Go Back  RCU Forums > RC Airplanes > Giant Scale Aircraft - General
Reload this Page >
Great Planes Giant Citabria GP/EP ARF 85"
Giant Scale Aircraft - General Discuss all other giant scale aircraft here.
Old 09-20-2014, 05:12 PM
  #101
Flyboywbl
Flyboywbl's Avatar
This looks interesting!
http://www.hobbyking.com/hobbyking/s...ng_System.html
Old 09-20-2014, 05:31 PM
  #102
[email protected]
I got them installed already. The wing tips and strobe were easy, the tail was a little difficult. Photos tomorrow if anyone wants.
Old 09-20-2014, 05:50 PM
  #103
Flyboywbl
Flyboywbl's Avatar
Yes sir! Much appreciated. If you don't mind going through your setup and installation process, I would be very thankful. I'm not much of electrition so when it comes to soldering resisters and such, I'm kind of a newb.
Old 09-21-2014, 05:38 AM
  #104
[email protected]
The tail was the only difficult light to add. Drilling the hole had to be done by starting out with a small bit and working up to one just under the thickness of the rudder. Rather than fishing the light to the tail, I slit the back at the stab and spread it open to stuff in the wire. The picture is worth a thousand words.The wing tips are easy, just pick a spot just behind the wing tube. The strobe I placed on the top just behind the wing. Just glue a piece of ply in place, iron the covering to it for added strength and pop it in.
ID:	2033870   Click image for larger version
Old 09-21-2014, 08:49 AM
  #105
Flyboywbl
Flyboywbl's Avatar
Cool thanks! Did you add a landing light to the cowl? Which lighting unit did you use? Do you have a separate battery or did you run it off your RX pack?
Old 09-21-2014, 09:10 AM
  #106
[email protected]
No landing light....yet. This is a RAM125 4 light sys. Now it can be powered up with 4.8 v to 12 v, it has a 9V connector and a connector for the receiver. So when you hit the rec PW switch. Very bright!
Old 09-21-2014, 04:10 PM
  #107
Flyboywbl
Flyboywbl's Avatar
Ok so after scouring the internet all day, this is what I came up with, http://www.scaleflying.com/Scale-LED...anes_p_17.html
It will allow me to do a white tale light, nav/strobes and a bright landing light in the nose. It will all be powered off the RX battery. I think I might put the lighting on it's own channel. Scale flying also had some awesome lexan nave light covers that come in different sizes http://www.scaleflying.com/Light-lens-set_p_3600.html. They are currently out of stock. My plan will be to build a scale nave/strobe light to insert on the wingtip.
-Matt
Old 09-21-2014, 04:30 PM
  #108
[email protected]
I noticed in your earlier post Flyboywbl that you are also using S3003 servos with your 6V system. I do believe these are 4.8V servos. Need to check on that to confirm.
This weekend I was sick, did not get a lot of anything done. But I did work out the problem with the cowl. It's mounted and everything else is pretty much done. Should be, I have almost no parts left except for the interior trim. I did the setup using an old 7 channel Rec, but ordered a 14 channel for this plane. Which will let me have a channel for every servo, and one for the nav lights. Gonna go with a manual choke on this because of just one thing. On this motor the choke arm pulls up and down. Not like the throttle which lets you install a servo behind the motor. I cant see a servo working properly on the choke on this motor. Wish I knew this about the VVRC40 twin before, I might have just spent a few dollars more for the DLE.
ID:	2034035   Click image for larger version
ID:	2034036   Click image for larger version
Old 09-21-2014, 04:46 PM
  #109
Flyboywbl
Flyboywbl's Avatar
Tower hobbies says 57 oz/torq at 6V so it think it's ok. It just says if using NiMh, Lipo or LiFe, make sure they have sufficient amps. It's a 3200 mAh battery so it should be good.
looks good! I can't wait to start mine. I get to MN on the 26th.
-Matt
Old 09-21-2014, 09:23 PM
  #110
bjackson1206
bjackson1206's Avatar
Originally Posted by Flyboywbl
Cool thanks!
Do you get one 5-10 minute flight? Or five, ten minute flights?
5 ten minute flights
Old 09-22-2014, 08:24 AM
  #111
nc state
Model Airplane News has a great story about this A/C.
NC State
Old 09-22-2014, 09:17 AM
  #112
Lifer
Lifer's Avatar
Model Airplane News has great stories about any of their advertisers products.
Old 09-22-2014, 01:37 PM
  #113
[email protected]
So, Flyboy, you are from MN? I lived up there for about 30 years. Finally got fed up with the cold and moved to FL. Never regret it
Old 09-22-2014, 04:23 PM
  #114
Flyboywbl
Flyboywbl's Avatar
Yeah born and raised, White Bear Lake, go bears! I have not gotten sick of winter yet. My wife is from MT so she is used to it. Winter is building time up north!
