More Engine for Edge 540
Old 12-24-2002 | 12:39 PM
Default More Engine for Edge 540
One of my current planes is a 72" Edge 540T from giantscaleplanes.com. The plane is currently set up with a Zenoah G-23 (Kalt Heli Version) turning a 17x8 prop. The plane flys great but lacks the power for 3D. I will give the little Zenoah credit though, it will hold a hover for about 8 seconds before falling out. I have been looking into the ZDZ 40 Sportsman enigne but also have been reading alot on the FPE 2.4. I have been leaning towards the ZDZ mainly because of weight and price. I should be able to swap out the G-23 to the ZDZ 40 with very little change in weight. The plane currently has a dry weight of 11 lbs. Am I on the right track here ????
Scott
Old 12-24-2002 | 01:27 PM
check out the new g26 lots more oomph.
Old 12-24-2002 | 03:06 PM
My Feedback: (62)
Default Rear Intake
Does the ZDZ have a rear intake, and if so, will it be an easy swap?
Old 12-24-2002 | 08:09 PM
The ZDZ does have a rear intake, but mounting it should be no problem. I would just have to notch the firewall on the engine box a little.
I have been looking at the G-26 and am still kinda wondering if it will be that much more than the G-23. There is a guy here in Kansas City that can do a hop-up to the G-23 and give it a little more fire. I guess the main thing is I want to make sure I have enough power. If I am going to spend the money I want to only spend it once !
Scott
Old 12-24-2002 | 11:51 PM
Shortman's Avatar
My Feedback: (21)
i think you would be 10 x better w/ a OS 160 FX 2-stroke.. 2lbs and gobs of power for a plane that size and weight.... if u want to 3d/ then a gasser really isnt the best choice for this size plane
Old 12-25-2002 | 09:35 PM
h82crash's Avatar
Yup, the OS 160 should out pull all those engines and be a pound lighter. If you're worried about all the glow you will use, these are very efficient. About 1.5 oz/min at WOT.
