Giant Scale Aircraft - 3D & Aerobatic Discuss all your 3D & Aerobatic giant scale airplanes right here!
Aero-Works 50cc Yak
Old 04-06-2006, 08:23 PM
  #251
edge540je
My Feedback: (190)
Default RE: Aero-Works 50cc Yak
I have to say. I just received my Yak today and all I have to say is WOW!!! Very nice job aeroworks!!!! I have the ne aerotech yak 54 and the quality of this plane beats it hands down. The aeroworks covering actually matches the painted pieces. And it is built strong. I would recommend the aeroworks hands down!! I am building mine this weekend with a 3W56B2 Twin. Will post pictures soon. P.S. you guys who are using the Da50 what size standoffs work 2.5 or 3"
Old 04-06-2006, 08:31 PM
  #252
bubbagates
My Feedback: (32)
bubbagates's Avatar
edge,
I have the Aerotech Yak also after I strip it and it will get sold as I agree, the Aerworks Yak beats it hands down.
Before you through the box away look at the packing slip envolopes on the box. One contains an addendum describing the distances needed from the fireall but to actually answer your quest, the standard DA 2.5 inch standoff are the ones recommended.
I'm going to use the 3 inch one so I can replace the tailwheel with a CF model move the engine out 1/2 inch and put the rudder servo in the tail. Other than that, I'm going to use all the stock stuff as it is first class
Old 04-06-2006, 08:35 PM
  #253
edge540je
My Feedback: (190)
If you find a buyer that would like a parts airplane we could sell them both. Ha Ha!
Old 04-06-2006, 08:49 PM
  #254
bubbagates
My Feedback: (32)
bubbagates's Avatar
I actually may have one. I have explained to him all the issues I found with mine.
Anyway, this is the Aeroworks Yak thread and I don;t want to posion it by discussing a true POS
I am completely impressed with this one, good coveriong, great build quality, nice hardware and I could go on and on. Too bad I'm heading to Toledo tomorrow or I would have it together this weekend not that it would matter because it's supposed to rain all weekend starting tonight
Old 04-06-2006, 09:01 PM
  #255
edge540je
My Feedback: (190)
I agree lets talk aeroworks!!
Old 04-06-2006, 09:25 PM
  #256
3dking
My Feedback: (26)
3dking's Avatar
Here's more pictures. I suspect that I will have to use the pitts muffler for added weight to the front end. I think if I were to use the standard muffler it would come out tail heavy...Any one using a standard DA muffler?????
ID:	440231   Click image for larger version
Old 04-06-2006, 10:44 PM
  #257
JoeAirPort
My Feedback: (41)
JoeAirPort's Avatar
You could also go with longer stand off's. That will keep it from being tail heavy. I went with 3.5 inch ones on my DA-50 for a 30% Edge to avoid the same problem.
ORIGINAL: 3dking
Old 04-07-2006, 09:41 AM
  #258
Whirlyspud
I notice that 130oz minimum is listed as being needed for the servo's. The question I have is should I go with more?
Mike
Old 04-07-2006, 10:07 AM
  #259
bubbagates
My Feedback: (32)
bubbagates's Avatar
Mike,
More torque is never a bad thing. I personally will be using 8611a's on 6 volt at roughly 250 ounce, at least that what JR says they are. I read where real world testing shows them to be more like 333
Old 04-07-2006, 11:52 AM
  #260
3dking
My Feedback: (26)
3dking's Avatar
4 5945's on elevators and ailerons and 1 5955 for the rudder. Knife edge pop ups are going to be a snap!
Old 04-07-2006, 07:09 PM
  #261
Yak Man
Yak Man's Avatar
Plane arrived, packing is first class, workmanship is outstanding.
A definite thumbs up to Aero-Works on ARF Quality!
Old 04-07-2006, 09:34 PM
  #262
Whirlyspud
I ordered servos and extensions today. What should I use for battery's for the rx and ignition?
Your opinions are welcomed.
Mike
Old 04-08-2006, 08:19 AM
  #263
ron9844
My Feedback: (65)
Received mine yesterday with some minor dents in the box. When I moved the box there was a lot of rattling inside so during inpection I found that the tape holding the wing tubes down had let go and they were sliding arund inside, but after inspection all is OK. THIS IS ONE NICE ARF. Not a wrinkle in the covering. Just waiting on the servos.
Ron
Old 04-08-2006, 08:24 AM
  #264
edge540je
My Feedback: (190)
Started on mine last night got the Wings Completed and I am on to the Stabs this morning. I opted to replace the control rods with H9 Pro-Links. If anyone is going that route the size you need is 2-1/2" for both ailerons and Elevators.-J
Old 04-08-2006, 10:13 AM
  #265
Whirlyspud
This will have to hold me till next week.
Mike
Old 04-08-2006, 02:30 PM
  #266
flatlandmike
My Feedback: (17)
flatlandmike's Avatar
You need 3 inch turn buckles for the ailerons man 2.5 for ele
Old 04-09-2006, 12:30 AM
  #267
JEFFRO503
My Feedback: (9)
Hey guys.just cruising through this thread and was wondering if anyone here has had or tried out a BME 50cc engine in this yak.............and if so , did it preform well? I think that the mojority of you have been using the DA-50 , but was wondering if any used the BME model?
