Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Gas Engines
help with small gas engine selection >
Old 11-29-2014 | 06:13 PM
My Feedback: (12)
Default help with small gas engine selection
I am looking for a small gas motor what will be in the power range of a .60 2 stroke or .90 4 stroke. I am looking at the evolution engines and the 10 cc is rated at the same hp rating as a 90 size 4 stroke. Seems wrong being the 10cc is only a .60 engine. Are the hp rating of evolution motors over stated? I am also looking at the 15cc evolution but for the same weight the dle 20 and vvrc 20 are the same weight. Pretty confused as to what route to take. I need to decide before the weekend is up being if I go evolution they are on sale.
thanks
Jeff
Old 11-30-2014 | 05:31 AM
Jeff, might help if you were to supply wing area, weight and wing span of the plane you're going with. Otherwise, for comparable power, just compare commonly used prop sizes on the engines you're considering. Not suggested prop sizes, ones guys are actually using.
The Evo 10 works good on larger .45 size, and smaller .60 size planes. How good will depend on what you're expecting from the plane. E.g. will this plane be flying more scale like, more sport, or 3D? I've found pretty good performance on planes in the 6-7lb range, with maybe 650 sq. in. wings.
Old 11-30-2014 | 05:57 AM
flyinwalenda's Avatar
My experience with the 10cc has been on the Hangar 9 Meridian and a scratch built Kaos type plane;both between 7-8 pounds.
The 10cc's fly them fine and I can perform almost any aerobatic maneuver . If you are looking for 3D ,unlimited vertical, etc.. on a 7-8 pound plane then you might want to consider the 15cc. As already mentioned it really depends on the airframe you are going to fly.
I also run the 15cc on a 90 size Cessna(stick built) and being a heavy plane it pulls it around great.
Tell us what plane you will be flying and how you want to fly it and we can better help you.
Old 11-30-2014 | 07:03 AM
My Feedback: (12)
Hey thanks for the offers of help.
I have the hanger 9 katana 50. It will probably be in the 7 to 7.5 lb range and wing area of 825. I am not radical 3d pilot. I want to do imac style maneuvers and maybe some beginner 3d stuff like harriers and flat spins. Just leary of putting to much weight on the plane and having a flying rock. I am kindof leaning towards the 10cc but dont want of have this model fly like the previous katana that I had with a .70 surpass. It needed all the engine could give and mush it way up till it got some speed then it would fly ok.
thanks
Jeff
Old 11-30-2014 | 07:35 AM
Sure, I remember discussing this question on the 10GX thread.
http://www.rcuniverse.com/forum/gas-...l#post11924683
Old 11-30-2014 | 08:50 AM
My Feedback: (12)
Yea that was me posting there also. I am terrible about making up my mind and always seems that I make the wrong decisions.
Jeff
Old 11-30-2014 | 08:59 PM
thanks
Jeff
I am flying a DL 20 in a hanger nine Katana.Power is awsome but that is what the throttle stick is for.Balence came out right on,Useing 15x8 three blade for prop clearence.Also flying two Hanger nine funtanas with DL 30 and DL35 Rear ext.Again just right for power and balence.All three I rebuilt from some bodies elses crashes.One I had to completely recover.Some day will learn how to send pictures again.
Our Indian summer is over in Wy. But was 54 Thanks giving day and no wind.I had to go to Denver(ugk).
BCCHI AMA 2500
Old 11-30-2014 | 09:08 PM
thanks
Jeff
I would go with the VV 20.Smaller and same weight as EVo 15.I have a VV 20 in Phoenix models Edge 540 for .90 engine.I think the Evo will be much nicer engine with the new pumper carb set up.
BCCHI
Old 12-01-2014 | 05:07 AM
BCCHI, it is very good to see you back on RCU. I hope all is well with you and yours and I wish you all a very Merry Christmas.
Sincerely, Richard
Cub Brotherhood #187; Sig 1/4, H9 100 inch (Gen 1), GB Anniv Cub
Club Saito #635; Saito 56, 100, 120abc, 130T, 180
Kadet Brotherhood #96; Mk 1 Kadet, Kadet Junior,
Sig Kougar, Sig 1/4 Cub, Sig 1/4 Spacewalker II
Old 12-01-2014 | 07:21 AM
Jeff
I not an impulse decision maker either! Better to take your time and get as many opinions and hard data as you can . Again, my opinion, I will stick with the 10cc on the Katana for everything up to 3D. If you think you may want to venture into 3D then get the 15. The added power will overcome the little extra weight.
