Giant Scale Aircraft - General Discuss all other giant scale aircraft here.
Edge 540 27.4% Build
Old 07-09-2014, 07:00 AM
  #1051
Melchizedek
Melchizedek's Avatar
Rapture guy
What's special about air tronics ?
Or were you just having fun ?
I'm Futaba. Minority in my club. Most guys spectrum.
Disregard if having fun. Sometimes I can be thick
Kevin
Old 07-09-2014, 08:20 AM
  #1052
raptureboy
raptureboy's Avatar
Just having fun, I'm a trouble maker at heart but I switched a couple years back and love them. I just bought the 10 chan sd10 and it is so easy to program and only one receiver is needed They all have plus and minuses though.
Old 07-09-2014, 08:28 AM
  #1053
acerc
acerc's Avatar
Ain't that the truth, I have always been a Futaba guy and I really like my Futaba T8FG but all the programming is a real PITA. For the life of me I can't understand why they feel the need for sooooo much programmability.
Old 07-09-2014, 09:07 AM
  #1054
Melchizedek
I'm with you Robert.
Moved up from 7 channel to the 14 sg.
Took me a week to kinda figure it out.
But you know. We are smater after figuring it out.
Kinda like staying in a Holiday in express
Kevin
Old 07-09-2014, 12:20 PM
  #1055
Jim Branaum
Originally Posted by VincentJ
Almost completely moved. Started to set-up my shop, will be remodeling this space after my Edge has been completed.
Tank has been plumbed, you can see how I ran the vent line if you look carefully in photo #3. I mounted the servos for the elevator halves and ran all the wires through the tube (rocket) that I had installed earlier in the build. It was a snap to just push the wires through and have them come out in the exact location that I wanted. I also installed one of four remote receivers in the tail and used the same chase to run the wire. The receiver that I am using is a 12 channel DSMX Power Safe Aircraft Receiver made by Spektrum.
When I mount tanks, I plumb the vent to a solid line coming down the firewall and out through the cowl. Sometimes the vent is a hard line through the cowl that disconnects when I remove the cowl and sometimes I just have a hole in the cowl that 'latches' over the hard line installed with those wire landing gear mounts. No, not the ones for gear legs sunk into wood but for gear on a surface.
So why did you put yours in the middle of your fuselage? MY way of thinking suggests that compromises that area of the fuselage, but my way is not always right.
Old 07-09-2014, 12:40 PM
  #1056
acerc
acerc's Avatar
If his overflow gives you pause, check out where my engine crankcase breather line exits.
Old 07-09-2014, 08:12 PM
  #1057
Cub Flyer Fresno
Cub Flyer Fresno's Avatar
On the subject of program-ability, give the FrSky Taranis a go! Talk about programmable! I love it... so far anyway. I haven't gotten to try it out in real life though, except for using it as a buddy box. Time will tell.
Old 07-10-2014, 01:15 AM
  #1058
stevegauth30
stevegauth30's Avatar
Hey Robert. Why don't you use some snaps for the flying wires? Lol.
Old 07-10-2014, 02:47 AM
  #1059
VincentJ
VincentJ's Avatar
Jim, I could have easily placed the vent line so it exits through the firewall and exit down through the cowl. I chose this spot for ease of removing the gas tank. The aluminum piece that the vent line goes through is a slightly modified fuel filler dot. The vent line simply slips through the hole, if the tank needs replacing it is an easy job of sliding the line through! As far as compromising the fuselage goes, the bottom of the fuse is balsa sheeted and glassed over so there's plenty of strength there. I am planning on placing a fuel filter on the inside of that vent line as well...
OK Robert, I hadn't noticed before the exit location on your Pitts. Is there a reason to place it in the tail?
Old 07-10-2014, 04:47 AM
  #1060
acerc
acerc's Avatar
LOL! The tube was originally as a replica for the cockpit vent per the model I am fashioning. This Valach being a four stroke needs a crankcase vent and this vent spews oil like a nitro. So the replica vent seemed like a good option to keep the black crankcase crud off the airframe. The pic is the new engine stand after a thirty minute run of the Valach, see the arrow.
Old 07-10-2014, 07:58 AM
  #1061
Jim Branaum
That is what I was looking for. My views on the fuselage are colored by MY approach which does not generally include glass.
Old 07-11-2014, 03:54 AM
  #1062
VincentJ
VincentJ's Avatar
Very smart and practical Robert!
