The BEST Smoke System
#202
My Feedback: (29)
AZ
RE: The BEST Smoke System
ORIGINAL: Josey Wales
Ok I spoke with Sullivan and they suggested to go to a lower voltage pack so I tried a 7.4 instead of the 11.1 and its MUCH better..even at 7.4 it still really pumps a lot at 100%..I lowered my End Point to 30% and it seems just about perfect...at least on the ground..The smoke comes on just a few clicks under 1/2 throttle..hopefully I will be close enough so I will only have to adjust the end point a little.
Bob this is how I have my TX setup..its a 9C
Pump is plugged into channel 5
endpoint is 30%
PMix #6...throttle master..aux 5 slave
Aux 5- null
pos 1 +100
pos 2 -89
pos 3 -90
pos 4- 90
pos 5 -93
endpoint is 30%
Aux 5- null
pos 1 +100
pos 2 -89
pos 3 -90
pos 4- 90
pos 5 -93
#203
My Feedback: (29)
AZ
does anybody know the song title and/or who sings that song in qq's turbine video?? thats a pretty cool tune and was wondering if i can get it somewhere?
#204
My Feedback: (61)
NJ
ORIGINAL: diamondave
why does it look like this curve is backwards in the mix?? the faq's page even shows starting at lower and going up to positive numbers, yours is the other way around?? i know i have time to play with this but i am curious why?
#205
My Feedback: (29)
AZ
okay...we'll see what happens with mine i guess,..
i also noticed using a p mix you cant assign to a "vr", like a knob or slider, so there goes my thought of using the slider even for an on/off, unless i set the pmix and leave a switch in a position all the time and leave the aux channel set to vre(right slider), then that may turn it on and off right??, i may change some things on my radio anyway and try switch h for the smoke, thats one i can hit easy too, however thats currently my idle down which i use sometimes when landing down hill, our runway is on a slight incline and when the wind blows a certain way, you have to land that way, the idle down helps to slow it down before going off the runway, but i may move that to "f", the spring loaded switch, i dont use that for kill because i have a fiber optic kill on switch e, but does anyone know if that would work like i mentioned about the aux channel idea?
#206
My Feedback: (61)
NJ
Well Dave you got me thinking so I went to a new memory and set up the smoke pump and it works like the faq says which means I prolly have some other mix activated that I forgot about..so I just copied my Yak into the clear memory and now it works like the faq except my percentages are much lower..my highest setting is 50% and it still pumps out a lot..
#207
My Feedback: (29)
AZ
cool, i was wondering about that with the settings, i guess the idea is to make a curve at whatever level works the best, ie.. higher like the faqs page or proportionally lower like you say, and maybe flatten it out in the upper middle section, so you get full smoke at 3/4 to full throttle?
#208
CA
Here is a quick pic of how I built up the sides of the mufflesr and tapped it for the smoke nipple. I currently have them plug as I am adding some more baffling.
#209
My Feedback: (40)
NH
#210
My Feedback: (29)
AZ
awesome, thanks, i thought the voice sounded kinda familar, but i wasnt sure, i appreciate it...
ORIGINAL: ncrego
It's Stephen Stills, Tree Top Flyer
#211
My Feedback: (29)
AZ
got my pump today, hope to get it in this weekend, not sure about flying it and testing it, but installed anyway
you guys using 2 check valves, should one be before the pump, and the other by the muffler? or both after the pump?
are you guys using the "crap trap" that came with the sullivan? any problems with that? i plan on using a filter in my pump line from the container, should i still use that craptrap?, i wasnt sure if it causes any flow problems...
#212
. . . are you guys using the "crap trap" that came with the sullivan?
#213
My Feedback: (61)
NJ
#214
My Feedback: (29)
AZ
thanks guys....does it hurt the pump to run it dry, i mean for a short time, like while setting up the radio or testing, to just turn in on for a few seconds at most??, or even flying if you run out of fluid and it is still on for a moment?
#216
My Feedback: (29)
AZ
thanks, i didnt see anything in the little instruction paper so i wasnt sure, i didnt plan on running it dry, other than just to test for power and turning on point
got the tank mounted, was thinking of puting the pump on top of that, i just realized i dont have enough tygon fuel tube, i think i have enough to go to the fueler, and then maybe i can use the neoprene from there, i bought a 2' piece of that, i thought i had more regular tube, i guess it wont matter about the black neoprene right? they reccommend a small peice at the muffler, it would be alright to have a bigger piece right? like from the fueler, i will still put the check valve where it supposed to go
#218
My Feedback: (29)
AZ
cool, i may end up with just enough tygon actually, once i mounted the tank it looks like i may make it, i plan on using a quick filler, so i have 2 shorter pieces that will make it, if i was going right from the tank i didnt have a piece long enough, should be plumbing it up today
has anyone mounted the pump on the wing tube?? someone told me you can ziptie or even tape the pump to the wing tube so its on the cg? my tank is about 6" or so from the cg, i was going to put the pump right on the tank, but i am wondering if thats enough to give me too much of an aft cg, its the easiest place to mount it for sure, i may check the balance there and see how bad it moves it, i took out my pilot which was 3-4 oz's and further back, so the tank and pump that close to the cg may not change it too much, any ideas? i dont like the idea of mounting to the wing tube because cant that rotate from vibration? i wouldnt want that, plus it would be harder to get at if i want to take it out for a while or something
#219
My Feedback: (29)
AZ
i was wondering, jw, you mentioned earlier about trying to slow the smoke way down, how much of a stream should i have at lower throttle? it puts out a pretty healthy stream, maybe i should start way down and then go up as needed? i plan to try it out this coming weekend, but i wanted to know if i should be more like a trickle at lower settings? i will find out anyway, but was curious...
#220
My Feedback: (61)
NJ
I started off at just enough to turn the pump over..but that is not enough because there will be back pressure from the muffler so I had to bump it up..I would start off low then work your way up. Even though the stream seems like a lot it will get cut down from the back pressure..After all the tweaking my pmix points are only different by 1-3 %..actually I could prolly just set the correct flow for 1/2-3/4 throttle and use that percentage for everything..its not that big a deal on mine..prolly with the bigger twins there is..
#221
My Feedback: (29)
AZ
did you ever figure out why your #'s were reversed? cause mine is doing the same thing, i havent tried reversing the "servo" yet though
i think i may end up with the same idea, as far as getting a good flow for 3/8-5/8 throttle or so, i am sure i will be happy with it no matter what, and maybe not burn through the fluid as quick either
#223
My Feedback: (29)
AZ
well i got everything ready to test out this weekend, but now there is a cold front coming through, supposed to be blustery and windy sometime tomorrow and sunday, i am hoping to have some calmer weather in the morning tomorrow to at least get a couple "smokin" flights, we'll see, may have to wait another week[&o]
#224
TX
Question for Josey Wales-- you mentioned going from an 11.1v to a 7.4v, why?
This will be my first venture (adventure?) with smoke. I have the Sullivan model. I says it is rated for 12v. I just assmed it would provide more smoke at the higher voltage.
Please explain. Thanks.
#225
My Feedback: (61)
NJ
ORIGINAL: torqmeister
