Needles working loose - help!
Old 07-22-2011 | 06:58 AM
Default Needles working loose - help!
So I'm thinking my needles are working loose, which is why my tuning is being such a pain. After all my tuning, I checked my needle settings last night, and the low is at 1 3/4 still. I know I have leaned it out more than that. I'm going to double check when I go out this weekend. Does anybody have any tricks for tightening up the needles? Can I put a little loctite on the threads and let it dry out prior to screwing it back in, or can I just put a dab with the needle still installed to hold it? Any help would be appreciated, thanks!
Old 07-22-2011 | 07:14 AM
jedijody's Avatar
Default RE: Needles working loose - help!
Teflon tape.
Old 07-22-2011 | 07:59 AM
Saw a person with guide tubes for adjusting touching them and wore them out with the vibration, Then it was new carb time!
Steiny
Old 07-22-2011 | 08:22 AM
Shim the springs on needle,s if has them,if long needle,s w/no spring cut them down and re slot,you really don't want any material in there,good luck
Old 07-22-2011 | 09:29 AM
Lnewqban's Avatar
Sorry to say that your ideas are bad and that the ideas advised in the previous posts are good.
Old 07-22-2011 | 09:30 AM
Like Jodi said OR
counterbore the needle threads vey slightly. Place a small O-ring and a washer under the spring. The compressed O-ring will keep the needles put.
Old 07-22-2011 | 10:39 AM
nonstoprc's Avatar
My Feedback: (90)
Or locking liquid or very small amount of epoxy.
Old 07-22-2011 | 11:47 AM
ORIGINAL: Lnewqban
And you would suggest,What?
Old 07-22-2011 | 11:53 AM
MetallicaJunkie's Avatar
i had that problem with a Toiletson carb.... i snugly wedged little a piece of hardwood between the two needles and used 2 zip ties... problem solved, LoL and i blamed 3W...its my favorite engine, now equipped with a Walbro [8D]
Old 07-22-2011 | 12:08 PM
ORIGINAL: MetallicaJunkie
Mine's a tillotsen on a ZDZ 80 RVJ
Old 07-22-2011 | 12:19 PM
WJ 71 solves ZDZ80 carb issues,hmmm tilotson,does it have long needles cut them shorter and re slot for tuning
Old 07-22-2011 | 12:43 PM
ORIGINAL: skip1320
thats it!!!...the WJ71 i love that carb... it's what DA puts on their 85s
Old 07-22-2011 | 12:44 PM
wyo69cowboy's Avatar
I put a short piece of Tygon on the low needle(about 3/4" long); it just rubs on the HS needle enough to keep them both from turning. It also helps me guide my screwdriver onto the needle when adjusting thru the cowl...
Old 07-22-2011 | 03:20 PM
Thanks, I know about the WJ71, and no needles are not long needles. I'm trying to fix it myself if possible as I'm on parental leave for another month, so trying to do this on a budget for this summer! Thanks for all the replies. I might go out tonight and see what's going on. Cheers.
Old 07-22-2011 | 08:20 PM
How much time do the bearings have on them and do you use after one oil? A bad front bearing can cause air to leak into the case making tuning frustrating if not impossible.
Old 07-22-2011 | 08:36 PM
There's only a few tanks through the engine. I'm assuming you meant after run oil? I have never used after run oil in a gas engine.
Old 07-22-2011 | 08:46 PM
After run oil in a gas engine? That's a new one. For the glow to gas newbies, gasoline is not hygroscopic and the pre mix oil is a far better lubricant than any after run oil one might think about using. Shorter version is one does not use after run oil in a gas engine. That's a slimer activity.
Old 07-23-2011 | 02:09 AM
TEFLON TAPE....
Old 07-23-2011 | 03:38 AM
ORIGINAL: charlie1960
TEFLON TAPE....
Teflon tape is good...just wrap it around threads in the right direction so that it tightens in place and make sure not to get any tape where the taper is on needle. Good Luck, Capt,n
Old 07-23-2011 | 06:58 AM
My Feedback: (110)
you can use a drop of c/a glue on the threads only. let it dry for a few hours. it will make it a little hard to turn but won't lock it up. ajust it and it will hold it there,and allow you to ajust it again a little bit..........RON
Old 07-23-2011 | 07:08 AM
ORIGINAL: Tired Old Man
I've used 2 stroke oil to winterize it. I might try fogging spray this winter, I think I still have some around from my old sled.
