DLE30!
Old 10-24-2009 | 05:14 PM
  #701
Default RE: NEW DLE30!
ORIGINAL: karolh
Capt,n,
Does your DL30 suffer from the same quirk as some others have of shutting off when tilted or lifted up.
Karol
Karol...read post #639 on page 26. It was very touchy, but after at least 70-75 Heat cycles and some fine tunning, its good to go! It has very good compression and has a good bouncy feel now also. Capt,n P.S. Some full throttle short blasts are good too after warm-up.
Old 10-25-2009 | 03:46 PM
  #702
My DL30 also has same tilt sindrome reported here.
at 2200 rpm hold ok in vertical, gentle tilt to horizontal the rpm will drop until engine quit.
boughted on e-shop in China, I have 2L ground break in on it and was very happy with it.
normaly i fly the engine at this stage, I may do that with this keeping the idle high.
look to me it is a carb problem, my DL50 don't do this!
Old 10-25-2009 | 03:58 PM
  #703
My Feedback: (29)
I am looking to buy a dle 30. Is this a problem from a supplier with a certain batch or all the engines in general?
Old 10-25-2009 | 04:18 PM
  #704
PlaneKrazee's Avatar
My Feedback: (14)
Doh!
Old 10-25-2009 | 04:22 PM
  #705
My Feedback: (29)
So should I be worried? Does this mean break it in on the ground with a few gallons or is it ok to fly? I want a reliable engine. I had a RCGF 26cc in my extra, but it didn't have enough power and now I'm looking at the DLE 30.
Old 10-25-2009 | 04:26 PM
  #706
craigteffe's Avatar
My Feedback: (24)
ORIGINAL: fern
I Can guarentee my problem was not the carb, I tryed 2 different carbs with no help. The problem is within the engine.
Old 10-25-2009 | 04:30 PM
  #707
My Feedback: (14)
ORIGINAL: craigteffe
ORIGINAL: Zippi
capt'n,
I't raining, 60°, and 20 mph winds here but a buddy of mine is coming over after work tonight and we are going to tag team this engine and see what we can do on getting it tweaked out. With him holding it and me on the needles we should be able to get it now. He is interested in getting one of the DLE 30 for a winter project so he wants to see one close up.
Let me tell you if your engine is doing the same thing as mine I don't think you will be able to fix it I changed everything that could be changed and I sent it back to Ralph and he said it was doing the same thing to him and he wanted to keep it to experiment on.
I Will keep everyone updated on what he finds, that way anyone else with this issue may be able to fix it instead of trying to fight the problem.
Craig,
Maybe you should buy a Syssa 180!
They are said to idle great.
Old 10-25-2009 | 04:43 PM
  #708
craigteffe's Avatar
My Feedback: (24)
ORIGINAL: PlaneKrazee
ORIGINAL: Zippi
capt'n,
Craig,
I looked at them when i was at Joe Nall flying this year, but I've had such good service from my DL 50 that I wanted to give them a try. After all the reports here and elsewhere i decided to go with the Dl 30 and it fits my application better. I cannot use the syssa in my large profile because of the top center standoff. I think Ralph is getting close to figuring out what is going on.
Old 10-25-2009 | 04:45 PM
  #709
You may be right, only time will tell. I should have worked on getting my DLE30 installed on my airplane. Instead I went to a swap meet and some items sold, but not too many. Lots of RC items of all kinds...just did not sell much. Looks like a lot of folks are stuck with a wealth of RC goodies! Capt,n[X(]
Old 10-25-2009 | 04:47 PM
  #710
On another forum Ralph says he has it figured out, but is being pretty secretive about it. Typical Ralph, but if anyone could get it figured out it would be him.
Old 10-25-2009 | 05:16 PM
  #711
The fix is in fine tuning, and try to prevent pooling...making it too easy to flood out on Idle speed. I got mine running good just by fine tunning. Capt,n Edit..UPDATE mounting the engine on a slight ange really did wonders for my engine. Capt,n
Old 10-25-2009 | 05:56 PM
  #712
craigteffe's Avatar
My Feedback: (24)
ORIGINAL: captinjohn
The fix is in fine tuning, but some may need the pop-off pressure set different. Pop off valves can make engines run too rich...making it too easy to flood out. I got mine running good just by fine tunning. Capt,n
Some of us are having issues that tuning cannot fix. I hope your engine gives you good service from here on out, but the fix from what i understand is not pop off or tuning, I checked and adjusted both. Have you mounted and flown the plane that its mounted on yet? Or is it still on the test stand?
I will be recieving my engine back from Ralph soon and will report back when it gets mounted.
