Go Back  RCU Forums > RC Airplanes > Giant Scale Aircraft - General
Reload this Page >
Great Planes Giant Citabria GP/EP ARF 85"
Giant Scale Aircraft - General Discuss all other giant scale aircraft here.
Old 09-19-2014, 07:01 AM
  #76
jwrich
My Feedback: (17)
jwrich's Avatar
Signed On
Rich
Old 09-19-2014, 07:09 AM
  #77
jwrich
My Feedback: (17)
jwrich's Avatar
The big brown truck dropped off a big box this evening. I quickly open the shipping box, there was the airplane box, as I opened the box I was worried about the condition of the plane. I have been building RC planes, scratch & kits, for more than 30 year, this is my first ARF. I was amazed how well everything was packed, everything wrapped in bubble plastic and taped together. I spent the next 3 hours unpacking and inspecting the kit. Also I installed the servos in the wing for the ailerons & flaps. I read the construction manual on Tower site so I was ready when it came. I want folks to see how well the airplane arrived, if you have never had an ARF kit you will be surprised. Here are some pictures.
The work will begin tomorrow
Rich
ID:	2033462   Click image for larger version
ID:	2033463   Click image for larger version
ID:	2033464   Click image for larger version
Old 09-19-2014, 07:46 AM
  #78
drdoom
My Feedback: (9)
My fuel tank set did not include any brass fuel line..
Old 09-19-2014, 11:28 AM
  #79
CARS II
My Feedback: (7)
CARS II's Avatar
Same here, the brown truck came yesterday, my son received it for me since I was at work, the text came around 10:00 am. What in the world is in this huge box?
Just like the others, excellent packing, no damage to the box ( Thank you UPS ) and now the time has come to start working on it.
By looking at the other pictures, one could say the same guy box all the kits,
Oh yeah! my wife saw the ( huge ) box in the living room and she had to call me at work to give me her opinion regarding the ( huge ) box.
ID:	2033530   Click image for larger version
ID:	2033531   Click image for larger version
Old 09-19-2014, 11:35 AM
  #80
CARS II
My Feedback: (7)
CARS II's Avatar
drdoom
Pick up some brass tubing at the LHS and a pack of fuel barbs.
http://www3.towerhobbies.com/cgi-bin...b%3C%2Fb%3Earb
Old 09-19-2014, 01:07 PM
  #81
CARS II
My Feedback: (7)
CARS II's Avatar
drdoom
Did you checked this bag group for your brass tubes.
ID:	2033554   Click image for larger version
Old 09-19-2014, 01:26 PM
  #82
CARS II
My Feedback: (7)
CARS II's Avatar
Double posting
Old 09-19-2014, 01:40 PM
  #83
CARS II
My Feedback: (7)
CARS II's Avatar
I completed my QC, all looks really good, very clean no extra glue any where or wrinkles, looks like every part of it is here, the wing tube fits snug, not tight, just fine
On my first inspection I found that I have an extra windshield magnet and that one or two of the windshield magnets are loose, every time I pulled the windshield off the two magnets were popped out about 1/16, a spot of CA under them should fix that, check them before you get a surprise.
I had my QC inspector go over the airplane also.
ID:	2033572   Click image for larger version
ID:	2033573   Click image for larger version
ID:	2033574   Click image for larger version
Name:	GeeBee 004 (2).JPG
ID:	2033575   Click image for larger version
Name:	GeeBee 001 (2).JPG
ID:	2033576   Click image for larger version
Old 09-19-2014, 01:53 PM
  #84
drdoom
My Feedback: (9)
Originally Posted by CARS II
drdoom
Yep thats where I found them. I made my own barbes out of copper wire wrapped and soldered.
Old 09-19-2014, 02:01 PM
  #85
drdoom
My Feedback: (9)
Covering the firewall with printers plate!
Old 09-19-2014, 04:33 PM
  #86
[email protected]
After arriving home I worked on the left side of the cowl, cutting out for the plug. But stumbled upon a major problem with using this engine. It will not work. I tried cutting up a shorter version of the cowl ring to give clearance of the cylinders but that wont work. I have only one option at this point, split the top off the cowl and ring. Making it a two piece and securing it together using pan head machine screws and strips of aluminum might work. Because it is just too big of a motor for that ring ever to slid off.
