RCGF Engines
#4128
FL
RE: RCGF Engines
Hey All
We have sold MANY MANY engines. In spite of our quality checks and our vigilance, sometimes a problem engine will work its way to a customer. This is our nightmare and something we work to resolve to the customer's satisfaction. That is why we will do our best to make things right. And we have been extremely successful to date.
In fact... if we do find issues with this line of engines, and if we find that it is systemic (that is to say it could affect all engines in this class), we will inform these customers and make things right. Pure and simple.... I really can't explain it any simpler.
We are here for the long term! We have the new YD-A 56 and 112cc engines that we feel are a best in class design, plus at least 4 new ones on the drawing board. This is not an inexpensive venture, and one that we are taking quite seriously. Therefore customer service will always be our priority.
More on this as we get further into it.
Cheers
Henry
Cheers
Henry
#4129
RE: RCGF Engines
Hi
We just want to declare that Aerovate 28cc is not produced by our factory,please do not mix it with our RCGF engines. Thanks.
We don't want to be involved in the issues. Hope you both can find a very good solution way.
Johnny
RCGF MODEL
Johnny
RCGF MODEL
#4131
UT
RE: RCGF Engines
ORIGINAL: rcbill58
Hey seanreagan
OKAY.. call Al Young... JTEC Radio Wave
[link=http://www.jtecrc.com]Jtec[/link]
He and I talked about the solution at the WRAM show. He can fabricate a custom muffler for you. The stacks are used for this....
Defintely give him a call. He is a GREAT resource.
Hey Ratchet
I am here.. Our phone system just got upgraded and most of the phone messages that were missing are now back and stacked up waiting for me. I am getting through them (and yours!!! ASAP). Email me.. and I can get back to you relatively quickly. Sorry for the delay.......
Right now, I am with Bill Jensen at his shop. What an amazing place!!!!! I am in the garden of engine eden here.
Pit-Viper - The throttle arms were promised to be finished by the manufacturer this week. (yes.. they are being made here in the USA). I will announce it here as soon as available.
Jeanes - The 45cc is your ticket to nirvana for your airframe. Lot's of power when you need it...
Cheers to all
Henry
Hey seanreagan
Hey Ratchet
Cheers to all
Henry
#4133
RE: RCGF Engines
Johny B is just stating its not made at his factory. I'm not dodging and I think others aren't either, just waiting to hear the rest of the story. We should continue this on the Aerovate thread , it is not an RCGF engine.
Andy
Andy
#4134
RE: RCGF Engines
When it comes to gas engines, people are like lemmings in a way. Few know squat about them, and fewer still will freely admit when they made a mistake with one. Typically they know what they learned when they bought their last lawn mower or weed eater. Flip the choke and pull the rope, hoping they run. Often they'll go online and berate a product to cover up their own lack of knowledge and experience to cover up that they loosened some screws and altered the timing, failed to tune the carb, or took one apart and didn't know which way they went back together. When that happens all the other lemmings presume it's the truth for an entire engine line and run away from the brand because of one post.
People really need to qualify the experience level of some of the people posting, and this is especially so with the smaller displacements since that's the place those brand new to gas engines seem to be getting started lately. Don't jump to conclusions because one person had a bad time. If each engine and owner was representative of an entire production run there would be a lot of great 50cc and 100cc engines laying around that could be picked up for a song. Most all of them failing to run correctly because the owners did not know how to turn a carb needle....
#4135
IA
RE: RCGF Engines
ORIGINAL: Tired Old Man
Whwn it comes to gas engines, people are like lemmings in a way. Few know squat about them, and fewer still will freely admit when they made a mistake with one. Typically they know what they learned when they bought their last lawn mower or weed eater. Flip the choke and pull the rope, hoping they run. Often they'll go online and berate a product to cover up their own lack of knowledge and experience to cover up that they loosened some screws and altered the timing, failed to tune the carb, or took one apart and didn't know which way they went back together. When that happens all the other lemmings presume it's the truth for an entire engine line and run away from the brand because of one post.
...I almost hate to admit what I have picked up for nothing over the years, for just this reason.
#4136
My Feedback: (79)
RE: RCGF Engines
It is a different story when the owner mess's with it, but if the timing is not set correctly from the factory that is a different story. I just set the timing on a friends MT 42, where the timing came from the factory set at 18 deg also.[X(] The little plastic sensor needed its slots worked on with a jedwlers file to get enough adkustment to get the 29 deg. I came to the determination, that the holes drilled and tapped in the crankcase determine the timing. The sensor brkt is installed and pushed up tight against the screws and tightened down. But in the case of my friends engine the holes were indexed incorrectly on the case. It ran fine before, but seemed pretty lame. The simple checking of the Timing and fixing it picked up 600+ RPM instantly. Now it runs the way it should.
