Tecumseh Engine
Old 03-06-2003 | 03:42 AM
Default Tecumseh Engine
OK Guys, I was poking around the 'net and came across an engine supplier that has Tecumseh 2 stroke engines in 49cc, 85cc, and 139cc. Anybody have any experience here? They have float type carbs that would have to be replaced. No weight figures were listed (that I saw). Also the Honda 31 (available for $180 + sh), any possibilities this would work well on a Dymond 100" Rearwin Speedster? 4 stroke would sound cool!
Old 03-06-2003 | 03:55 AM
My Feedback: (27)
can you share the site with us plz. have here what may be a similar engine in a briggs 2 stroke engine, 141 cc will go in a 1/2 scale pietenpol.
Old 03-06-2003 | 04:07 AM
www.tulsaenginewarehouse.com Look at the 40cc Mitsubishi engine
www.smallenginedeals.com Look here also
Sorry, they do have weights listed for the Tecumseh.
Old 03-09-2003 | 02:59 PM
My Feedback: (27)
Not my engine but someone has the idea already.
http://cgi.ebay.com/ws/eBayISAPI.dll...category=19164
Old 03-09-2003 | 03:43 PM
Saw that already, that's what gave me the idea. But I don't know this person and figured I see if anyone here had done it.
Old 03-09-2003 | 06:51 PM
Antique's Avatar
I converted two of these about 10 years ago, was not impressed with the power..Tecumseh was the only company that was not adverse to using their engines in model airplanes....
Old 03-09-2003 | 09:28 PM
Those engines you converted, are they the same as the current crop? If yes, then it's a dead issue. If they are not the same, then maybe a revisit is in order?
Old 03-09-2003 | 09:53 PM
That little honda is a great engine. A guy in our club has one and it will run all day on a tank of fuel, and provides pleanty of power.
ZB
Old 03-09-2003 | 11:06 PM
Antique's Avatar
It was a long time ago, there were two versions, one with a roller bearing on the front and the other with a roller...I converted the ball bearing versions...Maybe they have changed.....Seems like they ran about like a G38, 7000 rpm with a 20-8....
Old 03-10-2003 | 04:40 AM
Then maybe an experiment is in order here. Maybe when I'm done my Ryobi 4 stroke, I'll take a look at these.
Old 03-11-2003 | 05:57 AM
OK think I might be on to something here. Found a place to get a Tecumseh 98cc 2 stroke engine, new for under $90! The only catch, you must be a dealer. RCIGN, any possibilities here? I'll cough up the bucks if it looks like a viable option. Man can you imagine the possibility of a 98cc engine for under $350!!!! Even if it required some work to increase the hp.
Old 03-11-2003 | 06:18 AM
Antique's Avatar
I'm a dealer for Zenoah, Aerrow, and Walbro...Don't know if that would do....
Old 03-11-2003 | 11:42 AM
My Feedback: (27)
There is a place in town that will order it for me no questions asked called northerntool.com
Old 03-11-2003 | 08:38 PM
jackumac, what will they charge for price?
Old 03-12-2003 | 04:29 AM
My Feedback: (27)
i can call them if you have a specific part number. jack
Old 03-12-2003 | 04:36 AM
where is this place to get them.I will get it and check it out. my uncle runs the shop at fisher implement .
Darin
Old 03-12-2003 | 06:22 AM
Tecumseh model # HSK600 (cheapest version). Also check HSK635.
Old 03-12-2003 | 02:46 PM
This is the response I received from Nortern Tool.
Thank you for the email.
Currently we are not offering this make and model Tecumseh but do appreciate your checking with us! We may be able to cross reference it to another model with the shaft size (length and diameter) as well as bolt pattern measurement on the base measured diagonally.
Thank You!!!
Hal
www.NorthernTool.com
Customer Care
Northern Tool & Equipment
1.800.221.0516
Maybe you'll have better luck than I did!
Brian
Old 03-30-2003 | 01:30 AM
Well got my 138cc Tecumseh in today. First weight figure: 24.2lbs! After breaking it down: 9.0lbs! What a drop in weight. I still have more to take off though, this may shed yet another 1 to 1.5lbs. My target weight was 8.0lbs bare. Most 150cc twins range from 7.25 to 8.5lbs bare so I think I'm on the right track. I have a 49cc coming on Monday so that will be next for some weight figures.
Old 03-30-2003 | 01:31 AM
The other side.
Old 03-30-2003 | 03:50 AM
My Feedback: (27)
Have one of the 141cc Briggs singles close to a test run. Am planning on a 30x8 PK prop for it.
Old 03-30-2003 | 05:38 AM
I'd like to see a pic of that one!
Old 03-30-2003 | 02:40 PM
My Feedback: (27)
send a note, have yet to successfully add an image to a post. [email protected]
Old 03-31-2003 | 05:40 AM
My Feedback: (29)
this is a great idea. I was thinking the exzact same thing while looking at my snowblower over the winter, and less than a 100 bucks for a long block?? to cool. Are you guys gonna use a ch ignition for your engines? I would love to see a pic after there done!!
Old 03-31-2003 | 11:11 AM
Most likely some type of electronic ignition. Flywheel and cdi are about 8lbs!