Old 10-25-2009 | 06:14 PM
  #713
The engine is off the stand and I am in the process of installing it on my airplane. I did while on test stand, change the fuel line to a meium size neopreme Hays fuel line. Wish me a good flight, but I plan to fly fast and greese it in on landing. No fancy stuff on maiden flight! Capt,n
Old 10-25-2009 | 06:30 PM
  #714
Zippi's Avatar
My Feedback: (10)
Looks like I'll be sending my engine back to Ralph C. as well. I tweaked on this engine to many times to know that it's not a tunning issue.
Old 10-25-2009 | 07:22 PM
  #715
If you guys find out let me know. I am on my 4th gallon and it still quits so I don't think more fuel is the answer. I have tried lean, normal, and rich using a tach with no luck. I'm not a gas engine expert like some on the board, but it should not be that hard to tune an engine. I also tapped the float diaphragm which helped airborne. It has lots of power on the top end. It's the idle and quitting that's the issue. I'm going to try mine again this week and if it's still acting up I will get with Jody as I bought mine from Valleyview with my plane. It may just be an issue to a few engines that are defective. I don't think it's a design issue because we would of heard more complaints about it by now.
Old 10-25-2009 | 07:30 PM
  #716
craigteffe's Avatar
My Feedback: (24)
ORIGINAL: qspilotcmh
I am thinking that most of people are dealing with the issue and just not complaining about it. I could have flown the plane and just used a very high idle when flying and then brought the idle down on approach, but I should not have to do that and that is why I sent mine in.
Old 10-25-2009 | 07:59 PM
  #717
CAT POwer's Avatar
My Feedback: (61)
qspilotcmh, what is the serial # on your DLE30 ?
<br type="_moz"/>
Old 10-25-2009 | 08:01 PM
  #718
When I get a chance I am going to remove carb & reed box and look what the inside casting looks like. Good to find out this stuff. I cannot & will not send it back to where I got my Dle30 in Arizona. I was totaly banned from that site where I placed a lot of photos & data trying to help out. Life goes on...I had to solve and fix engines and worked on hundreds of them in my life! Capt,n
Old 10-25-2009 | 08:11 PM
  #719
Craig,
you could be right. I did not notice it until I tried to get the idle low enough to land around 1809-1900. My SU26 had light wing loading so you have to get the idle back to land.
Cat power,
000868
John,
anything you find out be helpful. I hope yours run well in the plane. It sounds like yours is running well.
Old 10-25-2009 | 08:15 PM
  #720
Antique's Avatar
That's funny...You HAD the first DL I sent out until you balked about the price and it was intercepted and got back...And then you misrpresented the circumstances on here...You're on your own, you'll probably find the fix..good luck...
Old 10-25-2009 | 08:56 PM
  #721
Antique (RCIGN) for you the only thing that stands between you being a very good engine man and being a super person that people could admire you is yourself. I can see better now in realilizing the way you replied about Scott Brillie and his engines & Bob and a few others on RCU. I will not argue with you. But you know & a few others know I told you not to sell your DLE30 engines for such a low price that you first quoated. By the way..I had to pay the shipping to another guy who you sent my engine too. Hey I am not going say anything more...just turn my cheek. Tell you wife I wish her to get better....she is more important than any engine. Capt,n
Old 10-25-2009 | 09:07 PM
  #722
My Feedback: (52)
ORIGINAL: fern
craigteffe, I too have tried everything I could come up with including days that turned into weeks, of searching the internet for the fix. The issue is not any better, and now after damaging my plane 2 times from dead sticks, I am just wandering if all the money and time I have put into what seems to be a KNOWN defect in this engine was worth it????
There is reports all over the net of buyers who have bought these engines have the same running problem and no one has the fix yet.
Forgive me for seeming upset but after having bought a dle-30 that was JUNK when I took it out of the box, buying the parts and paying for them out of my own pocket, rebuilding the engine myself, then spending weeks pouring over supposed to be fixes and NONE of them even coming close to taking care of the problem, I have lost any faith I had for these little motors and the people who make them.
The sad part is, it looks like the buyers and users of these engines are being used as test dummies. ( with the buyer getting burned ). After 30 years of working on gas engines I can not believe that the people who make these engines did not know there was a problem. How many planes will be damaged, and how much money will the rc buyer loose before there is a recall or the manufacturer of the engine is forced to do a recall ????????
Old 10-25-2009 | 09:18 PM
  #723
My Feedback: (14)
Antique, RCIGN, Ralph,
If you know whats wrong with the engines you sold why not share the information?
Old 10-25-2009 | 09:25 PM
  #724
I was going to take the reed block out and look around in there. Capt,n EDIT....UPDATE... I mounted the engine on my Giles 202 on about a 20 degree angle...now no engine quiting...I even tried to make it quit...she just kept on Purring. Capt,n
Old 10-25-2009 | 09:29 PM
  #725
My Feedback: (29)
Since there are so many problems with this engine, what is another choice for a reliable gas engine to power a 12lb plane if not the dle 30? Also some sellers are talking about the second generation of dle 30 now in stock. Are the problems solved or not with this batch?
