DLE 30 Problem
Old 12-10-2012 | 12:01 PM
Default DLE 30 Problem
My DLE 30 engine surges all the time. I have replaced the carb and I also checked to see of it was a radio problem and it is not.
The engine will not hold idle, it will move up 400 to 600 rpms and then back to the original setting and it surges at full power as well. I have resent the carb needles and this doesn't help either. Has anyone run into a similar problem and come up with a resolution?
Old 12-10-2012 | 12:50 PM
Default RE: DLE 30 Problem
Have you checked the sreen in the carb.?
Bob
Old 12-10-2012 | 02:20 PM
The carb screen is clean.
Old 12-10-2012 | 02:40 PM
Good air flow through the cowling ? Velocity stack ??
Bob
Old 12-10-2012 | 02:49 PM
My friend DaleD had a similar problem with his DLE 30. He tried everything including carb cleaner, new diaphrams, repair kit, the works and nothing worked. Replaced the stock carb with a new Walbro and all was well again.
Karol
Old 12-10-2012 | 02:50 PM
All testing done with cowling off.
Old 12-10-2012 | 03:04 PM
KAROLH please see if you can find out the model number of the Walbro carb and if it was a genuine Walbro.
Old 12-10-2012 | 03:38 PM
He replaced the stock carb with a Walbro WT759 which is discontinued and might be difficult to find, but a WT739 will do just as well.
A quote from Jody, "If one must have a Walbro there are many that will work well, all are 28-34/64" venturis, ones I've tried that work good are 739, 759, 645, and 805."
Karol
Old 12-10-2012 | 03:49 PM
All Day Dan's Avatar
Tony, here's a ridiculous thought. Make sure that you throttle servo is good. A worn feedback pot will give you those symptoms. Dan.
Old 12-10-2012 | 05:18 PM
Karol, thanks for the info on Walbro carbs. Dan, the first thing I checked was the throttle servo and it isn't the culprit. I will try a Walbro carb.
Thanks to all for your help, it was much appreciated.
Old 12-10-2012 | 11:55 PM
ORIGINAL: Tman
Have you check the engine timing.........my dle30 was at 35BTDC and gave me fits tuning the needles .......mine was hard starting and when it was running it just seemed like the needles and idle were all over the place.... 28 degree BTDC solved my problem.
Old 12-11-2012 | 04:04 AM
Checkist, good point about checking the timing. I haven't done a timing check before but know someone who has experience with timing issues.
Old 12-11-2012 | 05:56 AM
MetallicaJunkie's Avatar
ORIGINAL: All Day Dan
+1 ive had that happen to me.. it only would act up with the engine on....It was a headache diagnosing that one
Old 12-11-2012 | 07:39 AM
ORIGINAL: MetallicaJunkie
+ 1 on the servo pot I just had one go bad on another planes throttle the servo would reverse 3 to 4 trim clicks as I advance the throttle and then reverse back and go the propper direction during throttle up...............first servo I ever had that reversed directions on throttle up or trim changes..........those things give you gray hair for sure. Changed servo solved problem.
Old 12-11-2012 | 08:05 AM
I really don't think it is a throttle servo problem. With the cowl off the servo and connection are clearly visible the servo arm did not move and just to be sure it wasn't the servo we held the servo arm so that it could not move and if it did we could feel it moving. It was the first thing we thought of when the engine acted up.
Old 12-11-2012 | 08:16 AM
CK1's Avatar
CK1
My Feedback: (60)
Reset the timing to 30 degress BTDC and retune . every new DLE 30 I have checked has had the timing set too high usualy above 35 deg and some as high as 45 deg BTDC , The high timing makes starting and tuning more difficult and also has caused surging. Also be sure you have a CM6 plug and not the chinese knock off plug that came with the engine.
Old 12-11-2012 | 09:04 AM
Milton's video will help ypu with the timing. Dan.
http://www.youtube.com/watch?v=GBXFpxWg7vY
Old 12-11-2012 | 09:36 AM
Could a leak at the reed block cause the same issue?
Old 12-11-2012 | 12:08 PM
I plan to work on checking the timing tomorrow and regarding the question about the reed block, I installed a new one last week.
Thanks for all your interest.
