Area 51 engines
#51
My Feedback: (24)
GA
RE: Area 51 engines
Kevin
Glade you got aboard, I know that a lot of people like to see the manufacture on the forums to back up and give information about there products.
Milton
Milton
#52
RE: Area 51 engines
milton!
thanks for your commend,i hope every guys can try to attempt our engines( Area51 and Area102),i believe them will like our engines.i will keep hard work for every guys!
kevin
www.jcengine.com
#54
RE: Area 51 engines
hi Bo !
how are you? our factory was designed some tools , i think of just few days later i will show some pictures to you and if you have interest in our small tools, when you see pictures later you may contact Milton.he will let you know it's cost.
many thanks !
kevin
www.jcengine.com
#58
RE: Area 51 engines
#61
My Feedback: (24)
GA
RE: Area 51 engines
Tim
If I take the engine out of the original box and put it in a USPO flat rate box shipping would be around $40.00 US.
Check with Paul at http://www.gashanger.com/ and see if shipping from him would be better.
Milton
Milton
#62
RE: Area 51 engines
Hi Tim
Hi Milton
Just checked the rate fron UK, and you can double it and add a bit before I even start to get close,
at $40.00 that is a good rate don't think you are going to get better than that.
Paul
Hi Milton
Paul
#63
LA
RE: Area 51 engines
Hi everyone. Milton is the A.51 still $399.95 w/shipping and do you have it in stock. If so I will be calling you tomorrow. also what props do you sell and can i buy the drill jig from you. thanks.
Bo
Bo
#64
My Feedback: (24)
GA
RE: Area 51 engines
ORIGINAL: BOMYERS
Bo
Bo
Yes same price and in stock, No props in stock right now and a DA drill jig will work but you will have to buy it from others.
Milton
#66
My Feedback: (24)
GA
RE: Area 51 engines
Yes they are rated for six volts but some have failed because some 6 volt batteries will charge up to over seven volts and overload the ignition, CH ignition and Ralph say only to run on 4.8 volts also.
You gain nothing running them on six volts, no hotter spark at all just dump your battery sooner.
Milton
Milton
#68
My Feedback: (309)
CO
RE: Area 51 engines
I just wanted to make sure they could be run on a regulator up to 6v. I would probably run a 5.1v regulator with it.
What does the muffler that it comes with look like?
Thanks, Jim
Thanks, Jim
#69
My Feedback: (309)
CO
RE: Area 51 engines
ORIGINAL: RC Extreme power
Hammbone
Did you used to live in GA and fly at Jersey
Milton
Hammbone
Milton
Jim
#71
My Feedback: (24)
GA
RE: Area 51 engines
I thought that was you a while back when I seen some post you had made, long time no see, Hope things are going good for you.
Allen is grown now and still burning the sky as hard as he can, he is the one flying the planes in all our videos.
Milton
Milton
#72
My Feedback: (41)
RE: Area 51 engines
I would like the basic measurements of this to see how it can fit in my EF 88.5" Extra 300.
1) Back most part of of carb to the prop hub (choke butterfly is part that is usually the furthest point back...with choke open).
2) Center of jugg to prop hub.
3) Distance of center of muffler stack to prop hub.
4) how far muffler sticks out from prop hub center (to fit inside cowling).
Are stand off's included? If so what length are they?
My Feedback: (24)
GA
RE: Area 51 engines
OK here we go
Yes stand offs, muffler and ignition come with the engine
From back of stand offs to front of prop hub 6 1/2"
Stand offs are 2 9/16"
From choke butterfly to front of prop hub 6 1/4"
Center of jug to prop hub 3 1/2"
Distance of center of muffler stack to prop hub. 5 1/4"
how far muffler sticks out from prop hub center 3 3/4"
All dem are within 1/16"
Here are some video of the Extreme Flight Extra that you can see the muffler in the cowl
http://www.youtube.com/watch?v=rQtp-XURsOE
http://www.youtube.com/watch?v=KFgVLT4ZswQ
Milton
Milton
#75
My Feedback: (309)
CO
RE: Area 51 engines
O.K. Milton, I just ordered an area 51 from you a little while ago. I'll see if I can turn some of my Colorado flying buddies onto your engine and get you some more business.
Is an 85cc engine still in the works from you? If so, when might it be available?
Thanks, Jim
Thanks, Jim
