New ZDZ-80
#651
RE: New ZDZ-80
ORIGINAL: cyberchild
hey guys,
what is the best model flying weight for the motor? i have a 35% wild hare giles, plane weights about 25 pounds? wana strip plane to make it lighter. what is your thoughts
hey guys,
#652
RE: New ZDZ-80
Actualy wana make airframe lighter, wild hare kits are nice but manufactured very heavy, the plane is very snappy as well, wana take out unneccesary wood,
Thought of making it a toss-around practice plane, might make the plane more fragile, but if it goes, im planning on scrath building a 100" katana for the motor.
#653
TN
RE: New ZDZ-80
okay, I got it! it was something so stupid I'm embarrassed to admit it. one of the guys at the field was helping me with it the other day and took the fuel line loose from the carb and put it back on the wrong nipple. I can't believe I didn't notice it. well she's purring now. I apprecciate your help, Phil
#655
RE: New ZDZ-80
ORIGINAL: JoeAirPort
Sounds like there's too many nipples.
#657
TN
RE: New ZDZ-80
hey guys, I seem to be having some sort of vapor lock problem. I got the engine to start pretty easily on the first run of the day, but on the next one it would pop with choke, then come so close to running, but after 4-5 almosts it wouldn't fire anymore, do I have my needles too rich still.( I've been slowly leaning them out over the last couple of flights.) Is there anything I should do different? thanks again, Phil
#658
RE: New ZDZ-80
Here the procedure I use for starts following the first start of the day;
Ignition off
low throttle, three flips choke closed
three flips choke off
ignition on, usually starts first flip
Ignition off
#660
RE: New ZDZ-80
Mike Dooley and TBM both said to me;
Ign off, Choke on, throttle full 5 flips
Ign, off, choke off, throttle full 5 flips
Set for hi idle, ignition on, and flip to start. should start in a few if not the first.
Mine has been taking 3-5 but it is new and not fully broken in yet.
Dont be afraid to take out the spark plug and gently clean it with a toothbrush and gas or alcohol.
Im going from memory, but I think gap is .22 for super 80. someone correct me.
#662
RE: New ZDZ-80
ORIGINAL: pliebo
if the idle is set too lean or too open - starting is more difficult
it is a learning curve- set right the idle setting will start and run under/about 2000 rpm.
cold start - the multiple choke on flip(easy flips ) the choke off (easy flips) then check idle - turn on switch - it starts
this crap of swatting it like a horsefly just tires your arm and does nothing to start an enginelike this - it ain't an old magneto setup
you lean the needles based on how the engine runs not how many times it has been run
low needle allows for a slight hesitation when cold . then it is correct
high needle will allow engine to revup then slightly increase revs as it heats .
it really is simple if you think about the fact that heat is caused by a load and the engine is hottest when running full bore and not moving.
#664
RI
RE: New ZDZ-80
hey guys this is my first gasser so sorry for this question. i got through the throtle arm operation for the carburator now im stuck setting the ignition . i dont know how to set up the ignition magnet that connects to the engine shaft.at first i thought that you just hook it up and boila but now i know that it has to do with the timing of the spark.the latest number i got was 7mm tdc or something like that but this is all french to me so if somebody would please take 2 minutes and explain to me i would greatly appreciate it. i am a fast learner ... thanks in advance
#665
RE: New ZDZ-80
find the 2 holes on the fron of the engine where the pickup mounts, they are bout 1.5 inchs apart. There are 2 machine screws that fit them. THe sensor has a little *** in the middle that aligns forward over the little round magnet embedded in the rotating prop hub. There is a Web casting that sticks up right in between the holes on the motor. Looking at the motor from the prop(front) there should be 7mm distance to the right between the web casting and the middle of the magnetic pickup. It allows a basic advanced timing. Once power is supplied to the ignition,and the spark plug wire is attached, it will fire everytime your little round pickup passes under the pickup. To make sure everything works, you can install it, take the plug out along with the shroud arond the plug, and install the plug wire over the loose plug, it self grounds. and put battery power on the ignition, and move the prop shaft around and it will "tick" fire the plug.
That 7 mm equates to a few degrees of spark advance. Its also .27 inches or 1/4 inch. The edge of the pickup almost lines up with the web.
#666
RI
RE: New ZDZ-80
goose thanks a lot really for taking your time an explaining that. i really apreciate guys like you taking your time to teach us noobs . again thanks alot. i saw ur post at work so ill get to it as soon as i get home . have to work work work to try to finish my 33% sd yak.
#667
RI
RE: New ZDZ-80
hey goose sorry to bother you again , i got evrything you said except the web casting betwwen the holes on the motor . i dont know what part that it. i dont know if you were talking about the fins that stick out behind the prop hub. a picture would be greatly appreciated sorry for the inconvenience
#668
RE: New ZDZ-80
I measured the advance after setting the senser and got 8 degrees BTDC for those that might be interested, I don't understand why the setting in degrees is not provided with the engine? Most electronic advance ignitions are set about 5 degrees BTDC at idle.
#669
RE: New ZDZ-80
see the web casting sticking out...the fins..right. One on top , 4 total. Its on the other side. If the Round sensor lines up with the web on the other side the motor is at Top Dead Center. Pull the spark plug and you will see when the piston is fullup. THen the sensor mounts there. You can see the upper screw in the pic. the distance between that rib and the middle of the sensor *** that sticks out should be 1/4 of an inch. If you measured it in degrees it would be about 7-8 degrees of advance. Lookin at the motor from the front, the sensor shoud be to the right rotationally from the rib so that the round dot lines up with it just before TDC.
best I can do...on the road
#670
RE: New ZDZ-80
SD33% yak????? with this motor will be a roman rocket!!!!!!
What prop you gonna run?
Im running a NX 26x10 now and will switch to a 26A Vess on my Suky soon. Im at 25 pounds. You will and should be closer to 22 pounds. that thing will be ballistic. It will be a pleasure to fly, very light to the touch,
#671
RI
RE: New ZDZ-80
yeah thanks goose i will be running a 26 10 pt cf prop im still waiting for all my servos and batteries to get in so i decided to start up my engine in the meantime thanks for the reply i just wanted to make sure we were talking about the same thing. oh and by the way i have the zdz rv not the super J i think i forgot to mention so i dont knwo if it is the same spacing i would had thought YES but what do i know huh.
#672
RE: New ZDZ-80
Hi guys
I have ZDZ super 80 and i will install it on P51 Mustang from composite-ARF i have a quoestion if i put the engine in up right possition would it make any difference in the proformance that to put it in inverted possision or is it the same???
Ahmed
Ahmed
#674
RE: New ZDZ-80
Daniel
I was told by RCS that this pipe setup is the best for the Super 80 unless you get fancy and go with a tuned pipe which is a totally different "can of worms".
Cheers,
Lyle
Cheers,
Lyle
