What Aircraft are you installing your DLE20
#1227
RE: What Aircraft are you installing your DLE20
ORIGINAL: acdii
I must have missed it, but what is the diode for?
For our purposes here, power going through a diode is dropped by a little less than 1 volt (1 volt for planning purposes). Power through 2 diodes drops a little less than 2 volts (etc.). We're using the diode to limit power from a fully charged battery pack (7+ volts) to that found safe for use with the 6 volt max limits on the ignition modules. Works great in practice, and can't get much simpler.
#1228
I currently have a DLE20 in a OMP Fusion. Very nice but one day down the road it will no doubt meet its end. In looking for a replacement plane for the DLE20 I came across a Phoenix Model 540 Edge (.90- 1.20 size) at Tower Hobbies. It is a 65" wingspan and AUW of about 9 pounds. I did a search here but there is no information about this specific plane. Does anyone have it and can report the quality of the ARF and how well it flies?
Mike
Mike
#1229
I have it. Not finished yet but seems to be a nice kit. I have to put the radio gear in and Ill be ready for the maiden.
#1230
ORIGINAL: ahicks
Let's see if I can get this right.....
ORIGINAL: acdii
I used diodes also to setup wigwag lights to prevent positive voltage from bleeding from one light to the other on a common ground circuit in a car. Never tried them to reduce voltage though, will have to dig out my box of parts and see the drop for myself. Interesting.
#1231
ORIGINAL: acdii
#1232
ORIGINAL: Glyder
Mike
#1233
[link=http://www.rcuniverse.com/forum/m_10956033/anchors_10956033/mpage_1/key_/anchor/tm.htm#10956033]I'm building a Texas RC .60 Sized Drastick with an ES Composites tuned pipe.[/link]
#1234
Ifound this to be just right, no worries, and no soldering or other mess. badbradgraphics.com/images/regulator_2.jpg $11, and not voltage dependent.
#1235
OR
Well, I'm getting ready to install a DLE20 in my TF 60 ARF P47, my GP PT17 and my Seagull Zero.................hopefully this will work well, these are my first 3 gasser's.
#1237
I have installed the DLE20 and flown the following models:
Seagull extra 260 60-90, 2 more at our field
Seagull edge 540 60-90 3 more
Seagull MXS-R 90
Phoenix YAK 54 90
Currently building Black Horse PC9 90 with air retracts......
Seagull MXS-R 90
Phoenix YAK 54 90
#1238
My Feedback: (18)
IL
ORIGINAL: sandyjain
Seagull MXS-R 90
Phoenix YAK 54 90
Seagull MXS-R 90
Phoenix YAK 54 90
How do you like the Seagull MXS-R 90?
I have the Edge 540, and love it!
Anthony
#1239
I actually built it for a friend. Mine is still in the box.
Had 2 flights tho....
Looks great, great cockpit, tad heavy, easy to fly....
The extra260 or the Edge 540 are better for 3D.
#1240
OR
ORIGINAL: Lifer
oldtyme,
I have the DLE 20 in my TF P-47 and GP PT-17. Good fit and good power! I used a 17x6 Xoar in the PT, and a Xoar 16x8 in the P-47.
oldtyme,
Andy
#1241
Oldtyme,
I really like the H-9 metal mounts. I used those and added spacers to project the thrust washer to where it needs to be. I would like to discourage the use of the soft or vibration dampening mounts. I believe that it is best to hard-mount these engines. Just my 2 cents.
#1244
NH
After over 300 flights on my 2 DLE-20's, I now have the first Mintor 22cc in the US. My friendMatt and I are building the ultimate 68 inch Velox. We found a NIB yellow Velox from CA. Matt has contributed the Hitec 5565 ultra fast HV servos on the wings and elevators, and a 7954 on the rudder with Azhars's cool Secraft CNC servo arms. We are using CF/Ti pushrods, 10 oz Fiji bottle tank, Tech Aero IBEC, JR922 DMSX receiver, with dual 1300 mah 20C Sky-Lipos for power, Nachos cheese graphics. The Mintor 22 hopefully swing a 18 inch Vess. This will be the ultimate cool Velox, best of everything. It will be very interesting to see how it performs compared the trusty DLE-20.
#1245
No pictures at this time and all the planes are buttoned up. If I need to remove the cowls, I'll take pictures at that time. Given the fact that the DLE's are purpose-designed model engines, they really don't have a different appearance than a glow engine.
#1247
Here is where my dle 20 is a. In my cmp butcherbird. I did a 5minute spray bomb paint job. I hide the on off switches under the panel on the side. The cowl has 4 pegs on the ring that index it to the fuse and 2 rare earth magnets hold it from going anywhere. One more pic of the magnet and index holes that the cowl goes into.
#1248
Here are a few more pics. I wish they would have slanted the plug back. It seems like it would have helped getting the cowl to hide on some of the birds like the P51 where the cowl curves up on the botrtom. Mine is sticking out, just the plug cap maybe 1/2 inch tops.
#1249
OR
I know this was covered briefly in earlier posts.......way earlier.........but I'm an old guy trying to learn new tricks. When you rotate the carb 180 do you or should you rotate the reed block as well or just the carb??
Thanks for humoring an old fart.......
Andy
Andy
#1250
My Feedback: (23)
Hey Andy,
you only rotate the carb, the reed block orientation is specific to the crank case in how it draws in the air fuel mixture. At least that is how I understand it.