Also.............i plan on getting this yak as well , as it seems that aalot of you say that the quality of this plane is very , very good. I was going to hold off until i get my motor , and was wanting to try out the new BME 55CC engine that is supposed to be released any time now. From what they say , it weighs in less than the 50cc model , and has quite a bit more power. Supoosivley up towards a 60-70cc engine...........i'll guess we'll find out , but that seems pretty bold to make that statement.
also.................For Mark here................Does the decals come pre-attached to the plane , or is it sent out all white , and waiting for us to put them on? I think i would actually like to get one of an all white version so i could do my own color scheme.
Old 04-09-2006, 01:34 AM
  #268
flatlandmike
My Feedback: (17)
I have 2 friends running a bme 50 on a couple planes One is a wild hare edge thats commimg in at over 18 pounds and with a 21/8 prop that kick ass. if you have a bme50 you prob should try that prop combo
Old 04-09-2006, 10:05 AM
  #269
Ernsbarger
Now that several of us are building these YAKS (WHAT A KIT!!!) has anyone gotten to the point of deciding to have a pilot or not. I've got a 30% pilot but the cockpit deck and canopy seem to swallow the pilot. Looks like the pilot would need to be raised approximately one inch. Any suggestions or ideas?
Old 04-09-2006, 11:22 AM
  #270
edge540je
My Feedback: (190)
Same problem here Pilot is Drowning/-J
Old 04-09-2006, 02:06 PM
  #271
Mark Dennis
Mark Dennis's Avatar
I always recomend to go a little bigger on the percentage for the pilot. For some reason they never look right unless you go a size bigger like a 30% plane and a 35% pilot.
As for the custom color scheme we do not have all white ones but we do have a few ARC's in stock if your interested give us a call.
Old 04-09-2006, 02:46 PM
  #272
bubbagates
My Feedback: (32)
bubbagates's Avatar
For those that did not make the show, what a layout AeroWorks has coming, very nice looking planes. I did order the Extra 260 50cc but they will not be ready for a few months longer. I asked Rocco about the pilot and he said the same thing as Mark, plus, if you are not aware. Aeroworks now has dash panels, nice ones, for this Yak. I grabbed one at the show.
Aeroworks is listening to us. They took all of the things they thought of after this Yak was created and things, we as customers have been suggesting, and now have incoorated them into the new line that is coming and all I can say is it is an impressive list of a small things that will make our lives allot easier in assembling these bad boys. Yep, read that as even easier. I actually did not think there was much else they could change to make assembly easier.
Mark,
Not to change the subject that much. I met your dad yesterday at Toledo, nice gentlemen[sm=thumbup.gif]. I hear you told him and Rocco about my wallet statement, I'm gonna get ya for that one J/K
Old 04-09-2006, 08:06 PM
  #273
sig
My Feedback: (42)
ok so mine is done except 4 inch carbon spinner...ive been waiting since nov.----any way I started it up today with the da 50 23/8 mejklick or what ever prop and tuned pipe KS set up.. WOW this is a beast,the only thing I was looking for is a place for a smoke tank and show time smoke pump(blue one built in 6 volt batt ...any ideas???gonna fly it tues. and here in pa it should have good vertical pull out due to elevation.i lost room due to the power expander which was total over kill in here but what ever--3 7.4 2800 tbm li-ionbatts whith mpi regulators on all.
ID:	442251   Click image for larger version
ID:	442252   Click image for larger version
Old 04-09-2006, 08:11 PM
  #274
bubbagates
My Feedback: (32)
bubbagates's Avatar
You could get 2 smaller dubro tanks and stand them on their side right where the stock tank is. That Da is only gonna burn about 1 ounce of fuel per minute
Old 04-09-2006, 09:32 PM
  #275
lazy eight
My Feedback: (389)
lazy eight's Avatar
Just got back in form the Toledo show and my Yak was there waiting for me when I got home. My wife was the one that took delivery of it! Everything looks good no damage. I started putting the servos in tonight. Lots of new toys from the show came home with me and some where for the Yak. I talked with Rocco for about 40 min. and I have to say one thing he really wants to bring the vary best planes to the market for us all to enjoy. And from what I have seen he has raised the bar to a new level. The 100 cc and 75 cc plane look totaly first class. Get your name on the list you will not be sorry. He says there is more to come in the way of new planes but would not say what they are but for all you Biplane fans I think there is somthing for you on the horizon. After loking at the 100 cc Yak all I can say is I want one! I started putting the 50cc Yak togather to night and everthing fits tight and all seams and joints are perfect. I could not build it better if I tryed. I have a DA 50 up front with pitts muffler carbon fiber spinner and carbon fiber prop CP models 22*8. Servos are as follows 5645's on the elevator's and 5625's on the ailerons and 5955 on the rudder. I'm using the IC4 servo isolater and 2700mah Nmh battery paks 6v for servo power and 4.8 on the reciever. I will give total wieght when its all done
