DLE 20cc Gasser! (Data & Links 1st Post)
#5226
My Feedback: (47)
NY
RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)
And I'm using 14mm plugs for my XYZ 50, so I don't need a resistor. One less part to worry about.
btw - I swapped in my old XYZ ignition and there was still flutter on the elevator, but only on one side. Going to do some experimentation to see if it's the rudder, y-reverser, receiver channel.
#5227
My Feedback: (42)
NJ
ORIGINAL: microdon2
Also, ifit was radio interference, you would almost certainly see if hit the other channels as well. Rather than chase a ghost, try swapping out your elevator servo(s). Most likely it's just worn gears (if they are metal gears) or a worn pot. If so, expect the aileron servos to follow suite soon after. They're usually first to go, but it all depends on how things are set up, how much previous wear each servo had etc.
To make this more clear, a worn set of gears allows the control surface to bounce back and forth more, with greater inertia to overcome when the engine is running and making it rattle around. That can cause it to start oscillating as the servo tries to damp it out. A worn pot can cause the same thing to happen when excited by the engine vibration bouncing the control surface up & down.
#5228
Just wondering if you might be using a opti type kill unit ? I had a similar problem on a plane where the control surfaces jumped around and found out by taking the kill unit out of the equation that it solved the problem. Seems like what happened is the current the electronic unit on the motor was making affected the receiver and it was traveling through the wires to the receiver causing the flutter. Just a thought.
DougB1
DougB1
#5229
My Feedback: (47)
NY
NJR - thanks, and you're right - I'm right next to the plane when checking this. I'll look at the individual servos tomorrow.
DougB1 - pretty sure I already removed the Opti-kill switch, but will check that, too.
#5230
ORIGINAL: microdon2
DougB1
#5231
ORIGINAL: RiverLarry
When are you comming home you old Fart !!!! R/L
#5232
My Feedback: (7)
IN
ORIGINAL: ahicks
That little resistor was the subject of quite a discussion not too long ago. There was a comment made by somebody in a position to know, that it's not necessary...................
ORIGINAL: a1pcfixer
Look closely at photo #1, which shows the tiny resistor on the end - right portion of photo.
And be SURE (if you do one) to put the shrink wrap on loosely BEFORE everything else!
NOT something a newbie need be overly concerned about! If it came originally installed, leave it. If you want to experiment that's up to you.
#5235
My Feedback: (47)
NY
njfcflyer - as part of my troubleshooting I re-installed the original blue-plastic cased EI that came with the engine. And the engine runs great. As for the suspected radio interference, the elevators still had that intermittant movement - so either it wasn't the Rcexl EI, or both EI's were leaking radio interference.
Then I swapped out both of my elevator servos - Hitec 5645MG's - with two Futaba 3305's. And the intermittant movement is completely gone. So it looks like, as you suggested, the Hitec's were worn - even though I could feel no gear slippage and they worked fine without the engine on (does that mean it's the pots? Anything I can do to fix these?). Thanks for your input on this.
#5236
L I B the only props the LHS has are Zinger and Top Flite. Looks like I have to order from Tower if I want a good wood prop. The Master Screw props are pretty good for my glow popper, but I need larger ones, and I think only Wood should be used for them.
#5237
My Feedback: (7)
IN
ORIGINAL: acdii
If the LHS themselves & customers actually flew gassers, they'd be more inclined to have a wider range of props & various brands on hand.
http://www.valleyviewrc.com/estore/a...rs.html?cat=71
http://www.vesspropellers.com/servle...ter/Categories
http://www.chiefaircraft.com/radio-c...-spinners.html
#5238
The LHS by me cater to the electric crowd, so they have tons of electric props. Heck they dont even stock GP for the 4 strokes.
#5240
CA
Hey guys, I was wondering if someone could tell me how much fuel the DLE20 uses per minute. I only flew my plane about 7 flights before I crashed it. I timed it a couple times, and if i remember right, I flew 8 minutes and i used about a third of a tank. I just cant remember for sure. And I flew it hot. 1/2 to full throttle most of the time.
Here is my reason for trying to figure this out. Im trying to put a smoke system on the plane and the largest tank I can add is an 8 ouncer. My plane came with a 420cc (14.2) fuel tank. Since the DLE20 is economical, Ive thought about using the 8oz tank for fuel and putting the smoke oil in the 14 oz tank. But Im not gonna do it if its going to reduce my flight times to less than 8 minutes without some to spare for safety.
Thanks for the help fellas,
Jeremy
Jeremy
#5241
ORIGINAL: mach2
Jeremy
Jeremy
#5242
Tie that bird down good and seehow longthat20cc engine will run . My guess around 12 min. Give it a go....then you will know. Capt,n
#5243
ORIGINAL: captinjohn
Tie that bird down good and see how long that 20cc engine will run . My guess around 12 min. Give it a go....then you will know. Capt,n
+1
#5244
My Feedback: (7)
IN
ORIGINAL: mach2
................My plane came with a 420cc (14.2) fuel tank. Since the DLE20 is economical, Ive thought about using the 8oz tank for fuel and putting the smoke oil in the 14 oz tank. But Im not gonna do it if its going to reduce my flight times to less than 8 minutes without some to spare for safety.
Jeremy
Jeremy
But do some test runs and sneak up on it!
#5245
CA
Sweet. I want to try to slow the plane down and increase the throws because its such a speedster. The throws are fine when its movin along at 60+mph, but they are sluggish when slowed down. Its a GP Revolver 70". I dont really want to switch from low to high rates because im afraid that that will get me into trouble.
I do have low and high rates, but i just wanna fly my planes on one rate and be familiar with that.
Anyhow, thanks guys. If I run a 8oz fuel tank and a 14oz smoke tank, I could smoke out the whole town if I want to. I can crank that pump up to max and I dont think Id run outta oil...
#5246
MI
Captin John DLE 20 and 120 Space Walker should be done when you get home !!!!
the saito 150 that in it is a GLOW FUEL PIG !!!!
O Captin !!! just P/U a DLE 55 get back hear befor I cut my hand OFF R/L
#5247
#5249
I just about have my butcher bird ready to go. I am wondering if anyone knows the thread size of the dle 20 prop shaft. I have a couple pro spin aluminum spinners. But was also wondering if anyone knows where to get the brass bushings to fit the back plate to the dle 20 shaft. 1 I need tofind a spinner adapter for dle 20. 2 I need to find the brass bushing to fit the back plate to the engine. Any help would be apreciated. Thanks Dave
