Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Gas Engines
 Vent line on a gasoline engine ..how to.. >
Old 08-26-2009 | 08:53 PM
Ken Cz's Avatar
Default Vent line on a gasoline engine ..how to..
Hi,
I am in the process of plumbing my first Gasoline engine and fuel tank setup.
I am using a 3 line system.
It just does not seem correct/proper to terminate the vent line by just having a piece of Tygon hanging out the bottom of the cowl.
Should there be a filter in the vent line to prevent crud from blowing back up into the tank?
Is there a fitting available to terminate the vent line at the bottom of the aircraft?
Just want to make sure my set-up is bullet proof and avoid any problems.
Ken -MI
Old 08-26-2009 | 09:00 PM
Default RE: Vent line on a gasoline engine ..how to..
your vent line should be long enough to wrap around the top of your tank then out of the cowl. I have a DL50 that the vent line comes from the tank and makes three loops that I tied to the engine box then down to the cowl. Any dust or trash has a long way to go before it ever makes it to the tank.
Old 08-26-2009 | 09:05 PM
See Don's Hobby Shop for vent line filters.
http://www.donshobbyshop.com/
Old 08-26-2009 | 10:08 PM
I know you asking more about whether or not to have a filter, but what I do for the vent line exit/termination is use the same thing as for the filler - http://www.slimlineproducts.com/onli.../f1_fueler.htm. I run the vent out through the bottom of the plane just ahead of the fuel tank as opposed to running it back up into the cowl.
Dan
Old 08-27-2009 | 04:45 PM
As long as the vent line has a U-loop in it, any exit position is fine. Some route it towards the fuselage end.
A filter in the vent line is not needed. Any dust that makes it up that line without sticking to the wet line wall would be a miracle. The line is flushed each time the tank is filled to overflow.
Old 08-27-2009 | 05:32 PM
Ken Cz's Avatar
Thanks to all for the valuable insight on vent lines! All suggestions and ideas are 'right on' and much appreciated!
Ken - MI
Old 08-28-2009 | 08:06 PM
Listen to pe reivers......He knows his gassers and will give you the correct procedure..
