months. After two months I flied MB again, I had not checked the setting of crow. When I landed MB, it dived sharply and made a outside loop and hit the grassland. I immediately checked the crow setting and down elevator was set to 50%.
After that incident, I usually checked the crow setting of each plane and sometimes found the setting for down elevator had been changed to a greater value. It was very surprised that the value always be increased but not decreased!
Please remind all the 9C users to check the crow setting before each flight especially the down elevator value.
Old 03-15-2006 | 05:39 AM
bigman's Avatar
Please be informed mine is 9CAP not 9CAP Super
Old 03-15-2006 | 06:32 AM
Bax and Krista will be after us for 'discussion' on their forum!
I think what's described above is a positive feature of the 9C, not an issue or problem.
You get independant primary control trim settings (elevator/rudder/aileron) for each of the crow/flap and reflex programmes. There is no way that elevator compensation on crow, for example, could be the same setting as elevator trim for normal flight. Switch the crow off for normal flight as you do for flap and reflex and there is no problem. The crow trim setting won't change unless crow is switched on when the trim lever is moved.
I agree, the manual should more clearly explain that the trim settings are independant for each of the crow/flap/reflex programmes.
Old 03-15-2006 | 08:07 AM
Hi,
I am not particularly concerned about whether it is a bug or feature, of course this will depend upon the perception of the individual user.
I just need to know whether the 9C Super behaves in the same way as the 9C in this respect, so I can make a purchasing decision. Sorry to be unclear in my original post.
Boo
Old 03-28-2006 | 11:14 AM
Bax
This is not a "bug". What happens is that when you have a mix on, depending upon the mix, the trim on the primary will affect downstream mixes. It's not changing the "offset", but trimming. If you have rudder mixed to aileron, then adding aileron trim will affect rudder. If you use the pmixes, you can select in some of them whether the trim will affect the mixed-in channel. In some of the pre-made mixes, this feature may be on or off.
This isn't changed in the Super version.
We're sorry for the delay in response. This wound up on the second page and got lost for a bit.
Old 07-20-2006 | 05:37 PM
ORIGINAL: Bax
Well, I bought a 9C Super and I don't agree with your assessment that this behaviour is not a bug. (In the glider modes the behaviour has been fixed in the 9C S).
In Acro mode if you set the airbrake so it is activated by the throttle stick a near the low throttle position you still get the behaviour :
1. Set airbrakes to be operated the throttle stick moving below (say) 25% and conditioned by a switch.
2. Leave programming mode and switch the airbrake off with the switch.
3. Trim the model, (say) aileron trim.
4. Activate the switch but keep throttle above 25% so the airbrake is not activated.
5. Trim model aileron some more.
6. Oops ! No effect ! I tried moving the trim all the way and nothing happened ! That's weird, I'd better land and investigate...
7. ... See what's coming ?...
8. Reduce throttle below 25% to land....
9. Oh, now I know where all that aileron trim went !
10. Walk to field carrying a bin bag.
This is so well known and so well documented that I'm surprised Futaba hasn't issued a product recall. What happens when someone discovers this defect when they're flying a 1/3rd scale Boeing 707 at an air display ? The product liability issues must be tremendous...
So what are Futaba going to do to fix it ?
Boo
Old 07-21-2006 | 11:24 AM
Bax
Again, this is not a "bug" or a "problem". When the mix is on, the trims will work on the offset. The instructions included in the 9C system mention that the trim lever adjusts the control's setting in the mix when it's turned on. It does not act as a regular trim unless you turn off the mix.
Old 07-22-2006 | 06:46 AM
ORIGINAL: Bax
You have ignored what I said. The bug is that the trims work on the offset when the mix is off. In my example above, the mix is activated by the stick being moved below 25% as well as a switch being set. The trims adjust the offset whenever the switch is set alone, which ought not to be enough to activate the mix. I would like to forestall you from saying that the mix is activated solely by the switch since that is an exact statement of the bug : the mix (and hence trim-offset) should only be activated by the switch AND stick position together because that is when the mix becomes effective and the control surfaces start to move.
The flying example I gave proves that the behaviour is defective and I do not understand why Futaba is in such vehement denial over this ? I have heard of several models that have been destroyed by this defect and it is only a matter of time before someone is injured as a result.
ORIGINAL: Bax
I am talking about the 9C S and the behaviour has been fixed in this TX for the Glider modes where the trim can be selected to control either the offset or the trim. The fact that Futaba have fixed it in the glider model template shows that they tacitly acknowledge it to be a defect.
In the Acro model template it is unaccountably not fixed and the problem therefore remains. Of course the product liability issues with a large scale powered model are hugely greater than those with a glider and I surmise that this is the reason for Futaba's defensive posture on this issue.
To sum up, anyone who reads and understands the flight scenario I gave will be forced to agree that the behavioour is defective and I call on Futaba to issue a general global recall of this TX to modify the programming and to prevent an accident where somebody may be killed or seriously injured.
Boo