Old 09-23-2014, 01:53 PM
  #115
CARS II
My Feedback: (7)
CARS II's Avatar
Looks like TH is out of the Citabrias, I'm happy I got mine just in time, by the way I saw a piece of scotch tape on mine, on the windshield frame with a 129 number, I wonder if that is he kit number from the first batch.
Old 09-23-2014, 03:11 PM
  #116
[email protected]
Has anyone else started on their Citabria yet? Haven't heard much in it.
Old 09-23-2014, 03:39 PM
  #117
Flyboywbl
Flyboywbl's Avatar
Friday, I hope...
Old 09-23-2014, 04:01 PM
  #118
dasintex
My Feedback: (10)
dasintex's Avatar
I started mine; got the wing halves finished, complete with all servos and control surfaces mounted, tail feather attached and glue drying as I type this, tomorrow will attach the elevator and rudder control surfaces, pushrods and servos.
Anyone putting a Pilot Figure in like the 1/4 Scale Great Planes Figure that is recommended?
Old 09-23-2014, 05:45 PM
  #119
CARS II
My Feedback: (7)
CARS II's Avatar
I also started but not much done, I will be posting pictures of my progess starting this weekend, I will also install a lighting system like the one Matt suggested.
I decided to go with one 2500 A123 LiFe batt, this batt will power the receiver, servoes, lights when in used and ingnition for the engine, one on/off switch, an IBEC, two digital HS servoes ( throttle and Rudder ) and six HS 645 analogs for the controls, all metal gear ( because I have them ) a 7 channel receiver, pilot as suggested by the manual.
Old 09-23-2014, 05:53 PM
  #120
CARS II
My Feedback: (7)
CARS II's Avatar
Double posting
Old 09-25-2014, 03:38 AM
  #121
Planejaw
My Feedback: (53)
I'm curious as to your decision to fly on one battery. I have always used at least two batteries (three in some larger 30cc and all 50cc and larger aircraft), banking on the redundancy and ability to isolate the receiver power from any other sources (lights and ignition) that draw power from the same battery. It's pretty cheap insurance to have the second battery to split the load between components. It also ensures you have the ability to power your most critical item, the receiver, with an isolated power source that is not being called upon to power other items in your aircraft...IMHO.
Old 09-25-2014, 05:16 AM
  #122
[email protected]
I have never used a second battery, even on my larger 55cc aircraft. This 35cc size medium performance aircraft is not what I would call a demanding power drain. Now with the added lights I can understand the need for another battery. I should check on the current drain for these four LED's. But....they are only LED's so the drain should not be that bad. However, I will closely monitor the drain on the battery on the first few flights. Which may not be this weekend, but surely by the next. I have very little left to do.
Old 09-25-2014, 06:25 AM
  #123
Planejaw
My Feedback: (53)
Again, I think there are a lot of things we do that we "get away with" in our RC aircraft, but it's not a matter of "if," but "when" an item will fail. And, almost anything can fail, whether on our RC or full size aircraft. When you look a those "single-point of failure" items for RC aircraft, batteries are at the top of the list. If your one battery gives up on you, game over! You may be able to recover from a problematic servo or a fuel line that is clogged, but when the batteries give up or "brown-out" your receiver from a significant current draw, that second battery doesn't seem like all that bad of a concept. Even if you're not running lights, but just a receiver/servos and the ignition from one battery, why take the chance? Redundancy and a thorough pre-flight will take care of most items that could potentially cause the loss of an aircraft or injury to a person or property (if in fact you perform a thorough pre-flight). We can't control everything, but we can practice risk management. You'll never know if any particular servo has 5 good minutes left in it's lifespan or if you battery has only 5-minutes left. But if you have two batteries or run a Smart-Fly with three batteries (which I also do), you are helping to reduce your risk. True, if you are running on two batteries and one goes bad, there is a 50-50 chance the bad one will be the receiver battery. If you are only running on one battery, and it goes, there's a 100% chance your airplane is going down. Well, as with most things in life, it's the choices we make! I'm running two 3200 Hobbico LiFe batteries in my Citabria. One for ignition, one for the receiver.
Old 09-25-2014, 08:23 AM
  #124
drdoom
My Feedback: (9)
Well Im almost finish with the fuse. I used 1/32 OD Al tubing to thread the flying wire thru. at the stab and vertical fin...
ID:	2034959   Click image for larger version
ID:	2034960   Click image for larger version
ID:	2034961   Click image for larger version
Old 09-25-2014, 09:04 AM
  #125
dasintex
My Feedback: (10)
dasintex's Avatar
Did you first thread the flying wire through the tubing then bent the tubing with the wire in it to the angle/shape you wanted?