So has anyone ever tried this? I think I know how I want to do it, but I am open to ideas from someone who has seen or done this before. Not in the mood to experiment.
Old 09-19-2014, 05:11 PM
  #87
[email protected]
OK, I answered my own question. I will install the cowl ring and use it to screw the cowl to it using either 4 or 6 screws. That way the cowl can slid off with no problem. A lot less unsightly that cutting the cowl in half. OK, I can sleep tonight and not think about it.
Old 09-19-2014, 06:31 PM
  #88
Flyboywbl
Flyboywbl's Avatar
Cool thanks!
Do you get one 5-10 minute flight? Or five, ten minute flights?
Old 09-19-2014, 07:41 PM
  #89
cloudancer03
My Feedback: (22)
Hi tom.i am that ny guy that built a scale spacewalker.got a question for ya.i was going to fly my gas plane with an ibec and one battery but thought about it and am installing a redundant system hers the thing I reconfigured the set up and plugged my second battery into an open port on my ch futaba rx. The first battery is in another open port with a switch.should I get a miracle switch?then I have 2 switches 2 batteries same chemistry life.to one receiver.i was going with 2 batteries one switch but that seems to negate the goal for redunacy.As always appreciate your advice.dennis
Old 09-19-2014, 07:45 PM
  #90
cloudancer03
My Feedback: (22)
Rx is 8 ch.because the elevator is split flaps all ports are now filled.do I y harness the split elevators or y harness the second battery with say the throttle servo port.
Old 09-20-2014, 01:18 AM
  #91
Lifer
Lifer's Avatar
Split with a Y-harness.
Old 09-20-2014, 05:29 AM
  #92
dasintex
My Feedback: (10)
dasintex's Avatar
I hope this isn't a dumb question, I just got my Citabria and went through all the parts and reading the instructions I have a quick question, do the wing halves not get glued together? do they stay separate and mount to the plane as 2 separate halves joined by the wing tube, etc.
Thanks.
Old 09-20-2014, 06:38 AM
  #93
[email protected]
No they don't. But now that I think about it, the only reason to keep them two piece is for easy transport.
Old 09-20-2014, 07:37 AM
  #94
dasintex
My Feedback: (10)
dasintex's Avatar
So there wouldn't be any reason why you couldn't go ahead and glue them together, if transporting was not an issue? The wing span is 85" any of the Top Flite Giant Warbirds are 1 piece wings at about the same length.
Old 09-20-2014, 12:32 PM
  #95
Flyboywbl
Flyboywbl's Avatar
So i have not opened mine up yet, (still moving across the country) but I was thinking about installing a landing light like my real Citabria had in the cowl. I would slave the light to the flap servo so when the flaps came down, the landing light came on. It might be a nice scale touch. Does anyone here recommend a RC lighting system? I have never used one before.
-Matt
Old 09-20-2014, 02:01 PM
  #96
CARS II
My Feedback: (7)
CARS II's Avatar
Thanks.
If transportation or storage is not a problem then, by all means glue the two wing half together, it will make it a stronger wing,
Old 09-20-2014, 02:13 PM
  #97
CARS II
My Feedback: (7)
CARS II's Avatar
Matt
Check this one out, looks like the USA west warehouse is out of the switch at the moment but looks like more are on the way.
http://www.hobbyking.com/hobbyking/s...arehouse_.html
Old 09-20-2014, 03:08 PM
  #98
Flyboywbl
Flyboywbl's Avatar
Matt
Sweet, thanks! I thought it would be cool to put Nav/Strobes too but that might be a little difficult putting them on the wing tips and end of the rudder.
Old 09-20-2014, 04:51 PM
  #99
CARS II
My Feedback: (7)
CARS II's Avatar
Anything is possible Matt.
Old 09-20-2014, 04:57 PM
  #100
Flyboywbl
Flyboywbl's Avatar
Haha that is true!
