What Aircraft are you installing your DLE20
#1501
I've got a DLE 20 in a TF P-40 Warhawk, a few very small mods but it runs and flies Sweeeeet!!
http://www.youtube.com/watch?feature=player_detailpage&list=UUPES9tGMfyEEXhnoYfIjeYA&v=e7d0xqBoUrU
#1503
It is funny how things change. I always used to overpower my models, partly because I lived at 4500' elevation which kills about 15 to 20 percent of your power right there. (depending too on temperature.) I used to run .25 engines on .15 planes, .40/.45 engines on .25 planes, and .60 engines on .40 size planes, etc. Back then, everyone thought I was crazy. Nowadays, everyone would think those planes were a bit underpowered!!
A gas engine with it's relatively big prop turning slower is more efficient than a small prop going like a bat out of hell like on a glow engine. I think in most cases a 20cc engine on a 90/120 size plane is a killer, powerful combo, and on a .60 size plane is just incredible! I once kit bashed a .60 size Stik to a low winger, shortened the nose a bit, and put a 25cc gasser on it. I had great fun with it for a long time, then sold it to a friend and it is his favorite plane. It is fun to see it accelerate going straight up until it is just a dot in the sky, then spin it back down....
I only have one glow plane left. It is a Twist 40 with an old Fox .78 on it. Now there's a fun combo too! Cruising by at half throttle, when you nail it, it accelerates like it is going to leave the tail behind!! A Twist .90 (60?) with a DLE 20 on it would probably be pretty cool as well.
AV8TOR
AV8TOR
#1504
My Feedback: (7)
Help !!! Has anyone purchased or tried to buy a DLE 35ra engine from AEROBEEZ HOBBIES within the last 6 weeks. I had one on backorder for the last six weeks and as of today the engine is still on backorder. They seemed to have quite a few of thier products on backorder. Are they going out of business? The engine in question was purchased with a 30cc airplane and I got it for a great combo price. I finished assembling the aircrsft, now, I need the engine, to finish this project.
Iknow that this is a DLE-20 thread but I need help and I didn't know where else to go.
I guess that I can cancell the order but I have to pay more for the engine plus frieght except from Chief Aircraft. Please help.
#1506
WA
I installed one in a Seagull Edge 540 -120 size.... All I can say is ... WOW!!!... Fly's GREAT.... Been looking for a good match for the DLE20 and I just found it..
#1507
does any one know if a dle-20 will fly a pt-19 78" wing span ok, plain is about 8-1/2 lbs with-out engine and batterys also the gc in the book says 105-110 mm back from the leading edge not sure about that does anyone know if this is the correct gc for a pt-19 I read somewere were some one said just go 5'' and it would fly just great just not sure,
#1509
I would agree with kmeyers. 25 to 27% of the wing chord! back from the LE. I would think the 20 would fly that plane with plenty to spare. Especially that type of plane. Good luck with the maiden.
#1510
My Feedback: (34)
"I guess that I can cancell the order but I have to pay more for the engine plus frieght except from Chief Aircraft. Please help."
Check out ValleyviewRC!
www.valleyviewrc.com
#1511
thanks kmeyers, and stevegauth for the reply, the engine should back from the factory next week i'll go with the 25-27 % of my wing for the gc (should I balance my pt-19 up side down) the manual does not say.
#1512
I've always balanced my bipes right side up on the top wing, with good results, but wait and see what others say too. I don't want to lead you in the wrong direction. That's just my experience. Steve.
#1513
The Pt- 19 is a low wing plane usually balanced upside down, the Pt- 17 is the Stearman bipe. What brand of plane is it? you can go to most manufacturers websites and get the CG info but if the wing is a constant chord wing then 25-27 % will work measured at the root. I have a 20 in my PT-17 at 14lbs and 1 in my Ryan at 11lbs and also in my 60 size warbirds. All fly with plenty of power, especially the warbirds
#1515
thanks rptureboy for the pt-19 info, it should come in under 11 lb so ill go ahead with my dle-20 everthing including the servos less engine so far is right now is less than 9 lbs I only need to add the weight of the dle-20 and battery packs when my engine comes back from the factory if they ever get the part in
#1517
#1518
I have one of the new DL-20RA rear exhaust engines and will be putting into a Hangar 9 BF-109.
It should be a good match because by all reports the model still needs a pound of lead up front with a Saito 1.25 so the extra weight of the DLE plus ign and battery should help there.
#1519
FL
Dle20
I have an extra 260 and I was thinking about putting one of these on my plane. Is there anything that I need to do to install this engine on this plane. And what do you think about a DLE 30 is that to much for this plane.
thanks guys for any input.
#1520
What is the size and weight of the extra 260?
I have a few DLE20.
Lovely motor, reliable with good performance, run in on 16X8 Xoar prop, once run in done replaced by 17X6 Xoar, all use a mounting plate available from Seaplane Supply (link below)
http://www.seaplanesupply.com/aluminum.htm
the mounting plate matches DLE 20 to DLE 30 mounting points thus, if the 20 is not enough you can replace it with the 30 without the need to make new holes.
You will need to use stand off's, the lenght will depend on the space available from the engine box to the cowl
You will also need to replace the throttle lever with one CNC Alloy Throttle Arm for Gas Engines
available from Hobbyking (link below)
http://www.hobbyking.com/hobbyking/s...dProduct=21299
I have a few DLE20.
#1521
Thanks.
#1522
IL
With the right prop the 20 will hover a 14 lb plane. The 20 has more power then the average 120 4 stroke glow and about the same as a 120 2 stroke glow.
How much drag and the wing loading is whether or not you would have to fly at full throttle, so probably not. As a matter of fact I would bet you could fly that scale like with an OS 60 glow. But the 20 gasser will be more fun.
I have 2 of the 20's. I kind of use 11-12 lb as the cut-off for the switch to the 30. Because mild is not enough power for me.
#1524
IL
No not for mild flying. The 20 would be 1.2 to 1 ratio on your plane. I like WILD power to wieght ratio 2 to 1 is perfect for me.
Without tapered wings and large control surfaces or pylon type drag, the 20 will be just right.