#4138
RE: RCGF Engines
ORIGINAL: AJsToyz
Andy
Andy
The JC 28cc uses the same off the shelf cylinder that RCGF originally used for their 26cc (Now RCGF use a different one but the critical measurements are identical - just the side plate is not there). The crankcase is also very similar but the crank is different. The outward appearance may be why some are confused as to the manufacture but the manufacturers name is pretty clear on the box and the engine itself.
I know that neither Henry nor I are ducking from the engines, what we are doing is working with the manufacturer to try to find out why it is that some of the engines are performing flawlessly and others are not. At the same time we have recommended some changes be made to them to bring them up to spec.
These are similar issues that caused us to depart from another brand recently and are the reason that I instigated a thorough set of inhouse partial disassembly and checks on every single engine prior to shipping. It is also the reason that a new Western built brand came about - simple QC.
#4139
RE: RCGF Engines
Without defending any person or manufacturer, we have to figure there will be a small percentage of products that get through that aren't as they should be. More than once I've had demo engines arrive that needed a little attention. Those are ones you would expect to be show pieces, yet things happen. Even the high end engine makers have had their share of gremlins, which later got straightened out.
It's when the percentages become high that we should become concerned, or when distributors fail to acknowledge the inquiries from their customers. In this case I don't see the distributors shirking their duty to their customers so I find it difficult to understand the apparent outrage from a person or two.
#4140
RE: RCGF Engines
Here is some background.
RC modeler for 48 years. Racing and tuning chainsaw based go karts in my teens. Racing and tuning two stroke motorcycles in my twenties. Racing and tuning club level sports cars in the 80's. Mechanical engineering degree Michigan State 1971. GE Aircraft Engine Systems, Performance Analysis and Test Engineering group from 1972-1984, Professional Auto Mechanic, including repair of weed wackers and chainsaws, off and on for 40 years. Successful conversions of four weedies; 2 Ryobi's, a Pro Mac 1010, and a Husqvarna 25cc. Check out the thread [link=http://www.rcuniverse.com/forum/m_8479610/mpage_1/key_/tm.htm]http://www.rcuniverse.com/forum/m_8479610/mpage_1/key_/tm.htm[/link] for some discussion on the Ryobi conversions.
diceco
#4143
RE: RCGF Engines
Folks, I'm sure its been asked before but, without reading all 165 pages of this thread I'm not likely to find the answer...
What's a good break prop for a 26cc RCGF motor? What prop would you use after breaking in the motor if you were going to mount the motor on the nose of a 14lbs P-51 and had a bent for speed?
Thanks!
Thanks!
#4145
VA
RE: RCGF Engines
"SOMEWHERE" in this thread of 165 pages I ran across what DL and DA engines use the same muffler size as some Aerovate and RCGF engines. Which one is the same as the Aerovate 45cc rear induction engine ?
#4146
My Feedback: (8)
RE: RCGF Engines
Go to Jtec the only other mufflers that fit the 45cc are ones that will fit the Zenoa G-62 and cheif aircraft sight shows several manufracters different designs. I would buy Jtec if I was you cause they are for the RCGF 45cc .Just my two cents worth
#4148
RE: RCGF Engines
Hi all,
Today i received the test unit of RCGF 15cc engine.
Some basic specs,
weight engine alone = 635g
weight with ign and muf = 825g
weight with ign and muf and stand-offs = 900g
i test this engine using various props,
14 x4, 14 x7, 15 x8, 16 x6, 17 x4, 16 x 4. However i found that for reliable idling and best thrust ratio, 15 x 4W APC prop is the best. idle at 1450rpm and peaked at 8850rpm. Mind you this engine is new and haven't broken in yet.
all test was done using RON95 petrol, and PETRONAS 1000 2T(mineral based) at the ratio of 30:1.
refer this video when i use 15 x 4W APC.
[youtube]http://www.youtube.com/watch?v=0RxhxCrCtnY[/youtube]
Some basic specs,
#4149
RE: RCGF Engines
Hi guys!
Anybody from you get in touch whit new RCGF 50cc B type engine?
It has a CNC crankcase.
I won’t to buy my first 500cc class gasser, but I don’t know is RCGF 50cc b type is a good engine to start.
How is this engine comparing whit DLE55 or 3MM53 or MT57?
Thank you.
Thank you.
#4150
My Feedback: (12)
MT
RE: RCGF Engines
Umran,
Sounds great!! Looks like the cyl. head is round, very nice.
Can you get some measurements on the 15cc? Good to hear they do actually exist. Any guess on when they may be available? Thanks for the update.
Shane
Shane
