Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Gas Engines
Reload this Page >
What Aircraft are you installing your DLE20
Old 07-24-2013, 01:02 PM
  #1476
Lifer
Lifer's Avatar
Default RE: What Aircraft are you installing your DLE20
I believe Phil Kraft designed the original Das Ugly Stick and it was published in Grid Leaks magazine.
Old 07-24-2013, 02:44 PM
  #1477
stevegauth30
stevegauth30's Avatar
Man, you guys are making me want a P-38. Such a cool, and different looking plane.
Old 07-24-2013, 03:20 PM
  #1478
Bob Paris
My Feedback: (13)
Hay Lifer,
I doubled checked...and your absolutely correct...It was Phil Kraft that designed the Ugly Stick. Please excuse my error.
Soft Landings Always,
Bobby of Maui
Old 07-24-2013, 03:24 PM
  #1479
Bob Paris
My Feedback: (13)
Hay Steve,
The P-38 is an awesome aircraft and a very complex model to build R/C. I must have 5 lbs. of wires alone in my model...at least it seem I do. The P-38 is notorious for single engine out of control issues. Every one of the models I've witnessed...in time lost an engine...and unfortunately, every time...they had an uncontrolled very hard landing. You need two bullet proof engines on board and a keen set of thumbs on the Transmitter. Anyone that can keep a R/C P-38 alive and well, has to be a suburb modeler and proficient on the sticks. I'll also add...have a bit of good luck.
Bobby of Maui
Old 07-24-2013, 03:45 PM
  #1480
tailskid
My Feedback: (34)
tailskid's Avatar
I have always feared twins because of the one engine out syndrome.....but with those gassers - problem solved (unless you run out of fuel )
Old 07-24-2013, 05:14 PM
  #1481
Ernie Misner
Ernie Misner's Avatar
Has anyone found a way to eliminate the rudder coupling? I think one fellow used anhedral instead of flat or dihedral with good sucess.
Old 07-24-2013, 06:07 PM
  #1482
stevegauth30
I know. That's actually the only reason I don't have a twin yet. With only a few years of flying under my belt, I know I'm not ready to throw away that kind of money, time, and sweat. Hell, I sometimes have a hard enough time just keeping my more simple planes in one piece. Don't mean I don't want one though. Thanks for the advice, I think I'll take it. Steve.
Old 07-24-2013, 06:32 PM
  #1483
Twin_Flyer
Find yourself a twin and go for it! Nothing sounds as nice as a twin on a high speed low flyby!! Doesn't matter what engines are in them either!
My 3rd plane was a Pica Duelest, Still have it after almost 30 years too!
The Hobbico Twinstar is a good way to get started before getting something that will use two gas engines...
Bill S.
Old 07-30-2013, 07:58 AM
  #1484
JohnB96041
JohnB96041's Avatar
ORIGINAL: foxworth
I put my DLE 20 in a funtana 125, with a 17 x 6 XOAR. With the wind and weather I only been able to fly it twice.
<hr />
Foxworth: Just looking for some information about your install of a DLE 20 in your Funtana 125. How are the motor mounts holding up? Some people have used the metal mounts, some have used the Dubro shock absorbing mount. I have installed my DLE20 using the same mounts as shown in you pictures. How does it fly? Mine had the Saito 1.25 4s and have converted to the DLE 20cc gas. I have another Funtana 125 that has a 30cc gas engine by Syssa Aircraft Performance. It is the syssa180hp. I love that engine, but is really overpowered for the Funtana 125.
Old 10-05-2013, 03:48 AM
  #1485
alvinsmith75
alvinsmith75's Avatar
Haven't owned a Super Chipmunk in over 20 years but it was always my favorite plane. I am about to build another one. The Carl Goldberg .60 size kit. I was originally going to install the evolution 10cc engine, then I was thinking the evolution 15cc and now after doing research on engine weight I am considering the dle 20cc. I know its a .60 sized plane and the 20cc is obviously overkill but my question is, will it work? I am just looking for it to be gas powered and reliable. I already own a dle 35 in my Pilot Rc Edge 540 and love it. Any advice? Or am I plain nuts? LOL
Thanks in advance,
Alvin
Old 10-05-2013, 06:14 AM
  #1486
1300rpm
Hi Guys
I have a few DLE20.
Lovely motor, reliable with good performance, run in on 16X8 Xoar prop, once run in done replaced by 17X6 Xoar, all use a mounting plate available from Seaplane Supply (link below)
http://www.seaplanesupply.com/aluminum.htm
You will also need to replace the throttle lever with one CNC Alloy Throttle Arm for Gas Engines
available from Hobbyking (link below)
http://www.hobbyking.com/hobbyking/s...dProduct=21299
The DLE 20s are mounted on the following
1 on a VQ Cap 10B (Ideal match)
1 on a Pilot RC T90 (Bags of FUN on every flight) can be upgraded to DLE 30 as mounting plate matches DLE 20 to DLE 30 mounting points
1 on a Seagull Ultimate 120 (Ideal match)
1 on a Seagull Yak 54 (Ideal match)
And I am planning to fit 2 on a ASM Grumman F7F Tigercat
and another 1 on a Seagull Dewotine D520
Old 10-05-2013, 06:21 AM
  #1487
Lifer
Lifer's Avatar
I have several "60-size" models that fly great with a DLE 20. Most of the Top Flite and Hangar 9 60-size warbirds do great with a 20 cc gasser.
