DL-50 engine
#4002
RE: DL-50 engine
ORIGINAL: basman
do you have to use a spark plug with a resister eg plug that end with a R, to avoid interferance with the radio gear ? I noticed some said that a NGK CM 6 was the go but I do not know if this is a resister or not.
Just use NGK-CM6
Cheers
#4003
OH
RE: DL-50 engine
does anybody know if DLusa is selling the 55 yet. i tried calling several times and sent a email and no response. tbm has them but the one year warranty is parts only and i thought DLUSA has one year parts and labor.
#4004
UT
RE: DL-50 engine
Got a DL 50 the other day and mounted it. First time using standoffs. I used a 5 mm bolt and a fender washer through the firewll and into the standoff. Is that the normal way to mount them? Thought about a blind nut with a bolt through it and then gluing the bolt so it won't turn, then it would be a stud to screw the standoff onto, but I chose the simple bolt.
I don't like the plug cap. Hard to get on and harder to get off. First time I pulled it off the spring went flying. Didn't find til an hour later, and that was by chance, as I had given up the search earlier. Removing the plug and such would be a pain at the field. I would like to see a better design. The set screw caps work great I think. Just my two cents.
Everything else looks good. I can't wait to get it in the air.
#4005
RE: DL-50 engine
Sorry to change topic. But can any body tell me where to get the best props and price? I see that DL usa sells them with the holes in the already if you like right? And they are about 28 bucksis this good? I can't find them at the LHS only one and it was carbon fiber and it was $61.50. I am down to the prop and servo's. But all I can do is look as I said the tree is dried up. I run a hitec 82MG for my servo for my throttle and it seems to be fine. What do you guys use on yours? You know the 82 mg in a small servo, but the throttle is like 2" away from the servo. So please tell me what you think. Thanks Eric
#4007
RE: DL-50 engine
ORIGINAL: giddyuperic
For a tuned pipe setup a digital on the throttle is quite crucial for a smooth throttle curve. Engines on a tuned pipe tend to be very responsive at low throttle positions.
And props: yes $28 is a good price. I got mine from DA when I ordered a tuned pipe setup. I love the Vess props. My $0.02
#4008
CA
RE: DL-50 engine
mustangflyboy1,
There is an easy way to get the plug cap off. Just get a flat piece of steel about 5/8 to 3/4" wide by about 1/8" thick and 8 to 10" long. Wrap it back a few inches from one end with electrical tape. Then just place one side of the wrapped end between the plug cap and the head. The tape will keep you from marrint the head or the cap. Apply a little twisting motion to the steel and it will pry the cap right off. Very easy and works like a champ for me every time with my DL.
Personally, I like the really tight fit that the cap has. You probably will too after you make this little tool.
#4009
RE: DL-50 engine
Found the HS-5245MG 44 bucks but I can't find the other 0ne. What is the price on that one? I can wait if I have to and it means a better throttle servo
#4010
RE: DL-50 engine
http://www.servocity.com/html/hs-5065mg_servo.html
#4011
MO
RE: DL-50 engine
just my opinion.
T.J.
#4012
WI
RE: DL-50 engine
Hopefully I'll be firing up my DL-50 this weekend. It's all mounted on my test stand ready to go.
Question. I drilled my Vess 22B with 2 holes inline with the prop blades and the other 2 across the hub. If I find that the position is not ideal for starting is it OK to drill another set of holes at 45 degrees to these or would that weaken the hub? When I flip it the way it is now I'm moving down more so than to the side and I'm afraid that when mounted on the plane this will present a problem.
Mike
#4013
RE: DL-50 engine
I would not dill a nother set oh holes it will weaken the hub to much and you dont want it to come at you. I drill my blades just as you have and they work great you had is coming of to the side of air frame and when you kill the motor the prop is side ways to the airplane. you will be just fine.The Road runner
#4014
RE: DL-50 engine
Gooodmorning to all Now would that be the x pattern that I hear people talk about? I am going to buy a vess 23a and they said they would do that for me.
#4015
MN
RE: DL-50 engine
Here is the warranty as stated by the big two US distributors. And Australia.
http://www.rcaerobats.net/GAS_ENGINE...informatio.htm
#4016
WI
RE: DL-50 engine
Wow. Bob really needs to update his website. This is what it says right now on dlusa.net and like I said, it's hard to find.:
From the FAQ section
Perhaps I missed it somewhere, but what kind of warranty is being offered?
The manufacturer's warranty is that "the engine will be free of defects at the time of sale". In addition to the manufacturer's quality control procedures, we inspect all DLUSA engines prior to shipment to customers so material defects should be caught before they get to customers. We don't test run them though so something may get passed us. If it takes you 6 months to get your engine in the air and you then find out the carburetor for example is defective, it will be repaired or replaced upon return to us.
It's good to know that my engine has a one year parts and labor warranty as it will be at least a few months before my Spacewalker will be ready to fly.
Mike
Mike
#4017
RE: DL-50 engine
I would like to know if you guys break in the DL-50 with a diffrent size prop or do use what you are going to run? And what is the most used prop does any body know? I think I am going with the vess 23A
#4018
My Feedback: (42)
NC
RE: DL-50 engine
I use the Vess 23A on my yak and Edge for every weekend flying but one of the object of breaking in an engine is to have a lot of RPM with out the over heating so yes I could use any prop but I know better one should use a 22/8 for the beraking in, as it has ben mention many times in this forum,
#4019
CA
RE: DL-50 engine
I have never used a "break in prop" yet. I always buy what I want to fly with. Set the needles correctly from the start and go easy for a few tanks fulls, that is all that is needed, and I usually only go easy for the first flight if I can restrain myself
Why waste money on a prop you might not ever use again?? A Vess23a would be a good prop for this engine.
#4020
RE: DL-50 engine
ORIGINAL: RTK
I have never used a "break in prop" yet. I always buy what I want to fly with. Set the needles correctly from the start and go easy for a few tanks fulls, that is all that is needed.
Why waste money on a prop you might not like?? A Vess23a would be a good prop for this engine.
#4021
RE: DL-50 engine
All I can say is DON'T. Don't overload the motor before its broken in. Use a slightly smaller prop for break-in. A Vess 22B is perfect. Don't use synthetic oil to break in the motor, especially not mixed at 100:1. If you want to enjoy a powerful motor for a long time do what the experts do also. Use a quality, ashless petroleum based oil, such as Pennzoil for aircooled motors and a smaller prop. All moving parts need to wear in first before the motor can be "abused". Run at least two gallons of 32:1 mixture before switching to synthetic. Don't mix the synthetic less than 50:1, if you love your motor. If you don't then do what you think is better.
#4022
My Feedback: (42)
NC
RE: DL-50 engine
Thank you,
You are 100% right,
Keep in mind that the manual for an engine that the manufactures put out is only to waste paper only?
Disregard the many years that it takes to develope and fine tune an engine for competitive production and sales and what the engineers find while testing the engine with diferent types of oil as well as the conclution of all test, when all ells fails read the manual it really does work.
You are 100% right,
#4023
RE: DL-50 engine
My comment was meant cynical
I do exactly as you describe except that I'm using Amsoil Saber 80:1. DL50, MTW RE2, Vess 23B, 89 80:1 gas, 7200 rpm, 34lbs thrust.
