Comp-Arf Extra 260 2.6m Q's/Build
#128
My Feedback: (46)
RE: Comp-Arf Extra 260 2.6m Q's/Build
Well, the stock rudder servo mount broke today, it broke on the sides right where the lightening holes are, I think the only thing holding it together is the little bit of fiberglass on the sides of the wood.
Sooo...
I'm ordering up the AirWild servo tray to fix that problem.
I wouldn't recommend using the stock tray, it seemed to build pretty solid so I thought it would be ok, I haven't really pushed the plane very hard yet either. I got lucky that thing didn't break completely loose in flight. I do quite a bit of knife edge stuff, I like loops and cuban 8's while knife edge and I have two 8711's on the rudder sooo... it's not like I can't see how it broke.
Other than that, I put on some tail weight today, it really helped out the 3d on the plane, pop-ups and hovering are much better than they were, rolling stuff and harriers are much easier, I'm going to install the tray and then move the batteries back to keep the cg where it is now.
Anybody else flying or building this thing?
Sooo...
#129
My Feedback: (17)
OH
I am having someone build mine. (I like to fly not build ) Anyway I am using the SWB rudder tray with the pulleys. I flew it in my Edge and really like it.
Camss69 ... do you know where your CG ended up?
Doug
Doug
#130
My Feedback: (46)
ORIGINAL: WinginIt
Doug
Doug
I'm going to figure it out this week and I'll post where I am now. I know that today I rolled inverted and it pretty much kept flying straight and level where before it required down elevator to stay level and on an inverted 45 degree up-line it just kept going without climbing or falling, so it should be good to go now.
I'm also ordering one of these deflection gauges so I can set up the throw exactly.
http://www.airwildpilotshop.com/More...product&id=542
I like both the SWB and AirWild stuff, the AirWild tray is slightly cheaper, just as good, and recommended by the field expert so I'm going to give it a try.
I had to build mine myself, that way if I didn't like the way something was done I can just blame myself and it was kind of a pride thing for lack of a better word, I bought it, I'm flying it, of course I built the thing.
#133
My Feedback: (46)
The Fuse with all ready to fly equipment in it minus the canopy, wings, and stab, is balanced at 53cm from the tip of the spinner. The weights on the rest of it should be pretty much the same I would think from plane to plane as long as you have two servos in each wing.
I've started the rudder tray conversion, I recieved my airwild try and hardware kit yesterday, I'm going to try to mount it so that the servos are in the same location, with the tiller arm a little further back in the tail. I'm trying to figure out how to mount the tray in the plane, just some rails mounted to the sides of the fuse and then two rails going across the fuse but how do I hold the rails to the side of the fuse while the epoxy is drying? I don't have a gaint clamp....
#134
My Feedback: (17)
OH
ORIGINAL: camss69
#135
CA
camss69-- In previous composites I used hysol without clamping and have had no problems. I also have the mounted the cross rails that hold the rudder tray directly to the sides with little horse shoes under them without any problems either. On that one I used epoxy and milled fiber glass. Be sure to sand and clean the surface really well.
#137
My Feedback: (17)
OH
ORIGINAL: camss69
Thanks, are there local places that carry Hysol? What's it normally used for, can you get it from Home Depot or somewhere similar?
Thanks!
Thanks!
#138
CA
BVM carries it along with a few other giant scale vendors. There a many different types of hysol, they are thioxotropic (sp) meaning they will not run and stay where you put it.
You can accomplish the same thing using milled fiber and epoxy.
#139
My Feedback: (24)
SC
I just maidened my Extra 260 today. It´s the Flying Circus color scheme, engine is an EVOLUTION 116GX2 and JR 8411/8611a all around.
Wow, what an airplane. It flies extremely precise, like a perfect pattern plane should do, just some minor coupling for straight KE needed.
Though the engine is around a pound heavier than a DA-100, vertical performance is insane. I´m running a BIELA Carbon 25x12 3-blade turning already 6,600rpm!!!!! Try that with a DA-100[&o][img][/img].
Regards,
Uli
Regards,
Uli
#140
My Feedback: (17)
OH
ORIGINAL: slunicku
Regards,
Uli
Regards,
Uli
Doug
#142
Hi Guys,
Ive just ordered one of these in white, (I have my own color scheme in mind) and am going to set it up with a 3W 106 Competition motor. Any one out there done this and has advice to offer?
IL
Hello Spat Cracker,
I was originally going to use the same engine, but the cowl gets very skinny towards the front and my DA100 just fits. When I was looking at the 3W 106CS, it looked like it may hit the sides of the cowl due to the extra 1/2" or so in width vs the DA 100.
I would be nice to hear if this combo works. I almost did it, but then I decided to go with a DA 100 since it was a "known good solution".
#144
My Feedback: (17)
OH
I too have a white one which should be ready for maiden in a couple weeks. I also went with a DA-100. The main reason is because I am used to the DAs having them in 1 previous plane and my current Aeroworks Extra 260. Just really like them.
Will be very interested in how your 3W does. Keep us informed.
#145
Thanks guys,
I have the 3W CS sitting there needing a home so this is going to be it. A mate of mine is putting a DA85 in his, aparently they go well together also. Il keep you posted, just waiting for the long boat haul from Thailand to NZ.......
#146
My Feedback: (46)
If the 3w is wider than the DA you might have to cut a hole for clearance on the left side. I have the engine mounted according to the instructions (I'm using the DA-100) and my ignition cap on the left cylinder rubs against the cowl just barely. Just enough so that it wore through the heat shrink on the ignition wire boot on that side. I'm not sure if the plugs are angled on the 3w like they are on the DA or not.
A friend of mine is just about finished building one with a 3w and I can try and find out if he had clearance issues on the left side or not. His came out heavy at 30lbs but he has a smoke system installed, all JR 8711's in the entire plane, the big Fromeco 5200 batteries instead of the 2600's. I will be interested to see how it flies compared to mine which aside from a carbon wing tube and only running a single servo in the wings is about as light as I could get it.
On another note, I've recently starting adding the mix for knife edge flight. Wow what a difference, I should say that I don't usually add the mix in for my planes, I usually correct for it with the sticks in flight.
I was able to do inverted flat figure eights with the plane on the first try after adding the mix, also knife edge snaps, harriers and hovering were all tremendously easier. Ahh what a difference some tinkering time makes. My next several flights will be finalizing the mixing curves for knife edge correction, adding a throttle-rudder mix, and adding a throttle curve. It can only get better but it's already so good.
#147
Thanks Camss69,
I'll see how it turns out I guess.......still looking forward to the build, maybe I'll cut a cylinder off the 3W!!
Jas
Jas
#148
HI
My 260 2.6m is too tail heavy, i using 5955tg's all around, DA with stock muffs, 3x Fromeco 2600.
I have all the ignition stuff at the front of the motor dome, I think it would be pretty difficult to get it to balance out at 95-100mm, let me know how you do it, I ended adding about 26oz of lead to get it !!!
#149
My Feedback: (17)
OH
ORIGINAL: ASA28
HI
HI
#150
My Feedback: (46)
ORIGINAL: ASA28
HI
HI
