What Aircraft are you installing your DLE20
#228
My Feedback: (18)
RE: What Aircraft are you installing your DLE20
Mine will be going on a Aeroworks Extra 300. I am waiting on the plane in the mail kind of a hold up do to the wether here in NC. Got some snow on the ground whole place is shut down. Last thing that I heard was they could not find the keys to the plows.
#229
IL
I use the Airtronics RDS8000 and I've been very happy with it. I purchased it with an 8ch RX for about $150. That was two years ago.
Today I would recommend the SD-10G or SD-6G. I think you will be happy with the SD-6G for $159. Airtronics 2.4ghz technology is rock solid and much less expensive that competitive equipment.
If you want more info on Airtronics, seach the forums for related threads...there are a few out there.
ORIGINAL: SigMan
what airtonics radio do you use i seen a 6 channel 2.4 for 159 bucks at hobby people. wonder if its any good?
#230
ORIGINAL: mschulz531
#231
hello there guys
ihave mine installed in a nitro models extra330l 90
still in break in prosses lots of oil in the 1st gallon
and flies very nice just love it
thanks
thanks
#232
My Feedback: (7)
IN
ORIGINAL: Rhino0_6
......................kind of a hold up do to the wether here in NC. Got some snow on the ground whole place is shut down. Last thing that I heard was they could not find the keys to the plows.
My wife has relatives over in Lexington. They use water hoses & leaf blowers to clear the snow.
Betchya ALL the beer, bread, and milk is gone from the stores there....in that order too!
#233
My Feedback: (7)
IN
ORIGINAL: pwr1973
Post some photos of your DLE20 eng installation!
Just in case it helps (regarding uploading pictures)........
http://www.rcuniverse.com/forum/m_2629917/tm.htm
#236
My Feedback: (12)
ON, CANADA
Here are a few pics of my custom exhaust for my showtime 90. The entire engine and muffler fit completely insidde the tight showtime cowling. I used two 4oz aluminum cans to make the muffler. The muffler is a two chamber style using the top of one bottle as a joiner and cone.
#237
My Feedback: (12)
ON, CANADA
Well that was the first pic I have uploaded on rcuniverse! It would not allow me to put all the pics on one post "file too large" so here are the other two. I still have to add the stinger.
#239
My Feedback: (17)
FL
ORIGINAL: seagull extra
#240
My Feedback: (12)
ON, CANADA
They are almost as quiet as a cannister exhaust as I make the muffler with two chambers. Here is the first one I did for my Patty with the DL50
#242
CA
Here was another candidate for the dl 20 but it got the .91 surpass. I still love my 4 stroke glow too.
That is a nice looking aircraft for sure. I know what you mean about the 4 strokes, I still love mine as well. I do have to make one comment you have to do something with that workshop of yours. I thought you were working in the house until I saw the bike and wings on the wall. LOL! Throw some dust around make a mess, your making me look bad......
Dan
#244
#245
My Feedback: (17)
FL
Paul
#247
My Feedback: (12)
ON, CANADA
For the exhaust flange on the 20 I used brass flat stock and on the 50 I just pounded a piece of copper pipe flat, then I make a paper stencil of the exhaust and use a drill and file to shape the flange.
#249
After I got the engine mounted on the Hurricane I put on the cowling, prop and spinner, put it together and put on the cg meter to get an idea where I need to put batteries, ignition etc. I found that this engine is considerably lighter than the 120 OS FS it is replacing. I am going to have mount both batteries and ignition system in the cowling as far forward as possible and will probably still have to add weight to the prop hub. I've got the throttle hooked up and now working on the choke. I thought this engine would be too heavy for some of my longer nosed airplanes such as the P-40, but I guess not. If this engine runs as good as reported, this plane ought to go like a rocket at 9.5 lbs.
#250
IL
I've got a GP kit built .60 size Extra300. I was planning on putting a Saito 100 in it. Santa brought me a new DLE 20 that should bolt right in with little modification. I can't wait to try this new little gasser out.
