DL-50 engine
#6052
DC
RE: DL-50 engine
ALL my #7 drill bits, along with the rest of the world ,are .201
Where did you get a .1995 #7 drill ????
Or get a drill bit size chart..
#5 is .2055
#6 is 205
#4 is 209
Or a new mic
#5 is .2055
#6 is 205
#4 is 209
Or a new mic
#6054
MO
RE: DL-50 engine
ORIGINAL: Born2Fly
Quick question. This thread is quite long to read it, but I am sick and tired of my DA 50 that I had problems for the last 4 years and crash my 30% Extra 2 days ago because of the dead stick on the inverted flight at low altitude. Anyhow, would you recommend getting DL 55 as a replacement? Or should I look somewhere else.
Right now I just couldn't justify paying the extra $200-$250 dollars for a DA when the DLE pumps out just as much power or more and will last for just as long, its lighter, has pretty much the same warranty (depending on where you buy it from) and parts are cheaper and can be found all over the place.
Just a couple numbers to compare with when we tried the same prop... it was a Vess 23A, he was getting 7450 with his DA-50 with red line 50-1 mix and about 10+ gallons of fuel through it. I'm getting 7500+ with the Vess 23A, I'm using quicksilver outboard oil at the break in 32-1 mix, and I've got about 3 gallons through it now.
I didn't get mine from Jody at Valley View because I got it as a combo with my plane but I hear he is a great guy to deal with.
#6056
MO
RE: DL-50 engine
ORIGINAL: unit53
sup ,,,,,t,,,,,,,[img][/img] your friend from youtube,,,norm53
#6057
CA
RE: DL-50 engine
im a real moddeler like you bro,,you might find my cheap self anywhere ,,plus i own a old beat up dl 50 that still runs strong,it needs bearings and still runs good,,yeah check my youtube theres more ,i saw yours ,,too bad they took my stars away but ido segev still subscribes
#6059
RE: DL-50 engine
No. It will not fit into your crankcase. The crankcase on the 55 has been milled to a larger diameter. Unless you have access to a mill to do the clearance work you will have to buy the crankcase as well. At that point you may as well buy a new engine. To convert you need the piston, ring, base gasket, cylinder, and crankcase.
#6060
UT
RE: DL-50 engine
Thanks for the info. My neighbor works in an aircraft shop that builts air plane parts for the air force. I'm betting he could do anything I needed done.
#6063
MO
RE: DL-50 engine
ORIGINAL: rcfan450
I guess that will thwart the whole idea then
#6064
ID
RE: DL-50 engine
Sorry but you can't just bolt up a 55 cylinder to a 50 case W/O doing some mods to it first. Theres a 2 mm difference in the bolt hole pattern and the register stub that aligns the cylinder to the case.
#6065
My Feedback: (24)
TN
RE: DL-50 engine
Ok guys here is a question, I have 3 DL 50's and a friend has 1, i had to replace the crank assemly because the rod bearing gave way on two of mine and my friends just went out on him this seems to be the week point in this engine. Can we press the pin out and get a better bearing that will not give out on us? If someone has already done this let me know.
#6066
RE: DL-50 engine
Not sure how you would hold the crank to press the pin out, the throw face is only about .020" larger than the OD of the rod and they are in very tight, heat will expand both the pin and crank throw simultaneously. Pressing it back in would be easy, good luck.
#6068
My Feedback: (41)
RE: DL-50 engine
ORIGINAL: digtman
Now that I almost ran 2 gallons of fuel at 31:1 ratio woth lawnboy oil, what's the best oil for 50:1 ratio?
Any Stihl chain saw dealer will have it or can order it. It comes in white or grey bottles. They seemed to have changed colors to grey.
PS: A lot of gunk is going to wash out of your engine at first. Lawnboy makes black tar at the exhaust port.
#6069
RE: DL-50 engine
ORIGINAL: craigteffe
#6071
RE: DL-50 engine
I could be wrong,Dl/DLE dont supply the crankpin separately and to have one made would probably exceed the cost of a replacement crank assembly and still have the original problem of wanting to replace the original needle roller from a known quailty manufacturer.I would try something as simple as 30mm plate steel drilled and slotted to clear rod and crankpin with crank securely clamped via the crank web to the plate and the whole assy mounted in a press.Place drift over crank pin centred under press ram and load the pin.Apply and concentrate heat via oxy/acetylene to outer diameter of crank throw immediately opposite crankpin,weight/load the pin via the press and hopefully the pin will move and can be pressed out without bending crankthrow.If successful,clean and inspect then reassemble with new bearing using loctite super retaining compound on mating surfaces of crankpin to crankthrow having first chilled the crankpin,press together.
#6074
RE: DL-50 engine
Looks like I need to ask for advice! I tried to start my DL-50 for the first time today. It has never been run, and I got it about 2-3 years ago from Valley View. I finally finished the Extra for it, and wanted to see how the engine would run today. I couldn't get her to fire at all. Fuel seems to be pumping to the engine, as I could touch gas under the carb. I charged the ignition battery a little more to see if that helped, but no. So I switched to a new battery and that did not help either. Suspecting the ignition, we switched it to my son's plane with the DLE-55 on it, and it ran fine, so I put my ignition back in my plane. The clear blue tube for vacuum looks pliable and new, so I don't think that is a prob. I also switched to another new CM-6 NGK plug and it did not make a difference. Priming the engine with the ignition on, choke on, and throttle at full, fuel moves to the carb as I said before...there is gas dripping under the carb. But the engine won't ignite at all after no matter how many flips. Compression seems kinda weak compared to my son's DLE-55 and even to my glow engines. I have the low and high needles set at 1.5 turns open for starters.
My only idea so far is to switch that clear blue tube for vacuum to Tygon, and to try opening both needles. Any ideas? Thanks. Jon
#6075
RE: DL-50 engine
Verify thatit has spark first, if it does, does the plug get wet?Closed choke and full throttle can easily flood the engine, leave the throttle at a high idle position. Choke on, ignition on, flip till it barks, choke off, flip about 5 or 6 more times and it should take off.