Old 10-05-2013, 07:23 AM
  #1488
stevegauth30
I have one on a sig CAP 231 EX 120. It sport flies it just fine, but a 30 or 35 would do it a great justice. I also have a top flite corsair and seagull super decathlon that both have 20's and are both rocket ships. Awesome little gasser. No complaints.
Old 10-05-2013, 08:22 AM
  #1489
Twin_Flyer
Steve,
the sig CAP 231 EX is an arf Sig made for a while isnt it? I have one and am planning a DLE30 install.
By any chance do you have any pics of your engine setup?
You can send them to me at mr_avt@yahoo DOT com to keep this forum on topic...
Bill S.
Old 10-05-2013, 11:05 AM
  #1490
stevegauth30
Hey twin flyer, yes, that's the one. I think you'll really like it with the 30 on it. It's got almost unlimited vert with the 20, but just not enough. Of course, you'll have to open up the bottom of the cowl like mine, but I'm sure you knew that. Also, there's plenty of room behind the firewall for batteries, and throttle and choke servos if you choose.have fun with it, Steve.
Old 10-05-2013, 09:42 PM
  #1491
Ernie Misner
If they have under rated the engine requirements like they often do it might work fine. I think I would post a question in the kit or aerobatic forum (or where else, anyone?) about what engine others have used to get the right power to weight and balance. You need to look at the all up weight of this plane and how it would balance with the DLE 20 up there. The good news is that most 60's weight as much as more as the 90's do, and the DLE 20 weighs barely more than most 90's.
Thanks in advance,
Alvin
Old 10-05-2013, 11:40 PM
  #1492
Twin_Flyer
if you do a search on RCU there is a thread on the TWM Super Chippy ARF and there are a few flying with the DLE20 with no issues. Also, the Airborne Models/TWM Super Chippy ARF seems to be a true copy of the CG design!
Bill S.
Old 10-06-2013, 04:45 AM
  #1493
ahicks
Thanks in advance,
Alvin
Alvin, there are a TON of guys flying the 70" Revolver 60 using DLE 20's. It handles the power just fine and makes an awesome all around sport plane. It's about 850 sq in and usually comes in between 9-10lbs? It's the smallest 20cc plane I've flown that really flies well.
The Chipmunk you're talking about (I think?) is 64", just under 700 sq in, and 6-8 lbs (maybe a little more with the 20?). My experience would say this is going to make for a plane with fairly heavy wing loading, similar to a lot of the military stuff? That's just a guess though. Wouldn't argue the point until flying one.
These are the specs I'm using:
http://www.carlgoldbergproducts.com/.../gpma0952.html
Old 10-06-2013, 06:50 AM
  #1494
Twin_Flyer
pretty close to the TWM version.
http://www.rcuniverse.com/magazine/a...article_id=814
Bill S.
Old 10-06-2013, 02:34 PM
  #1495
Granpooba
Had my DLE 20 mounted in a Great Planes Revolver 70. But that one contacted Mother Earth. Will be putting the DLE 20 back into another Revolver 70.
Aso just ordered a Hanger 9 Christen Eagle and will be powering this model with my new OS GT 22.
Old 10-06-2013, 05:14 PM
  #1496
Tailspin
Tailspin's Avatar
I installed a new DLE20 RA rear exhaust engine in my old Hanger 9 PT-19 last week and flew it a bunch of times this weekend. The little engine ran like a champ right out of the box. About 20% more power than the Magnum 1.20 4-stroke glow engine it replaced, I would guess. I used a Valley View 17x6 prop and Pennzoil at 32/1 as recommended by Valley View.
I will be using one of these in my new Hanger 9 Tiger Moth in a month or so. This is the perfect engine for narrow cowled planes.
Steve
Old 10-06-2013, 08:00 PM
  #1497
Bob Paris
My Feedback: (13)
Hi Guys,
I just ordered a 20cc gas powered Gee Bee R3 and I will use a RCG 20 in the airframe. I've experience with two RCG 20's and really happy with this gas engine. I had these originally mounted in a Big Stick ..60 ~ .90 ARF. There was a learning curve for me in running this engine, for they were my first gas engines. Once I figured out how to tune the carb's...life got a whole lot better for me. Great Power and received my best power, with a Xoar 17x6. I also used a Master Air Screw 16x10 with good results and I be using a 16x10 with the R3. I already have a Pitts style muffler for this engine and a Roto 16 oz. fuel tank.
The model came from General Hobbies and I was told it shipped out five day's ago.
Bobby of Maui
Old 10-06-2013, 08:37 PM
  #1498
RKoz
My Feedback: (10)
I'm thinking about installing the DLE 20 in the TF Spitfire kit. had a Saito 125 in it, but with a small tank flight times are short. Anyone with this set up.
Old 10-07-2013, 12:59 AM
  #1499
stevegauth30
Not with the spit, but a perfect match for the top flite corsair and mustang. I don't think the spit will be any different.
Old 10-07-2013, 04:48 AM
  #1500
alvinsmith75
Thanks for all the replies guys. After your comments and further research I believe it will work. I am also considering moving the elevator and rudder servos to the tail of the plane like they are in several of the planes I own now. I believe this will help the plane to balance out without having to add any additional weight.
