Roto 50 V2 question
Old 12-08-2007 | 08:43 PM
ossie's Avatar
Default Roto 50 V2 question
Hi there, hope some one out there can help me out.
Have a 1/3 GP pitts special that needs an engine, and would like to try a twin cylinder engine.
Would anyone know the dimension from plug cap to plug cap on the Roto ??
Want to make sure it fits neatly inside the cowl !!
I have a couple of 50cc singles in other models, but this time I'm looking at a twin.
Cheers
Ossie
Old 12-08-2007 | 10:16 PM
wingburner's Avatar
My Feedback: (17)
Default RE: Roto 50 V2 question
http://www.rcshowcase.com/images/eng...s/roto50v2.jpg
You can likely add 60mm to include the plug caps.
Old 12-09-2007 | 05:16 PM
ossie's Avatar
Yep, knew about the 214mm cyl head to cyl head dimensions, but looking for an accurate plug cap to plug cap length.
I sent an email to RC Showcase a while ago seeking the information, but never got a reply.
Is there anyone else out there that can help me out ??
Old 12-10-2007 | 04:34 AM
Ossie..
I have this engine in my Pitts. The plugg caps are touching the cowl slightly :-(
I have only flown this combo twise, but without the cowl. I have not decided if I will try to fly with the
caps as they are, or if I will make holdes for the caps. I have reinforced the spot where they toutch.. Will see..
Anyway, LOVE this engine...
Best regards
Sandman
Old 12-10-2007 | 05:47 AM
ossie's Avatar
Thanks for the reply Sandman,
I'd be keen to hear your thoughts on the model and engine combination.
From what I've seen the Roto is a real smooth running engine.
Cheers
Ossie
Old 12-10-2007 | 07:38 AM
Ossie..
This is a great engine, easy to start. Pulls a Menz Ultra 22x10 til 6700RPM. Nice throttle respons.
And viritual vibration free... I did take my time to get to know this engine, by a long breaking in periode
in a bench... It has a nice steady idle, and a good transition. there is a "rough" spot a aprox 2500RPM, but this is very little compaired to a ZDZ 60 that I was running at the same time.. All in All a great little twin.
This engine will stay in the Pitts, holes in the cowling or not :-)
I have not had the time (or weather to be precise) to fly the Pitts more that 2 runs. But the take of run was short, and I had a lot
of pull.. This plane must be one of the more easy plane I have ever landed ,just pulls the throttle to idle, and point the nose slightely
down, flair just above the runway.. Very easy to land..
Good luck on yours..
regards
Sandman
