Air Hobbies Sachs Dolmar 3.2
Old 06-12-2007 | 05:59 PM
My Feedback: (12)
Default Air Hobbies Sachs Dolmar 3.2
I was recently given one of these engines and would like to know more about this engne, good,bad or ugly.
please share your experiences.
jeff
Old 06-12-2007 | 06:06 PM
Jake Ruddy's Avatar
My Feedback: (40)
Default RE: Air Hobbies Sachs Dolmar 3.2
Well I hate to be the one... but a simple click of the search button and Air Hobbies will return a ton of posts... mostly bad and ugly.
Old 06-12-2007 | 07:15 PM
TLH101's Avatar
My Feedback: (90)
They have a good piston and cylinder, at least before they covered it with the red stuff. If it has that monster muffler/mount combination, throw it away, and you can shed a ton of weight, and grief.
Old 06-13-2007 | 08:48 AM
My Feedback: (12)
TLH101, I did do a search and found very little about the engine. Sinergy, I plan to take that thing off but do you know if it will run
well once the muffler has been changed.
Thanks guys
Jeff
Old 06-13-2007 | 10:27 AM
TLH101's Avatar
My Feedback: (90)
I think RCU has limited the search function. It does not work to well anymore.
The engine is based on a Sachs Dolmar (now Makita Dolmar) chainsaw/cutoff saw, engine piston and cylinder, which are very good quality. Brison, Fox, FPE, and others all use the same components. I can't say about the crankshafts, though there have been builders in the past that just could not get them right. I have read of problems with ignition systems on the motors, but don't remember exactly what the problems were. Get a good muffler for a 3.2, don't use soft mounts, and you should have a good engine. Will turn props in the 20x10, 22x8, 22x10 range.
Old 06-13-2007 | 03:45 PM
I know nothing about that engine but I have a 3.2 FPE which is the same engine block assembly, I think. My FPE is two years old runs flawlessly on a SIG Sundancer bi-plane. It turns 7260rpm with a 22X8 PT Models CF prop.
Old 06-13-2007 | 05:13 PM
Jake Ruddy's Avatar
My Feedback: (40)
The cylinder and piston are fine.. the rest is a joke.. tolerances are way off the mark and their ignitions suck.
Use the search and click advanced and type in Air Hobbies should return a lot
Old 06-13-2007 | 05:15 PM
Jake Ruddy's Avatar
My Feedback: (40)
Here will save you the work... search function works fine if it's used properly http://www.rcuniverse.com/forum/sear...mitbutton=+OK+
