MLD 35 problems
Old 10-02-2012 | 07:38 PM
Default MLD 35 problems
My MLD 35 will not suck fuel with the choke closed. I have to prime it to start.
Any suggestions on solving this problem?
Old 10-03-2012 | 12:19 AM
3136's Avatar
Default RE: MLD 35 problems
Check the reeds, if they are not closing properlyit will not draw fuel.
Unscrew the 2 bolts holding the carb on and look at the reeds, if there is a gap it needs to be corrected.
Also sometimes the black insulator block can be cracked, or the screws not tight and drawing air.
Regards Mark
Old 10-03-2012 | 08:37 AM
Thanks Mark,
I will check as you suggest,
Russ
Old 10-03-2012 | 08:42 AM
BarracudaHockey's Avatar
Also make sure the choke plate is closing completely, and if you have to, solder over the hole.
Check the reed seating first though.
Old 12-29-2012 | 07:29 AM
CERMARK is no longer the distributor of MLD , any question please contact MLD([email protected]) or SDShobby