Just an update on the progress of my Edge. Closing on my house is this Monday, so the push to get everything out and cleaned takes first billing. Setting up shop in my new digs gets second billing. (Got everything just about where I want it so I can work efficiently) With all this going on, some progress has been made on the Edge though!
Made a removable platform to hold the battery (3200mAh Life) and receiver, this should work well. I'm going to need to buy an adaptor to go from the battery's Dean connector to the EC3 connector that is on my Spektrum receiver. With this almost completed I will get started on covering the elevator halves and rudder next so I can make them functional.
Old 07-11-2014, 03:57 AM
  #1063
stevegauth30
Even with all that and you still find time for the shop. Now THATS impressive. You must be just dying to have the whole sell/buy/move ordeal behind you.
Old 07-11-2014, 04:01 AM
  #1064
VincentJ
VincentJ's Avatar
Oh you better believe it Steve, moving is a young man's sport! I am so done with it, I am lucky to have the help that my girlfriend (Marianne) gave me or this deal would not be going on...
Old 07-11-2014, 04:16 AM
  #1065
stevegauth30
I have the same joys in my hopefully near future if my place ever sells. Tough market right now.
Old 07-14-2014, 11:32 AM
  #1066
VincentJ
VincentJ's Avatar
Keep the faith Steve it will sell! Better start to thin out the stuff in the workshop that we all collect over time...
I closed on my house this morning, it was both a sad and happy moment for me ...Now a little more organizing on my new shop and I can get to some serious building. Sorry that the progress on this build has been so slow!
Old 07-14-2014, 12:23 PM
  #1067
acerc
acerc's Avatar
Looking forward to somebody getting something done. I know I'm not.
Old 07-14-2014, 01:27 PM
  #1068
Melchizedek
One chapter closes. Usually bitter sweet, even if the chapter is closed willfully.
But now a bright and promising new chapter has opened.
All the best, for this new chapter Vince.
Kevin
Old 07-14-2014, 06:59 PM
  #1069
out2pasture
Hi Vincent, I just want to say how much I love your Edge. What really kills me is this is just your beater plane. The good ones never leave the house! Congratulations on closing and moving into your new house. That's always tough. But life is like that and sometimes you just need a break. That's why I love this hobby.
Old 07-15-2014, 04:15 AM
  #1070
VincentJ
VincentJ's Avatar
Thanks Kevin and Mike, I am glad that is now behind me. I'm hoping this Edge is going to be my everyday flier. What makes this all fun (at least for me) is the dialogue that I have with all of you during this build. There is so much to be learned in this hobby...I know a lot of what I try is something that I have seen in other threads or from talking to guys at flying fields.
Old 07-15-2014, 07:49 AM
  #1071
ovationdave
My Feedback: (16)
ovationdave's Avatar
Beautiful work Vincent, very nice indeed....
Dave
Old 07-15-2014, 08:17 AM
  #1072
raptureboy
raptureboy's Avatar
We want private Ryan, we want Private Ryan, we want Private Ryan..... come on you know if those guys at topgun can do it you can too. Have you seen the B-29 thread? I got to see that plane fly, pretty amazing to see it doing a flat spin. I hope to check out your new digs this summer yet, and maybe do some flying together.
Old 07-15-2014, 06:15 PM
  #1073
VincentJ
VincentJ's Avatar
Haven't heard from you in a while there Dave...
Cliff, I hope you can make it! It would be great to get some air time...I haven't seen the B-29 thread yet.
Tomorrow I will start the covering of the tail, be sure to check in for the progress...
Old 07-16-2014, 08:20 AM
  #1074
raptureboy
raptureboy's Avatar
Sad to see Mac Hodges crashed his B-29 last week at a show in DE, went right over the crowd on takeoff and hit a tent. Amazing no one was hurt.
Old 07-16-2014, 12:15 PM
  #1075
VincentJ
VincentJ's Avatar
WOW, I'll have to watch that clip!
I worked all day in the workshop covering the tail, I used Hangar 9's Ultra-Cote. Though it's easier for me to use than Monokote it was still a pain. I had forgotten how much I dislike covering with plastic! Oh well, it did do its job keeping the weight down on the tail section...
I'm going to post the pics now, but I don't have the time at the moment to explain the covering procedure so I'll do it tomorrow...My honey and I are going out to celebrate!
ID:	2014769   Click image for larger version
ID:	2014770   Click image for larger version
ID:	2014771   Click image for larger version
ID:	2014772   Click image for larger version
ID:	2014773   Click image for larger version
